Which maitenance is worth the effort - Honda Civic Forum
Old 01-03-2007
k-lines is an unknown quantity at this point
Which maintenance is worth the effort to do our own? Assuming that you don't work full time as a mechanic and only have spare time on the weekend.
I would have thought
1) Change Oil and Oil Filter (every 10k)
2) Cleaning and change Air Filter
3) Filling all the lube...
any other thought?
k-lines is offline
Old 01-03-2007
The only Wyoming Redneck on here
2002civicLX2002's Avatar
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
change the oil sooner, if your just using regualr 5-20 oil you should change it 3000 miles, if your using full sythentic change it every 3000-5000 miles. change your oil filter every oil change. your air filter should be changed about 10000-15000 miles, just check it every oil change. if you can see light through the filter then it is still good. you should always check all your fluids and keep them full. and change everything on time. all that will keep your car in good shape.
2002civicLX2002 is offline
Old 01-03-2007
4rns860's Avatar
4rns860 is an unknown quantity at this point
Talking Invest on a torque wrench, jacks and stands
a good Torue wrench would cost just about $30-40 bucks and now you can rotate your own tires
4rns860 is offline
Old 01-12-2007
ctx66 will become famous soon enoughctx66 will become famous soon enough
oil/filter changes and air filter changes are simple.
if you were to run conventional oil, id change it and the filter every 5,000mi.
if you were to run synthetic oil, id change it and the filter every 7,500-10,000mi
air filter every 15,000mi
ctx66 is offline
Dawit Melese
6th Generation Civic
10-04-2015 09:02 PM
jackoncruzpr
7th Generation Civic
09-29-2015 08:59 PM
deanaZoom
35
09-19-2015 01:22 PM
Bikergofast
09-12-2015 02:36 PM
Quick Reply: Which maitenance is worth the effort
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
