too much oil
#31
Rep Power: 0 next change
hey
been busy with a car getting ready for CES in jan. drained all the oil out and filled with 3 qts. dip stick was in in the middle of 2 dots. went to start and it would turn over but no start. pulled the air box smelled fuel. pulled sparkplugs and they were covered in oil. cleaned in reinstalled(will replace). started it and some blue smoke from burning oil in the cy l. o well lesson learned
#33
Rep Power: 294 humm... oil blew past the valves, should be okay, just make sure the car isn't eating oil for the next few weeks/months.
#35
Rep Power: 0 Well.... Normaly you need 3.7 quarts. Try to not go past the max!
I don't know if the min and max indicator on oil deepstick is for low temperature or for the engine operation temperature. Somebody know? This is also good to keep in mind!
#36
Crayons taste like purple...
Rep Power: 263 you can check oil @all temps...its tranny that needs to be warm and shifted through all gears then shut off and checked.......
#38
Rep Power: 0 I just have the 70000 mi service at a Honda dealer. In the aperwork they specified: 5-20 CHEV Oil.
I gues is a Chevron oil. So what is special about "honda oil"? Is realy a Honda Motor Oil or is just a myth? Is the honda motro oil made by Chevron? I don't whant to go too far with other expressiond like: use Honda .....
Any comments?
Any comments?
#39
Rep Power: 787 usually they have a bulk container of oil could be anything. my old dealer says it was castrol. but yes there is an oil bottled with the honda graphics and everything.
#40
Any comments?
Any comments?
Well, I'm going to guess Honda doesn't make any oil. But, they can make certian things about the oil specific to their cars. For instance, if you look at the filter, it says Fram. So everybody instantly think Honda's filters are just rebadged Frams. This is not the case though, Honda actually had Fram put about twice as many pleets in the Honda filter than the Fram filter you go buy at Walmart. My point is that it may have some special properties specific for Honda's, even if it is made by someone else.
The real question is how special are these properties? That I really don't know. Here's what I do know, Honda oil is a synthetic blend oil and the TBN on it last about 4,500-5,000 miles before dropping. This is the typical range of any normal blend oil. I personally just use a normal dino oil and go about 4,000 miles on that, I plan on doing a oil analysis on my '06 civic with Valvoline (just the normal stuff) once I get to the proper milage.
#41
Rep Power: 0 THX for info. Probably this is the case. My doupt was that the honda dealers are independent companies and they are not in a chain. I try to obtain the service history for my car I brought used, but the dealers are not connected so they dont know the history. This was one of the reason to think, maybe each dealer try to buy bulk oil or other stuf from where is cheaper and honda fixes just some standards. Or I am wrong.
I did the change at the dealer because of the miserable weathe (+ service time). I have a Mobil 1 Clean 5000 (5W-20) ready for the next oil change, what I will do by myself.
emich
12-11-2015 12:20 PM
SidCivic
17
08-23-2015 03:14 AM
CdnRD
08-21-2015 11:42 PM
fafa1234
08-08-2015 06:42 PM
fecrni
08-08-2015 06:15 PM
