Disable the parking light feature from the front turn signals?
If the title wasn't clear enough, here's what I want to do. I would like the front turn signal amber lights (7443) to only turn on when using as a turn signal indicator and remain off during all other times (even when the headlights or daytime running lights are on). And of course I want the hazard lights to work as it should.
I really hate the ugly orange lights that are always on whenever the DRL (nice LEDs) or headlights are on. Is there a wiring modification where I can disable the parking lights so it only works when I use the turn signal switches (and the hazard button). I'm really hoping there's a way to make this possible. The amber lights are the only thing ruining the front view of my civic coupe.
Thanks a lot in advance!!
G
G
Re: Disable the parking light feature from the front turn signals?
Each one has a dim (park) and bright (turn) in the same bulb, right?
Remove/disable/cut the wire that runs the dimmer of the two bulb filaments (park) at each socket? If you do it right that should leave the bright (turn signal) filament working on each side.
(Did not look at any wiring diagrams for this guess.)
Thanks for the reply. Will take a look at it this weekend and let you know if success.
Any other solutions welcome as well.
Thanks
SUCCESS!
This was easier than almost anything I've done in my car. No wire cutting involved. All I needed was a tiny bit of plastic tape - covered the parking light wire (in the bulb) that touches the metal part in the socket.
The following users liked this post:
TokyoCornflower (05-20-2023)
That tape may become ineffective after the bulb has been hot several times. Good luck though.
I'm thinking if that ever happens I will simply trim the parking light wires in the bulb (Btw, these bulbs are $2 a pair here at the local thrift store I just don't want to cut the wires connecting the socket so I don't have to repair or replace it later when selling the car.
Thanks.
Thanks.
Or you could get some switchback LEDs that are white and switch to amber when the hazards or turn signal are activated. But you would also need an LED flasher so you don't get hyperblinking.
Had these on my 6th gen coupe and it was sexy! all white light in the front
Save
Thanks.
Thanks.
I tend to make things complicated LOL
Also, another issue - The 7443 switchback LEDs that I got turned out to be too big to fit through the hole that the socket and bulb sticks out from. Had to return the LEDs.
I'll probably go back to switchbacks if I ever figure out ^solutions.
Thanks!
very unlikely someone will see this 7 years later but in the off chance, could you elaborate how you did it? Maybe post a picture. And would it be possible with LEDs?
[/QUOTE]
[/QUOTE]
Super Moderator
Received 1,837 Likes
Rep Power: 195 Re: Disable the parking light feature from the front turn signals?
Three wires running to the connector. One is ground, one is battery voltage (cycling on/off) for the turn signal, third is constant battery voltage for the parking lights. According to my service manual, these are black, green/red (left) or green/yellow (right), and red/yellow respectively. Inside the connector or on the bulb, find a way to prevent the red wire/terminal from touching the appropriate contacts on the bulb. Would work the same with LEDs.
Either pinpoint and cut the correct wire, or as the Orignial Postered did: put a little strip of tape on the correct bulb contact (easy trial and error to make sure you have the correct one), also very easy reversal in future if need or want arises. I haven't tried it, but my suggestion would be once you do determine the correct contact, snip the bulb's contact wire (so the bulb is permanently altered but car is not) and tape doesn't gum up or wear through in time. If they are LEDs that directly plug to standard wiring it should work fine.
