Which oil weight to use?
Old 06-30-2003
Maverick's Avatar
Maverick is an unknown quantity at this point
Just wanted to know what you guys were using.Turbo is on the way, when I install it I'll be switching to Mobil1, but wasn't sure if I should stick to same weight(5w) or switch to 15.Just wanted to know the best and what you guys are using/recommend.Thanks.
Old 06-30-2003
orso's Avatar
orso is an unknown quantity at this point
i would say staywith the same wieht and change your oil every 3,000 miles if you don't do it all ready.
Old 06-30-2003
Maverick's Avatar
i change it every 3, though i've heard with FI, you may want to do it every 2...but if you're using a synthetic, they don't break down as easily anyway. thanks for your input, leaning toward staying 5w-30
Old 06-30-2003
9K Redline Owns U
Spider883's Avatar
i would stick with the 5w30.. u cant go wrong with that
Old 07-01-2003
cool beans
zinkyroo's Avatar
zinkyroo is an unknown quantity at this point
10w-30
Old 07-03-2003
Yakkolio's Avatar
Yakkolio is an unknown quantity at this point
i use 10w 30
Old 07-07-2003
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
is 5w-20 synth too light for turbo then?
Old 07-07-2003
Premium Boosted Member
MadWheel's Avatar
"Viscosity
Viscosity (a fluid's resistance to flow) is rated at 0° F (represented by the number preceding the "W" [for Winter]) and at 212° F (represented by the second number in the viscosity designation). So 10W-30 oil has less viscosity when cold and hot than does 20W-50. Motor oil thins as it heats and thickens as it cools. So, with the right additives to help it resist thinning too much, an oil can be rated for one viscosity when cold, another when hot. The more resistant it is to thinning, the higher the second number (10W-40 versus 10W-30, for example) and that's good. Within reason, thicker oil generally seals better and maintains a better film of lubrication between moving parts." - Popular Mechanics
I woudl say using a 10W-30 would be your best bet. Also according to the site, we should stay away from full synthetic, a synthetic blent isn't too bad but I still recommend an SL blend 10W-30.
Old 07-23-2003
Hail to the king baby
kjgracing's Avatar
kjgracing will become famous soon enoughkjgracing will become famous soon enough
Amsoil Full synthetic 5w30 and a bosch filter
woorks great for me.
Old 07-24-2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
u use the stock stuff, and change it every 3000 miles. It still comes out pretty clean.
Old 11-21-2007
Green44's Avatar
Green44 is an unknown quantity at this point
Re: Which oil weight to use?
So I know the recommended oil to use for a 2003 EX civic is 5w 20... but I purchased the wrong grade and got 15w 40... and I was told that it wasn't too horrible for the car, but just be sure to not do it again and to change it in 3,000 miles. But I was wondering if it was retarded to put it in anyway. Just wanna hear some feedback. PS sorry for reviving this dead thread.
Old 11-21-2007
in cold weather, your motor will hate you.
Old 11-21-2007
sl33pyriceboi's Avatar
ur motor is REALLY gonna hate u if u put that in....so i suggest returning it...and getting the right stuff...
my car is reaching 100k so i switched from 5w20 to 5w30...and also switched to valvoline max life....good stuff
Old 11-21-2007
valvoline max life ftw. i just reached 70k miles and using that stuff in 5w20
Old 11-21-2007
^how/where did u get the 5w20? i cant find it even if my life depended on it!
Old 11-22-2007
advance auto parts here has it, i usually wait til its on sale for $1.xx per quart
brags
46
01-07-2016 09:39 PM
emich
12-11-2015 12:20 PM
Mr.Beefy
08-12-2015 04:39 PM
fafa1234
08-08-2015 06:42 PM
fecrni
08-08-2015 06:15 PM
Quick Reply: Which oil weight to use?
