2004 ex tachometer not working
Old 12-08-2012
idea2's Avatar
idea2 is an unknown quantity at this point
Any ideas why the tach is not working and how might I fix it?
Old 12-09-2012
Re: 2004 ex tachometer not working
mice or squirrels chewing the wiring of the car might be a possible cause.
asking this question without even going to a shop will yield no responses in here, too broad a question.
and yeah, a friend actually had the trouble i mentioned, so it is a true statement.
Old 12-09-2012
D Murphy's Avatar
D Murphy is an unknown quantity at this point
Have you done any other work? I have seen loose alternator bolts cause this problem.
Old 12-09-2012
idea2's Avatar
About 2 months ago I replaced the Alternator. It wasn't charging the battery and the Tach..,
Speedo., Odom.... entire cluster was not working. Once the Alt. Was replaced everything
In the cluster began working again. 2 weeks ago the tach stopped workinging. The needle
does not move off zero.I did not check the bolts, I did check the belt and the belt is tight.
Old 12-09-2012
Check if it works during a gauge sweep test:
https://www.civicforums.com/forums/p...110-post5.html
Be sure to watch the linked video too.
hokiedad4
05-03-2015 10:06 PM
ORskier
05-03-2015 12:54 PM
Bigdaddy198
04-30-2015 08:36 PM
ashleymmackey
04-18-2015 09:48 PM
McD
04-16-2015 10:46 AM
Quick Reply: 2004 ex tachometer not working
