Gear problem
Old 05-13-2017
Yehya's Avatar
Yehya is an unknown quantity at this point
Gear problem
I have changed two gears (Bmxa) for my civic 2004 coupe, american made, up till now from a month, but both gears have a common problem only at the morning, the gear gives some kicks, after i drive for about 10 km everthing comes normal wihtout any kids.please help what is the problem.
Old 05-14-2017
Dr Krieger of Modification
mac25's Avatar
Re: Gear problem
...You posted in "Suspension Performance"...
is this a Suspension question? If so what gears?
or is this a transmission issue? If so, manual or automatic?
Old 05-15-2017
Yehya's Avatar
Re: Gear problem
It is an automatic transmission gear, i thiught suspension is the same as transimission .
anyway hope anyone help, cause some are telling it is the computer board in the car must be replaced .
Old 05-15-2017
mac25's Avatar
Re: Gear problem
Who is saying it is the ECU, a mechanic you went to?
Old 05-16-2017
Yehya's Avatar
Re: Gear problem
Yes a mechanic, they say he is a specialist in automatic gears, but iam asking you as an experts : what is the cause for such problem, so i fix it.
Old 05-17-2017
Re: Gear problem
Sounds like your trans has, or still has, a problem.
Any reputable shop will give a warranty on their parts and workmanship.
....I suggest you need to return to the mechanic that did the work to fix it as a warranty repair.
