drain 1st quart = cleaner?? - Honda Civic Forum
Old 07-16-2006
You bought a used dog??
def01tones's Avatar
def01tones will become famous soon enough
a coworker of mine has a SWEET TT 300ZX, and he says after he drains all of the old oil out, he pours his 1st quart in and just lets it run through the engine and back out. he said that it will get more of the old oil out. what are ur thoughts bout this???
def01tones is offline
Old 07-16-2006
Hoosier282 is an unknown quantity at this point
Your basically wasting a quart of oil. You might get like a little bit more out then you would just letting it drain normally, but frankly if you just let it drain it is just fine. If you want to clean your oil system out there is a good product called Sea Foam which cleans your system out good. It is worth the buy and you dont have to waste a quart.
Hoosier282 is offline
Old 07-16-2006
New Mod on the Block
Rennen's Avatar
i pour a 1/4 quart to rinse out w/e old oil is left.
Rennen is offline
Old 07-16-2006
def01tones's Avatar
u do this with the new oil filter on? old filter on? or no filter?
Old 07-16-2006
Rennen's Avatar
i do it with the old filter. idk... it may do nothing, but i put about 3 and 3/4 quarts of oil in my car, so i'd have a 1/4 left over if i didnt use it to wash out the motor.
Rennen is offline
Old 07-16-2006
ctx66 will become famous soon enoughctx66 will become famous soon enough
I'm guilty of doing this in the past. But now, i just run my engine before i change the oil so that all the crap at the bottom of the oil pan gets suspended and should drain out with the oil.
ctx66 is offline
Old 07-16-2006
skipbarber's Avatar
this wont do anything...the engine gets lubricated a number of ways, all of which work when the engine is running. dumping a quart of oil in there isnt going to go through the entire block, it'll simply fall, almost vertically back to the pan.
skipbarber is offline
Old 07-17-2006
def01tones's Avatar
thats exactly what i was thinking. i bought an extra quart for nothing...hoe well.
Old 07-17-2006
Jrfish007's Avatar
yup, doesn't do much..... however I do it. Usually the car takes 3.7 quarts or something like that, so I use the 0.3 quarts from the last oil change and dump it in, the first little bit the comes out is black looking, but that about it.
Jrfish007 is offline
Old 07-21-2006
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
I buy 6 packs of Mobil 1 so, so with ever 2 packs I get a free oil change with the 4 left over.
DaddyFatSacks is offline
Old 07-21-2006
DOHC i-VTEC TiMEX
aznboysrfr's Avatar
he let's it run through the engine? ... like when the engine is running?
aznboysrfr is offline
Old 07-22-2006
Jrfish007's Avatar
No, just when he changes the oil, before putting the plug back to fill the engine up, he puts an extra quart through it. The engine is not running or anything... I hope.
Old 07-22-2006
diskreet's Avatar
If he turns the engine on with the oil drain bolt out we will all hunt him down and kill him for his stupidity.
Not nearly as bad as the SR(etarted)T-4 driver who thought green cleaner would be good inside the engine to clean it.
diskreet is offline
Old 07-22-2006
DOHC i-VTEC TiMEX
aznboysrfr's Avatar
yeah. another srt4 guy who couldn't get his drain bolt out, so he took his oil filter off and started his car to drain out the oil from the filter hole. yup.
that's why I asked.
Munzy
7th Generation Civic
21
10-07-2015 08:48 AM
Raiool
10-01-2015 11:42 AM
jackoncruzpr
09-29-2015 08:59 PM
ThatGuy913
09-28-2015 06:35 PM
BBrosario
09-17-2015 08:51 PM
Quick Reply: drain 1st quart = cleaner??
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
