oil drain bolt washer ?
Old Dec 4, 2005
mrDFWmechanic's Avatar
well i was curious about this cause for the past few months i worked at a shop and everytime anybody changed oil they change the drain bolt washer regardless. and just doing that for months on cars i do that now everytime i change my oil or anybody elses. is anybody else like this or am i just a wierdo for having 12 honda drain bolt washers sitting in my toolbox
Old Dec 4, 2005
CraigW's Avatar
I change the washer each time.
Old Dec 4, 2005
lindermant's Avatar
lindermant will become famous soon enoughlindermant will become famous soon enough
I picked up 30 of them a while back (parts counter had them for $.05 each) - 10 for my civic, 10 for my odyssey, and I gave 10 to my neighbor for his accord...
Old Dec 4, 2005
robbclark1's Avatar
Retired suspension supermod.
I changed my oil for like 40k with the same washer and not a single problem.
Old Dec 4, 2005
civic01vtec's Avatar
I have 60k on my car with the same washer.
Old Dec 4, 2005
civicvtec1ps's Avatar
Search and Learn
It is recommanded to change washer.
Well, I do it anyways, It's cheap.
Old Dec 4, 2005
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
I never change them, never even use a torque wrench.
I have also never stripped the threads or cracked a plug.
Never had a leak.
I think it's just them being overcautious.
Old Dec 4, 2005
Jrfish007's Avatar
It's a crush washer, it's suppose to be replaced. But if you are working at a shop and they don't replace it, and the oil starts leaking from there, guess is gets to pay for a new engine. 5000 washers are probably cheaper than 1 engine, so really it's just the shop protecting them selves. Do you have to replace it, I don't know, I do because the dealer gives to me for free when I buy a filter from them, and they have a deal where you buy 2 fHonda filters you get one free, so it's pretty cheap.
Old Dec 4, 2005
streetglower's Avatar
I always use a new washer each time. I have a crap load of them in my tool box.
Also at our shop, we have a spare case with drain plugs for each vehicle and several styles of washers. If a car has a washer when it comes in, we reuse it, but if they dont have one, then we put one on there.
Old Dec 4, 2005
robbclark1's Avatar
Yay for fumoto...no need for washers!
Old Dec 4, 2005
Sick Cycle's Avatar
Sick Cycle is an unknown quantity at this point
does the fumoto ever realistically pay for itself in terms of 5 cent washers though? ;PPP
Old Dec 4, 2005
taehoshi's Avatar
taehoshi is an unknown quantity at this point
where do you find these washers?
oil sump drain washers arent all standard, right?
Old Dec 5, 2005
you can get the washers at the dealership for really cheap. I bought like 10 for a buck.
Old Dec 5, 2005
whenever i pick up parts from honda i usually get a few extra washers as well
Old Dec 5, 2005
robbclark1's Avatar
No it pays for itself by directly draining into a laundry detergent jug and having little to no mess! That is the true savings my friend...
Old Dec 5, 2005
skipbarber's Avatar
i always replace it. no reason not to.
Old Dec 5, 2005
Sick Cycle's Avatar
I never have a mess anyway, u oil changing newb.
hehe jk
Old Dec 5, 2005
robbclark1's Avatar
hehe jk
I do when I live in a townhouse complex and have to clean out my oil pan everytime because I have to store it on my porch. Sucks, but now fumoto is my new best friend. Damn the crush washers! Damn them to heck!
Old Dec 5, 2005
DDragon7's Avatar
...I tried changing my oil today and I couldnt get the bolt off... Then I gave up for the winter, its getting too cold.
Old Dec 5, 2005
Sick Cycle's Avatar
^ use an open end wrench, tap the other end with a hammer.
Old Dec 5, 2005
DDragon7's Avatar
Was afraid to strip it, since my dad said it could, but next time, I'll try that... probably in the spring or if it gets warm enough before the oil reaches its time.
Turn it to the left, rite?
Thx.
Old Dec 6, 2005
Sick Cycle's Avatar
lefty loosey, righty tighty.
it's hard to strip it if you have the correct sized wrench ... unless the person who put it on last put like 300 ft/lbs of pressure on it.
Old Dec 14, 2005
Blackpearl's Avatar
Blackpearl is an unknown quantity at this point
Every time change the washer.
In old times the washers where made from copper. Now is cheap aluminum.
The copper ones can be used again if you heat them up to the point that they geting red. Cool the slowli and the result is a mor softer copper. Better for environment .
LionSpratt
Jan 29, 2017 11:07 PM
RIPSAW
Nov 6, 2015 04:36 AM
trellex
Electrical
Jul 9, 2015 12:01 PM
silverdevil
20
Jun 2, 2007 04:42 PM
Grey
16
Jan 27, 2002 11:34 PM
