Auto Transmission Rebuild (pics)
Old 08-16-2006
  #31
Mike04Civic's Avatar
Mike04Civic is an unknown quantity at this point
so i was lookin at the TCI website, im thinkin bout getting the over-haul kit. its says 2001-2002 civics, im assuming it'll fit the 2004's as well?
and it doesnt have prices, how much did you pay for it?
Mike04Civic is offline
Old 08-16-2006
  #32
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
Originally Posted by eye_see_you
the clutch disks are small and as far as the rpm it is not increased unless you got the TCI torque converter
if u looked i said wat is the rpm increase when upgrading the tc(torque converter) with level ten stage 2 upgrade? eh its a simple mistake pplz make...no biggy. i do remember hearing them say the rpm increase but that was awhile bak when i got the tci upgrade kit several months ago.
mike04civic: if your askin me i got it thro Civicmexicano(hope i spelled it right) way bak for i believe $250 w/ stock tc. i think the kit is about $300-$400 for the kit and $400 to upgrade your tc. you can go to level tens website nd they have prices. www.levelten.com
crazyasian is offline
Old 08-16-2006
  #33
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
I paid 218 Shipped from http://www.lonestarracing.com/cgi-bi...CI-559100.html
Is your 04 tranny starting to slip? I would call TCI and ask them if it will fit your tranny.
dopes6070 is offline
Old 08-16-2006
  #34
i thought the stall rpm was raised by 500 if i remember.
gearbox is offline
Old 08-16-2006
  #35
nahh, not yet - but when it starts im deffinantly getting it + a torque converter
Old 08-16-2006
  #36
I am not familiar with the TCI torque converter because I am not going to be putting it in this car since my gf doesn’t really care... she just doesn’t want it to feel like its breaking anymore HAHA
Old 08-16-2006
  #37
i just did another fluid change and it felt better again. it only lasts for a few thousand miles tho and then goes back to shifting harder and all the suckiness. i remember a mechanic saying the fluid should be changed with every oil change and that it needed a cooler and external filter to operate properly. im like great why couldnt honda do this. so far ive been trying to change fluid every 10k, it seems like enough but remember its barely only 3 quarts and that is maybe 1/3 of the total fluid. i feel like i should be doing it more often even like every 5k. the fluid is only $25 and its maybe an hour or two job if you work slow. hardest part is driving it around and adding fluid once its warm.
gearbox is offline
Old 08-17-2006
  #38
KINGCHILE's Avatar
KINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to all
check out jmo racing if your interested in the torque converter.
KINGCHILE is offline
Old 08-17-2006
  #39
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
ugh i had to learn about that in class i dont know how u do it or how u had the patience to learn this...i was so lost...wait i still am
boxcarracer is offline
Old 08-17-2006
  #40
It seems that you would probably benifit from the external filter if your fluid gets bad that fast. I will post pics of the filter + cooler install this weekend. Im hoping with the filter I wont feel bad leaving the fluid in there 15k miles. (I was doing 10k changes too)
Old 08-17-2006
  #41
also when i went to clean the drain bolt, there was alot of black sludge on the magnet that i wiped off. looked like liquid metal almost. and thats after i put some LC20 in there. usually the plug is pretty clean so maybe i got some of the gunk outta there.
gearbox is offline
Old 08-17-2006
  #42
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
My favorite auto tranny was the Jatco 3n71b. Put almost 300k on it, a breeze to rebuild, and built like a russian tank. And it ONLY needed the clutches replaced. That would have been my Mazda RX2. And to top it off, I drove it like I stole it every day.
After looking at the pics of the civic tranny.... no wonder.... the clutches are TINY.
tinman is offline
Old 08-17-2006
  #43
yes they are, even smaller then a CD...
Old 08-17-2006
  #44
This stuff will be installed saturday. I dont think I like the zip tie method of mounting the cooler so Im gonna be looking for another way to mount it.
ID:	67612   Click image for larger version
Old 08-17-2006
  #45
heres how i did mine and its been fine for a year now.
http://gearbox.shmikx.net/Transdiy.htm
gearbox is offline
Old 08-17-2006
  #46
RHCP0801's Avatar
hey gearbox do you mind sending me a link where you got the tranny cooler from? because i know only certain ones will fit and i dont want to get the wrong one, thanks
RHCP0801 is offline
Old 08-17-2006
  #47
well it doesnt really matter. actually i threw away my box so idk which one i even have, just get a smaller one. mine looks exactly like the one posted above. you can get a bigger size but just make sure its not any thicker than about an inch or so. if they even make thicker ones. its a B&M supercooler that i bought of enprocesso.
gearbox is offline
Old 08-17-2006
  #48
The one I got is actually 1.5" thick but I’m going to be putting it in front of the AC condenser so I’m not concerned.
Pretty much the same way Boiler put his engine oil cooler.
http://www.7thgencivic.com/forums/sh...=v8+filter+oil
Old 08-18-2006
  #49
the only reason i couldnt do that is looks because you can see it through the bottom grill holes.
gearbox is offline
Old 08-18-2006
  #50
RHCP0801's Avatar
i can probably put it there because i have that billet aluminum lower grille on my aero kit. So basically your saying any cooler that is around 1-1.5" thick and length doesnt matter will fit?
RHCP0801 is offline
Old 08-18-2006
  #51
I don’t know if you would want or need to go that much bigger. Our car is small so the transmission doesn’t make as much heat as larger heavier cars. If it’s too big I would think that the transmission would never get to optimal operating temps.
Old 08-18-2006
  #52
RHCP0801's Avatar
do you approximatley know how long your cooler is?
RHCP0801 is offline
Old 08-18-2006
  #53
its about 11" x 7" x 1.5"
Old 08-18-2006
  #54
RHCP0801's Avatar
ok thanks
RHCP0801 is offline
Old 08-19-2006
  #55
The filter and cooler are installed after about 3 Hrs of work and 2 trips to Autozone. Even though it looks like the hose is rubbing going from the filter to the cooler, it has about 1" of clearance all around it. I also had to buy a bunch of fittings just to get a 90 degree 3/8" hose barb going from the filter adapter. Its not as nice looking as Earls fittings but they work with no leaks.
ID:	67624   Click image for larger version
ID:	67625   Click image for larger version
Old 08-19-2006
  #56
lookin good. i just bid on this from ebay.. (nobody else better bid on it! lol)
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEBI%3AIT
gearbox is offline
Old 08-20-2006
  #57
Between the filter and coler the car holds about 1.5qt more ATF so it will stay clean longer. Like 5000 miles after I put the new tranny in im gonna replace the filter and cut this one apart so I can see how much crap is inside.
Old 08-20-2006
  #58
do you know if i can use this filter thing to clean the tranny to maybe make the slipping better? where exactly did you install yours, is it just on the cooler line? and which one does it matter even?
gearbox is offline
Old 08-20-2006
  #59
well they say in the instructions to have it before the cooler so i put it like this.
Trans - Radiator - Filter - ATF cooler - Trans
I will let everyone know if this helps the slipping on her current trans. the only way it would help slipping is if the pressure in the trans was dropping from a clogged ATF screen (which it could be). If your clutches are already worn then its beyond help
Old 08-20-2006
  #60
just wondering did you read my diy, and did i have the correct lines for outgoing and return from the trans?
gearbox is offline
Quick Reply: Auto Transmission Rebuild (pics)
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
