2006 honda civic gauge issue
Rep Power: 0 2006 honda civic gauge issue
My name is Tony I'm from arkansas I just bought a 2006 honda civic and the temp gauge fuel gauge and speedometer doesn't work the speedometer shows 0 all the time and the fuel gauge reads nothing and low fuel light flashes and temperature stays at bottom anybody know what can cause this
Dr Krieger of Modification
Re: 2006 honda civic gauge issue
Pull it off and see if it is plugged in all the way, maybe someone tampered with it, like removing CEL, and didn't clip it back together.
Also check the fuses/relays/and grounds to the cluster.
Rep Power: 0 Re: 2006 honda civic gauge issue
Thanks I am going to try to find where the ground wires are I have the dash apart now it's all plugged in good and the gauge cluster has been replaced with a used one and does the same thing all fuses are good the miles change when you drive it it just doesn't tell you your speed I'm hoping it's something simple
Got engine fault codes?
Does engine data show VSS value correctly? How about fuel level and coolant temp data?
Got body (B) codes? Communication (U) codes?
Data bus down or offline for some reason?
Our reader doesn' do a ot but when I hook to it it won' communicate
Have you done the gauge cluster self diagnostic and function checks?
If the PCM can't communicate, that sounds like a problem that may be related and a place to start diagnosing
Did you try swapping the other part?
The speedometer part was replaced not the tach part when I do the self diagnostic thing fornthe cluster the bottom cluster does what it's supposed to the top one just sits lime it does all the time all I have is a basic code reader
Got service info? Alldata or similar?
Which part got replaced? (tach section or speedo section)
I got the other gauge cluster out of a junk yard today and replaced it and it's still the same. I started messing with the air conditioner because it doesn't work either tracking down power issues with it now the car won't start at all and has a green key light flashing
Nwengr1
05-21-2016 12:19 PM
strega51
10-03-2014 06:32 PM
