Oil in coolant overflow
Old 05-21-2007
lovinthevtec's Avatar
lovinthevtec is an unknown quantity at this point
Hey, i've been boosted for 5000k stock d17a2 motor at 6psi with an ~11.5 a/f wot tune and as im tearing my car down this year i've noticed a bit of oil residue in the overflow coolant tank
I drained the coolant and it did not look milky or as if oil was mixed in there but there is (what looks to be) oil residue on the sides of the top of the tank
Whats everyone's thoughts on this? Head Gasket is what first came to mind for me but it is not smoking at all aside from a bit of black smoke when my fuel curve changes for the boost and like i said the coolant looked normal draining out of the rad?
Any input fellas?
Old 05-21-2007
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
Re: Oil in coolant overflow
i think it can be only the headgasket. how else will the oil get in the coolant. do you throttle boost a lot?
Old 05-21-2007
im not sure if i follow what you mean by throttle boost?
i was thinking either the head gasket or water jacket
Old 05-21-2007
woops. i meant partial throttle boost. water jacket? the part where the radiator hoses hook up to? that could be a possibility too. very unlikely though, never seen any of those things go bad.
Old 05-21-2007
DaRk_MauL's Avatar
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
Well i have had something go wrong to this sunday.I drove like 80 mile i stop
behind a friend and see the water temp climbing all the way up i shut down
car right away.water got out of the water reservoir next to the radiator.
ride home water temp stay normal till i have to slow down or stop at a red
light.Had heater on hot so temp stayed ok.
after checking some stuff firt so little bubbles in the radiator but after
checking again nothing anymore.
Have driven around today, alot of stop at red light everything normal
no white smoke,no coolant in the oil, temp stay normal all the time.
gonna check if their are exhaust gasses in the radiator if that ok .....
weirdest thing ever.
Old 05-21-2007
ok im not sure how that would help me but yes..have to make certain you get all of the air out of the cooling system
bump...i know there are some hardcore guru's on here....any ideas?
Old 05-21-2007
mods can u please move this to the 7thgen forced section
Old 05-21-2007
Turbo Guru
andyman97's Avatar
It sounds like it COULD be a blown headgasket. There is only one way to know for certain and that's by doing a leakdown test. You can check compression first if you want, your reading may be a little high on one cylinder if its got a leak.
Old 05-26-2007
boosted1.7??'s Avatar
boosted1.7?? is an unknown quantity at this point
yea the same thing is happing to my car it would heat up when i stoped but if i drove slow it would cool down so if you find out what is wrong please let me know.
Old 06-04-2007
Gigaloace's Avatar
Gigaloace is an unknown quantity at this point
My best guess, cracked block or head gasket. If you want to check head gasket, do a compression test. If its a blown head gasket, you'll get two low psi readings of cylinders right next to one another. If all psi's check out okay, or maybe low on a single cylinder, start to suspect cracks.
Good luck man
Old 06-05-2007
Turbo Guru
andyman97's Avatar
^Where do you get that from? A seal doesn't always blow between two cylinders.
Old 07-10-2007
DaRk_MauL's Avatar
my problem is fixed now head gasket had 2 smal spot blown between the
combustion room and water canal.It would slowely build up to much compression
in the cooling system.
that was the problem. so i would say to head gasket
Old 07-11-2007
thanks dude, im thinking that as well
blazebrown
18
06-02-2019 12:31 PM
Hqly2001
22
07-12-2015 06:44 PM
stvpagn
07-09-2015 09:59 PM
Bounddyy
07-08-2015 11:22 AM
ZILLA
07-05-2015 05:24 PM
Quick Reply: Oil in coolant overflow
