valvoline oil - Honda Civic Forum
LinkBack Thread Tools Search this Thread
Old 12-21-2005   #1
herroherror's Avatar
herroherror is an unknown quantity at this point
valvoline oil
I got my oil changed about 5 months ago at Valvoline with synthetic oil. The window sticker they gave me says I need to change it on 08/06/2005 or 19663 miles. My car has about 20,100 miles now but I hear synthetic oil can last for 5000 miles. Should I change my oil now or should I wait til 5000 miles?
Also I havent driven the car for 4 months because it was uninsured while I went to school.
herroherror is offline   Reply With Quote
Old 12-21-2005   #2
bluestreak's Avatar
bluestreak is an unknown quantity at this point
change it, you shouldn't let it sit in the for more than 3-4 months
bluestreak is offline   Reply With Quote
Old 12-21-2005   #3
Jrfish007's Avatar
yup, change it because it sat for so long. Synthetic is fine for well over 5,000 miles, but letting it set for so long is bad for it's pH.
Jrfish007 is offline   Reply With Quote
Old 12-24-2005   #4
liliechen is an unknown quantity at this point
Just change it anyway, cause you can't really judge just by the milage, if it's back in aug since last oil change, i'll change it right away.
liliechen is offline   Reply With Quote
Old 12-24-2005   #5
teg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trusted
synthetic oil does not last 5000 miles, anyone who says it does is lying, change all oil 3000 miles if u want your engine to last
teg91ls is offline   Reply With Quote
Old 12-24-2005   #6
aoar is an unknown quantity at this point
syn does last 5k. www.bobistheoilguy.com
aoar is offline   Reply With Quote
Old 12-25-2005   #7
CivicSF's Avatar
CivicSF should not be trustedCivicSF should not be trusted
not at WOT driving. 3000 miles if you step on it. maybe even sooner.
CivicSF is offline   Reply With Quote
Old 12-25-2005   #8
lc20 in oil = 10k miles
gearbox is offline   Reply With Quote
Old 12-25-2005   #9
chrisleecool's Avatar
change it (like everyone said, it's been sitting too long)
I change my Regular oil every 5~6k miles and I heard it is totally fine to go that much
chrisleecool is offline   Reply With Quote
Old 12-25-2005   #10
I love to suck t3h c0ck & am supr ghey
i8dabomb's Avatar
i8dabomb is just really nicei8dabomb is just really nicei8dabomb is just really nicei8dabomb is just really nice
the oil may last but what about the chunks of metal flowing in it?
i8dabomb is offline   Reply With Quote
Old 12-26-2005   #11
Jrfish007's Avatar
Quote:
That's why I change my oil at 1,500 miles. Since their "magic break in stuff" is actually just moly, if you pick up an oil that has a high moly count, you will be fine. It sounds wierd but, use Valvoline Max Life if you want to change your oil sooner than 5,000 miles, it has 5 wt% moly in it, the highest around.
Old 12-26-2005   #12
Jrfish007's Avatar
Quote:
Sure and you are basing that off what? And you have what to back you up?
Try using google and finding some used oil analysis, chack the TBN of of the oils. My dad changed his oil every 5,000 miles with DINO oil, his old car is still running, with almost 300,000 miles on it. I know plenty of people who have done that, I also know plenty of people who have changed their oil every 3,000 miles and still had their engines blow up before they get to 50,000 miles.
Old 12-29-2005   #13
ok im sorry i should have been more specific, if you drive like a grandma, synthetic will last long, but if you drive spirited, most if not all sythetic oils will be broken down and ready to be changed around 3000 miles.
Thread Thread Starter Honda Civic Forum Replies Last Post
Liqui Moly 2009 Anti-Friction Oil Treatment emich Fuel, Oil, Cleaners & Other Maintenance 9 12-11-2015 12:20 PM
How to know if oil change done correctly? SidCivic Mechanical Problems/Vehicle Issues and Fix-it Forum 17 08-23-2015 03:14 AM
Had oil changed, dash says "oil life 15%" fafa1234 Mechanical Problems/Vehicle Issues and Fix-it Forum 4 08-08-2015 06:42 PM
97 Civic Oil Plug Problem fecrni Mechanical Problems/Vehicle Issues and Fix-it Forum 3 08-08-2015 06:15 PM
Smoother A/T Shifts Through TPS Adjusment and More? Megalodong Mechanical Problems/Vehicle Issues and Fix-it Forum 8 07-12-2015 11:54 AM
Tags
2005, civic, filter, forum, forums, honda, life, max, oil, si, sticker, synpower, synthetic, valvoline, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
