Low beams OUT
200,000 and counting
Rep Power: 172 Low beams OUT
on my '01. I know there is a TSB out regarding this, but it was (supposedly) fixed.
Is there any other possible easy answer? (Other than busted bulbs.)
Rep Power: 787 Re: Low beams OUT
could be bad headlight harness grounds behind the front bumper on each side. they do get corroded easily from road spray. also could be the fuses or relays for the lo beams.
Re: Low beams OUT
The ground path for the headlight bulbs is made through the headlight switch not outside. The fuses and the relay(s) are common to both high and low beam operation.
Assuming you have working high beams, ? and not 2 bad bulbs...?
Inspect pin 6 RED/WHT at the headkight switch it is the low beam line that gets a ground through the headlight switch to light them.
how do you explain my lo beams not working when i had one of the grounds under the bumper disconnected.
Re: Low beams OUT
https://www.civicforums.com/forums/a...1&d=1254923682
Pin #12 of the switch to G401 is the ground path for 01-03
https://www.civicforums.com/forums/a...0&d=1267189121
https://www.civicforums.com/forums/a...6&d=1281967392
Re: Low beams OUT
Not sure if this is what you meant by TSB, but there is a recall out for Civic low beams. Apparently, some part of them can overheat causing some wires to melt...
CraigW
08-18-2015 07:06 AM
JetsterDajet
08-16-2015 01:56 PM
Doug Lassiter
08-09-2015 09:31 PM
adamdrives
15
08-08-2015 08:53 PM
alxz310
07-30-2015 12:18 PM
