Rear strut removal DIY
The following users liked this post:
Bryan Sibert (05-30-2020)
Received 1,440 Likes
Rep Power: 338 Re: Rear strut removal DIY
thanks for your help to the community!
HAHAHA
I know, lame, but the only DIY up had busted pics
Once I saw how easy, yeah, lame post
the trick is putting a 10mm deep well socket on a floor jack to push on the eye and compress it the last inch and get the eye bolt in
Also, when the seats are down, there are a pair of access panels that pop out to get the forward nut onto the struts stud
That is all good citizens
Grey hair
1 Post
Rep Power: 0 Re: Rear strut removal DIY
I should have made another DIY on how to do it to a car in the rust belt. First how the head of the lower mount bolt snaps off because the bolt is seized into the bushing sleeve. Then how the welded on nut gets cut off with a angle grinder because the bolt is also seized into it. We move to the trunk to get the upper nuts which appear to be in excellent shape, this should be easy.. Right. 3 came off easy and one stripped instantly requiring the air chisel to get medieval on it. That leads us to the now still stuck in the bracket bushing. Of course the angle grinder makes yet another appearance to cut off the bushing shell to get at the inner sleeve, I love the smell of burning rubber bushing BTW. And for the finale the angle grinder again doing it's magic on the sleeve and the remainder of the bolt. Add some hammer, big pry bar and a BUNCH of choice words and it's done. Well almost because in all the excitement you also managed to look the wrong way at the little metal brake line that goes into the wheel cylinder and it starts leaking... Of course anyone who has worked on rusty Michigan brake lines knows this story, might as well go all the way to the prop valve because as soon as you touch one line and start reefing on it to loosen it a leak will appear somewhere else up the line....
gnostic19
12-13-2015 04:21 PM
galaga3
05-30-2002 05:32 PM
