02 Civic Ex 4dr tire size fit
Old 03-26-2011
kickme005's Avatar
kickme005 is an unknown quantity at this point
Can i put 195 60 15 tires on my 15" rims their hub caps? Its a 2002 Civic Ex 4 door. I got these tires free from a friend.
Old 03-26-2011
sl33pyriceboi's Avatar
Re: 02 Civic Ex 4dr tire size fit
yes you can.
Old 03-26-2011
kickme005's Avatar
will they rub? will my speed o meter be off? anything else i should worry bout when putting these on?
Old 03-27-2011
http://miata.net/garage/tirecalc.html
also, some people run 215 without rubbing...
see more info in post #2 here
https://www.civicforums.com/forums/1...rket-rims.html
Old 03-27-2011
it'll be slightly wider than the stock 185/65s (by 1cm) and it's overall diameter will be smaller by .3". You'll be fine
Old 03-27-2011
kickme005's Avatar
so it be a wider tire and a small circle than stock? what about the speed meter be acuract
Old 03-27-2011
it'll be off by something negligible like 1% (indicated 60mph on the speedo, you'l be going 59.4mph)
Old 03-27-2011
Kickyou, you did not even read the links, right?...
Old 03-27-2011
kickme005's Avatar
ok thanks i got it now
Old 03-27-2011
kickme005's Avatar
ok i was wondering what brand and model tires came on my civic from factory?
Old 03-27-2011
honda gets from at the least 3 different tire makers
one of them is from where i work.
that said, does it matter?
Old 03-27-2011
kickme005's Avatar
what the best Michelin tires for my Civic?
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
bo_red
04-23-2015 10:09 PM
tkcne
04-18-2015 02:33 AM
GH04si
04-15-2015 08:13 PM
SleepyT
11-01-2001 04:59 AM
Quick Reply: 02 Civic Ex 4dr tire size fit
