Motor Mounts issue
Old 06-30-2013
200,000 and counting
thesushiboy's Avatar
thesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the rough
Motor Mounts issue
Changing out the drivers side mount, bought this one from Autozone. Won't fit, the lip is too wide to slide into the engine mount bracket. Autozone says that's the one, period, but there is no way it fits. Are there different part numbers for coupes and sedans?
http://www.autozone.com/autozone/par...418418_0_4281_
Old 07-01-2013
Re: Motor Mounts issue
Maybe. Look it up for each car and compare part numbers. http://www.hondaautomotiveparts.com/
Old 07-01-2013
Check 5 speed and automatic too... never know, I know the rear and passenger side are different.
Old 07-03-2013
Turns out there sure is. Had the guys at Autozone check for 2002 civic, and there they were--two types, one for sedans and one for coupes.
Old 07-03-2013
Aftermarket mounts generate all sorts of vibration complaints because they are usually harder than stock. Factory mounts are softer. Choose carefully.
Old 07-03-2013
That's funny you said that. After I put this one in, just today, I couldn't BELIEVE the amount of vibration! I figured that I didn't tighten the bolts enough/engine isn't lined up properly, not sure? Going to wait till tomorrow to take it off/reinstall. Also after lurking around Honda-Tech, found this thread: http://honda-tech.com/showthread.php?t=2779057
Looks worth a try.
Old 07-03-2013
HAH.. I threw on the energy suspension polyurethane insert in my front motor mount before it tore all the way through. THAT my friend, is vibration. I don't mind it though. I never have to worry about that mount now. Just the bolts on the rest of the car vibrating loose.
Old 07-03-2013
PFffft. My first car had SOLID STEEL motor mounts.
Old 07-03-2013
Oh my.. lol.. they made them a lot smoother back then
Old 07-03-2013
Everything was cast iron.
Computers sucked back then too....We had hand cranked modems and wood burning servers.
It was a 63 Bug. Clapped out with a Baja kit, open header w/megaphone, jacked up, Desert Dog tires that would throw 20 foot rooster tails, fiberglass one piece tilt front end, it survived some 4 foot jumps, and I drove it 150 miles each way every other weekend between school and home. It lasted me about 3 years.
Old 07-03-2013
[ Everything was cast iron.
Had a '67 bug. I don't think I've ever worked on a car more often than that train wreck... Oh, the clutch cable memories... *shudder*
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
Jigee
05-09-2015 11:18 AM
MN-02-CivicEx
28
05-02-2015 09:11 PM
bsmiley
04-27-2015 01:27 PM
JoeB16
61
10-16-2003 07:58 PM
Quick Reply: Motor Mounts issue
