View Poll Results: what oil filter do you use
Honda OEM
224
36.78%
Mobil 1
96
15.76%
Fram
174
28.57%
Bosch
18
2.96%
K&N
82
13.46%
STP
15
2.46%
Voters: 609. You may not vote on this poll
poll: what oil filter do you use?
#182
Re: poll: what oil filter do you use?
I've used the following:
Honda OEM (Made by FRAM)
Quaker State by Sopus
FRAM (Orange one)
They're are all pretty cheap filters. Honda's OEM is a FRAM but cost more than the orange FRAM.
FRAM (Orange one)
#183
Rep Power: 787 Re: poll: what oil filter do you use?
ive tried K&N a few times (too pricey), used to use oem for a while which was prolly a bad move but oh well, now using napa gold. maybe next time i will try mobil1 since i think our store carries em now.
#185
Rep Power: 209 Re: poll: what oil filter do you use?
I use Fram TG I like the media inside, if not Fram TG then Hamp. I use Valvoline Semi-Synthetic 5w30 for now. When I swap or turbo I will flush the system and switch to Eneos 0w-30. Best oil out there pricey but the best.
#186
Rep Power: 0 Re: poll: what oil filter do you use?
I use Honda OEM S2000 filter part #15400-PCX-004 ($9.12) or the K&N part# HP-1004 ($12.99) in my 6th gen 2000 Civic EX, and 5th gen 2000 Prelude TypeSH.
#188
If you cut open a FRAM the insides are held together with a cardboard frame that gets broken down by the hot oil.
I use purolator pure 1, they are all metal, have a better capacity for contaminants due to more filter media, and low oil pressure increase. everything you want in a good oil filter. oh, and the valve that stops the contaminants from falling back into your oil pan when engine shut off, also made of metal with a better seal than alot of the competition.
also, highly recommend Esso XD-3 oil. it's a class 4 synthetic available for the price of most class 3's. Very good stuff for all conditions. I have used in 97tercel, 91civic, 90silvia, everything from high mileage to high HP.
#189
Rep Power: 213 Re: poll: what oil filter do you use?
Yup^
reason i use Wix, diaphragm is crap on FRAM filters!!
if you open up a WIX youll notice the way its put together kills the FRAM.
I trust and use WIX and will continue to do so, same with using RP for my choice in oil.
#190
Honda OEM
Honda has been running commercials in my area with a catchy slogan:
"If it isn't a genuine Honda part, it shouldn't be part of your Honda"
I guess advertising works
#193
You VTEC...I-VTEC
Rep Power: 232 Re: poll: what oil filter do you use?
oil filter? who uses one of those? just duct tape the hole shut and forget about it
whats the diff between s2000 oem and civic oem? in theory they would be the same
#194
I'm still using Mobil 1. I don't have an EM2 anymore but My 07 Si coupe still takes Mobil 1's oil. 5w30. AND a Mobil 1 oil filter. My Si STILL takes Mobil 1's M1-110 oil filter.
#195
My last oil changed I swapped over to high performance synthetic, and a Fram oil filter.
#203
throw out ur FRAM. just cut mine open 2 oil changes ago and it was **** construction... it had soooo many less pleats than any other filter i found and my oil was always dirty...
I run Bosch or K&N... way better construction and filtration.
and the same price.
and the same price.
#207
fram is definitely over rated garbage that people buy for some reason . if i could find it i would definitely use amsoil products they really are the best but there not easy to find so i use royal purple with synthetic micro glass royal purple filter.it filters at 25 microns
#208
i would use amsoil if it werent so crazy expensive. fram is all marketing hype and advertisement, and its cheap thats why people buy it. i had people come in all the time for oil change supplies and 90% always asked for the fram filter. and if you turn the box over, the filtration rate is a measly 94%
