Headgasket replacement parts list
#61
Received 1,146 Likes
Rep Power: 485 Re: Headgasket replacement parts list
for sure man. Good luck with your HG job. Hopefully you don't run into what happened to me back in October
#62
I hope it doesn't happen to me either! I can't afford another car, if I can barely afford parts for this one!
Parts come sometime tomorrow. Head is coming off tomorrow too, and hopefully the machine shops in my town don't suck!
#63
Rep Power: 0 Re: Headgasket replacement parts list
So the parts list here and a tensioner bolt should be the only things needed to do this job properly. I've been reading a lot on head gasket replacement the last few days and I know I read somewhere that the bolts/studs should be replaced, but this thread says they don't need to be.
I'll be taking the car to a shop to have this done I just want to make sure they replace and do everything that needs to be done. I'd rather spend a few more dollars on parts/labor now than have to have the job done again in a year or so. The timing belt was replaced less than 30k miles so I'm not sure if I should spend the extra money to have that done too or just leave it, car has 190k on it. What sucks is the place I bought it from replaced the head gasket and timing belt before I bought it, my guess is they didn't do a good job on the head gasket and that's why I need a new one already.
Any suggestions I should make to the the shop that hopefully won't **** of the mechanics?
#64
Received 1,126 Likes
Rep Power: 190 Re: Headgasket replacement parts list
xRiCeBoYx
61
09-04-2018 01:04 AM
Kevin_646
24
04-22-2013 10:31 AM
Speedo
10-01-2009 05:25 PM
18115plcj01, 2003, 98, civi, civic, gasket, head, headgasket, honda, list, needed, parts, replacement, replacing, time
