So i was just messin around the engine...
Prince of Persia
Rep Power: 240 So i was just messin around the engine...
... puttin the cai back in and takin stuff apart/assembling them, when i decided to take a look at my spark plugs. so i pull out the "rod" that's above my spark plugs and in the chamber i find that there is a good deal of rust built up on the inside. i was just wondering what could of caused the rust to build up, because it wasn't just inside 1 of the chambers, it was inside all 4.
also, i bought this car used about 2000 miles ago, should i replace the spark plugs?
Rep Power: 294 Rust.... inside....can you explain where this is? Most of the engine is aluminum, which should not be rusting... you mean rust inside the the connection to the plug?
Rep Power: 0 I hope the previous owner didnt wash the engine compartnemt too often with a power washer. I normally just strip everything i can out of the engine. Take rags with rubbing alcohol and wipe everything clean. Now if the rust is reachable take some really fine grit sand paper and get rid of it. Just make sure nothing goes into your engine when you have the sparks out.
Prince of Persia
Rep Power: 240 yea i'm going to go ahead and take a small rag and screwdriver and take the rust off of the inside of the chamber, take the sediment out with a low power vacuum, then change the spark plugs.
Prince of Persia
Originally Posted by scansel912
How many miles are on your car?
Unless you have over 100k, changing the plugs is unnecessary.
the 100k spark plug change is Honda marketing BS IMO. I think Honda just wanted to say no major maintance for at least 100k miles. And while yes the OEM plugs CAN last that long, I found at 50k, changing them help power (it might have been the placebo effect) and MPG (not placebo effect - recorded). Not only that, but then I took them out they looked horrible. So for the $10 for new ones, I just replaced them and was done with it.
Prince of Persia
Rep Power: 240 well i went and got autolite double platinum spark plugs and did the swap. i'm glad i did because i immediately noticed that the car was more responsive to my accelleration.
i looked at the tips of the old plugs and i think there's too much fuel entering the engine kuhz the tips are really dark. is there anything i can do to fix it?
Rep Power: 0 feeling a power increase is not all in your head. I changed my plugs for the bosch 2's and it felt alot smoother and it didnt feel as if i had to press the throttle down as much to get to the speed i wanted. And for everyone who says that you dont need to change your plugs until 100,000 miles, you really should look at a plug at 50,000 miles. It isnt pretty, so take that and multiply it by 2. "yoshiemaster" i would suggest changing your plugs. It is a relatively cheap change and you will not regret it. Unless your like my idiot friend and left the plugs out and went to lunch. A bunch of **** went into his motor and the genius did not even check. we all know the result of that one... BOOM!
Prince of Persia
yea i changed the plugs. didn't cost me much and it gave me sumtin to do. the only thing i have a question about is how to regulate how much fuel enters the engine because my spark plug tips were pretty dark, which means that too much fuel is entering.
99% of all cars made today run rich for safety reasons. If your cars runs lean... well it won't run to long; but if it runs rich, you'll waste a little tiny bit of fuel. And the cars runs extremely rich during cold startup. So between these two things, your plugs will look pretty nasty by 50k miles.
Edit to say if your car runs lean, it won't run to long
Prince of Persia
Originally Posted by Jrfish007
99% of all cars made today run rich for safety reasons. If your cars runs lean... well it run to long; but if it runs rich, you'll waste a little tiny bit of fuel. And the cars runs extremely rich during cold startup. So between these two things, your plugs will look pretty nasty by 50k miles.
Prince of Persia
Originally Posted by cwo715
NGK Iridium plugs and use anti seize on them plugs.. can the plugs come out or are they rusted in too?
no i got the plugs out easy. i put anti seize on the douple platinum autolites.
Rep Power: 787 do you mean the burnt areas of the coil? i think thats normal. i dont believe there would be any rust. plugs are cheap, and for the money i sleep better knowing im getting the most out of an already anemic engine. $8 a year isnt that bad.
Heres a picture of my plugs when i took them out at 90k..
Is the rust you're talking about where it's white and says Denso and the plug part number?
http://www.gts4.com/plugs/all4/medium1.jpg
Originally Posted by 02BLKCIVIC
So no cause for concurn?
If it looks like the picture ctx linked to, no cause.
Prince of Persia
Rep Power: 240 listen guys, it wasn't on the plug...... alright so you know that tube that you had to put your socket wrench into in order to get the plug out? it's the same "tube" that the plug is sitting at the bottom of. well the rust i'm talking about is located on the walls of that tube.
Well rust in that area, sounds screwy to me... is it lots of rust? That area is sealed it really shouldn't have water in it.....
Prince of Persia
Originally Posted by gearbox
ya all mine have that. its scorch marks not rust. why does it matter anyway if everythings working.
ahhh, ok that makes sense. i was just wonderin what caused it.
mistahlorax13
21
11-18-2015 12:47 PM
HondaChevy
06-28-2010 10:02 PM
xproductionz
09-09-2004 11:04 PM
