high pitch squealing when car starts??
Old 01-31-2011
jeffconnell12's Avatar
jeffconnell12 is an unknown quantity at this point
hey when i start my car i get a high pitched squeal, so im guessing this is one of my belts.. my friend told me to water each one down until i see which one is making the noise, any suggestions? thanks
Old 01-31-2011
Re: high pitch squealing when car starts??
https://www.civicforums.com/forums/1...celerates.html
Old 01-31-2011
High pitch squeal is generally caused by a loose or worn out belt. It's either the accessory belt or the power steering belt. Depending on how many miles you have on them just get them replaced, if they are fairly new it's probably the result of an improper install and just tighten them up. The accessory belt and p/s belt on these cars dont have an auto tensioner so they won't keep tension as they wear.
If your going to put anything on the belts don't use water use belt dressing. It works way better.
Old 01-31-2011
Trance Addict
MelJ's Avatar
Yeah. Definitely sounds like a belt.
Old 02-01-2011
Mad Dog Tannen's Avatar
+1 for belt!
Old 02-12-2011
prezdead's Avatar
prezdead is an unknown quantity at this point
Just replaced both of mine - was the belt
Old 03-14-2011
Xplod590's Avatar
Xplod590 is an unknown quantity at this point
My car makes the same noise. But i have changed both of my belts and it still does it mainly when i start my car. i have been told that I have a baring that is going out in one of my pulleys. Anyone have a idea of the main one that I need to start with on checking?
thanks in advance.
mikemc422
08-09-2018 05:41 PM
usajags84
05-10-2015 08:11 AM
dragonsblood
04-27-2015 12:28 PM
Blaster30
04-22-2015 12:21 PM
tattedlariat
04-12-2015 07:55 PM
Quick Reply: high pitch squealing when car starts??
