30,000 maintenace list ok?
Old Jan 7, 2007
CIVIC X3's Avatar
CIVIC X3 is on a distinguished road
well, i am about to hit the 30,000 mark. so i jus wanted to make sure i got everything down.
no need for air filter since i have a brand new weapon R intake.
cabin filter change
tire rotation
spark plugs (i run hard alot so i might just take a look first b4 changin it)
ngk spark plug right?
oil change
oil filter change
radiator fliud change
transmission fluid change
can someone help me get the link how to change the transmission for the manual...i only see the ones for auto and i remember for manual there is an extra bolt you have to take out to refill the fliud. i've done transmission fluid change to my brother car all the time, but its an auto, and i have a manual.
Old Jan 7, 2007
Alpha 5's Avatar
It is not up yet but it will be soon.
7th Generation Civic - Login
Old Jan 8, 2007
CIVIC X3's Avatar
so i guess this website is not for the 7thgen? wut ever happen to the old 7thgencivic...
Old Jan 8, 2007
03TxCivic's Avatar
03TxCivic is an unknown quantity at this point
we are like stockton and malone now..a HONDA POWERHOUSE... I skipped my 30k checkup..ill do the 50 in a few months though. Everything listed seems to be up to par buddy.
Old Jan 8, 2007
CIVIC X3's Avatar
hey ty for the reply...so many come in but dunt leave a comment...o well..
Old Jan 8, 2007
03TxCivic's Avatar
I think the main reason i skipped that 30k mile checkup, was the fact that it was going to cost me a lot. My stepmoms cr-v got the 30k checkup and it was like 400 dollars...and after the checkup the alignment was off horribly..
Old Jan 8, 2007
TRIZ's Avatar
my 60k check up was cheap, less then 200. like 150. I did some of the work myself, told them dont mess with my intake, did my own cabin filters, spark plugs changed, they just did everything else. Why not spend some money and make your car stay healthy and last?
Old Jan 8, 2007
03TxCivic's Avatar
Sorry. I'm a cheapass. I'll take it for the 50k checkup. I dont to any of my own stunts so its gonna cost me a bundle. I'll tell them to leave my alignment alone..they seriously messed up the cr-v. I think they fixed it, but i dont remember.
Old Jan 8, 2007
jester444's Avatar
Dain Bramaged.
jester444 is an unknown quantity at this point
A lot happened to the old site. It's gone, in essence. The members that were 7thgencivic.com left to other places. Some made a wanna-be site on proboards, others joined more reputable sites such as importpassion.com, and others made a more technical-centric site, namely EMHonda.com. That's where you'll find most of the users that are the most knowledgeable about these cars. Not on this board. The most helpful guys have left, to repeat myself.
Old Jan 10, 2007
CIVIC X3's Avatar
wow that really suck...i learned so much from 7thgen website too...=/ guess there is no point of coming here anymore. no more 7thgen car meets...
Old Jan 10, 2007
jester444's Avatar
Dain Bramaged.
All the guys that organized the meets and things like that moved over to importpassion.com. I'd go check that out if I were you. This site is still good though, if only for its databases.
Old Jan 10, 2007
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
cabin filter change
tire rotation
oil change
oil filter change
are you doing this yourself? well your asking for a diy so i guess yea.
im about to hit 30,000 (at 29,890)
I bought:
Denso Iridium - but really you shouldn't have to change the plugs til like 60k miles, drive it hard every now and then as well.
Royal Purple 5w-20
Bottle of Lube Control
Hampa Oil Filter
Prestone Pre-Mixed Coolant
Bottle of Water Wetter
2 quarts of GM Synchro Mesh
Old Jan 10, 2007
mr.rowdy's Avatar
mr.rowdy is an unknown quantity at this point
go to emhonda.com it is all about 7th gen and pretty cool
Old Jan 10, 2007
Matteo's Avatar
Matteo will become famous soon enough
i feel like an idiot in asking this, but whats the cabin filter?
Old Jan 10, 2007
Alpha 5's Avatar
I knew this was coming!!!!! Look behind your glove box. There is a cabin filter it filters the cabin air.
Old Jan 11, 2007
jester444's Avatar
Dain Bramaged.
Yeah, it's not easy to find. There's two filter elements in there, even though it doesn't look like it.
Old Jan 12, 2007
CIVIC X3's Avatar
my plan for 30,000, and yes i'm doing this myself.
prestone coolant
moblie 1 5w-20 + oem honda filter
oem cabin filter
ngk/denso iridium
honda transmission oil 2 quarts<<< still need help with this. i dont know which bolt to remove. i know there is two bolts you have to remove. one is to drain and one is to refill. *shrug
Old Jan 13, 2007
Matteo's Avatar
o haha, i knew there was some sort of filter for that..just didnt now it was called that or located behind glove box, thanks. I didnt even kno u were supposed to change those! lol
will Honda do that in their warranty check-up dates? my car is just just 2 years old now
Old Jan 14, 2007
CIVIC X3's Avatar
now really that hard to change...if u can change the air filter, u should be able to change the cabin filter...
Old Jan 14, 2007
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
prestone coolant
oem cabin filter
ngk/denso iridium
I wouldn't go with prestone coolant, i'd go with honda oem. If you want something else that you can buy easier, go with zerex.
If you have a 5 speed civic, im pretty sure the bottom bolt with a square in it for a socket wrench is the drain plug, and the fill plug is the larger one, 17mm i think.
Old Jan 15, 2007
CIVIC X3's Avatar
wow...finally! ty a bunch ctx66. really appreciate the help. 2 quart of transmission oil is fine right? and ty for the heads up. i'll go and pick up the honda coolant too.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
