Where is all my gas going!?!?
#61
Rep Power: 278 02 Civic EX 5speed Coupe. 38k.
Scangauge tells me that I average 34.1MPG. That's pulling a nice hill twice a day. IF I could cruise, windows up in 5th gear at 65MPG, NO hills.... 42.8MPG steady. It can do it, but any grade or hill will drop MPG. Worst I get is 22MPG pulling hills, 4th or 5th gear make almost NO difference going up a hill. Coasting.... 105MPG, 0.3GPH fuel consumption. Coasting in neutral.... 152MPG, 0.2GPH fuel consumption. That's coasting at 65MPH.
Interesting stuff. I have already learned how NOT to drive. Aircondition sucks up 2MPG average. Not as bad as I thought. SO I'll use it more often when it's hot. OH, VERY important: I run 45PSI tires. Max 52psi rating.
My next experiment will be to log mileage by Octane to see if it makes any difference. All readings are Freeway under nearly identical conditions. So this will take a bit.
Current fuel is chevron regular.
#62
Autocross Junky
Rep Power: 356 I've been driving that for the last 5 years... on the highway with my 01 EX (100,000 + miles on it now too) I average some where between 36-42 MPG depending on how long I run at 80+ mph. when I cruze at 70-75 I ushually end up with a quarter tank left when I get home.
in town, I get about 30 mpg.
#63
Dain Bramaged.
Rep Power: 0 One of the biggest factors in mileage is the specific energy density of the gasoline you put into your tank. Here in Tarrant (And Dallas, and Denton, basically DFW area) county, the gas in all the pumps is a mixed blend, usually with something like 15% ethanol. That mixture has a lower specific energy density, thus making your mileage and power drop significantly. I know people that drive up here on one tank from Corpus Christi, but have to fill up on the way back.
#64
DOHC i-VTEC TiMEX
Rep Power: 338 I'm getting about 28 mpg driving mostly hwy ... or about 26 mpg mostly city w/ my k20 ... not -too- bad ... with my d17, I used to get about 32-33mpg hwy. I don't know why it was so low ... -_-;
#65
Official Wish He Knew It All
Rep Power: 218 My car is just under 27k, and it is slowly starting to get better gas mileage...I mean....i do sometimes drive like an animal....lol.....but, i have gotten 400 miles to tank once....which was amazing....I love that feeling......
#66
1 Post
Rep Power: 0 i'm starting to get depressed, I've never seen 40, I get 27-32 or so (with agressive back road driving). With all highway, I recently got 35.xx. I dunno about some people getting 50+, seems a little redic but they got BS called allready. *sigh* I guess thats what happens you live in a city- stop and go all the way home.
#67
Dain Bramaged.
Rep Power: 0 It's not the heat in Las Vegas that helps. Think about it.
What three things are required for an internal combustion engine to function? Fuel, Oxygen, and Fire, right?
Well, hot air has a lower density than colder air. It also has less oxygen than cold air. If anything, hot weather hurts your mileage.
HOWEVER it's the humidity that helps. When the air contains less water vapor, it contains more oxygen.
In conclusion, a cold, dry day at sea level is the most efficient atmospheric conditions possible.
#68
Rep Power: 290 It's not the heat in Las Vegas that helps. Think about it.
In reality
The engine uses a lot of fuel to get to operating temp!
#69
Rep Power: 0 I just got back from Kentucky. I had to drive from Lexington to San Antonio. It took me about 19 hours with minimum stops and driving at least 10 over the speed limit except in Arkansas. My gas mileaged ranged from 35 to 38.5 ,pg, but I have the non-vtec D17A1 motor in My 04' VP. It's a 5-speed, but it's not that bad. I wish I could get the mileage of my girlfriends EX sedan. She still averaged 38 mpg in the desert of New Mexico with the Ac on and she has an auto. I do have one question. How come the fuel light comes on with 3 gallons left to go? I think it must be a Honda thing because the fuel guage on my 06 VFR800 is equally pessimistic
mistahlorax13
21
11-18-2015 12:47 PM
tropicola
09-25-2015 07:02 PM
NaturalSelectio
09-06-2015 06:59 PM
