Sounds like driving over a rumble strip at low speed
Old 01-02-2012
Barb 56's Avatar
Barb 56 is an unknown quantity at this point
My daughter's 2003 Honda Civic starting making a rumbling sound intermittently when driving at low speeds (under 40 mph). Had all suspension and tire/ wheels balanced- all checks out ok. Did notice slow oil leak down 2 qts...oil light did not come on.
Any ideas? all garages seem to be closed today for the New Year.
Old 01-02-2012
SpdySylvrEX's Avatar
SpdySylvrEX will become famous soon enough
Re: Sounds like driving over a rumble strip at low speed
I assume it goes away at higher speeds? Is it a rumble sound or feeling?
down 2 qts
That is almost more than half, Hondas only take 4 qts. The VTEC will cause this type of feeling when the oil is low. But it will more than likely shake the car violently than anything else.
Old 01-02-2012
Barb 56's Avatar
filled oil level....still has the rumble strip sound...
no violent shaking, so what else might it be?
Old 01-02-2012
sound or feeling?
your initial post says "feels like driving over rumble strip"
Are there any codes?
Old 01-02-2012
Barb 56's Avatar
No check engine lights came on
Old 01-02-2012
Does the car only do it when it is rolling down the road? does it do it while it is idling?
Old 01-02-2012
Barb 56's Avatar
Just when driving at low speeds and intermittently.
Old 01-02-2012
lazlong's Avatar
Does it do it regardless of whether you're accelerating or coasting? Does it seem to vary with engine or road speed? If so, which one? Can you feel it in the steering wheel? In the meantime, check for any play in the axles and all suspension/steering components.
Old 01-02-2012
I would physically take the tires off and shake each individual component of the suspension. IF something feels loose, tighten it up.
Start the engine and physically watch it to see if it shakes to much. It just sounds like something is loose to me. Of course I am not there and can't hear/feel the noise myself.
Rotate the tires manually, see if there is excessive movement in the suspension. You have to physically put your hands on things to see what's wrong.
I am shooting from the hip on these ideas since you still haven't answered our questions...
Old 01-02-2012
Barb 56's Avatar
It does it while driving on acceleration at road speed. It happens intermittently. My husband drove it tonight and it did not happen but yesterday it did it twice for him.
Old 01-02-2012
VTEC-4.0's Avatar
Could always be bad tires.I replaced the tires on my old Accord and they were cheap,made so much noise.
Old 01-02-2012
Not every code triggers a CEL.
If the engine was down 2 full quarts of oil then it's likely the engine has been damaged, the oil should be checked routinely.
Are you sure the rumble noise isn't just the fan turning on?
Old 01-02-2012
Do fans come one when you are driving? I think not...
I'm sticking to there being something loose....
Old 01-02-2012
I only skimmed the thread, it sounded as if it was happening following idling, hence fan suggestion.
If the car is at speed, then it's definitely something loose or worn in the suspension. Check wheel bearings, ball joints, axles, tie rods/ends.
Old 01-03-2012
Barb 56's Avatar
It's at the garage this morning checking axle, ball joints and CV. I will let you all know the outcome.
Old 01-04-2012
Barb 56's Avatar
Ended up going to a transmission place. They flushed the transmission, put all new fluid and a shudder fix additive. Drove it 30+ miles and all seems good. Daughter took it home another 15 miles. No problems so far. Mechanic said if problem returns, it most likely is torque converter. Hope not.
Xuhme
21
08-07-2023 03:40 PM
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
smmahan
04-15-2015 08:17 PM
mohawkboom
11-02-2001 06:00 PM
Quick Reply: Sounds like driving over a rumble strip at low speed
