2001 honda civic overheating when turn on heater any help would be appreciated
Old 11-28-2010
escomonose's Avatar
escomonose is an unknown quantity at this point
Can anyone help my car started overheating about a month ago. I thought i had fixed the problem but now if i turn on heather the car overheats in minutes. I replaced the radiator fan switch and the enginecoolant tempature sensor. didnt start with the thermastat because i know that usually turning on heater will cool down the engine. The tempature will go down as quickly as it goes up. The heater started to act funny as well sometimes it will blow hot air sometimes cold.
Old 11-28-2010
Re: 2001 honda civic overheating when turn on heater any help would be appreciated
what did you do when you thought you fixed the problem?
Old 11-28-2010
Does hot air blow out of the vents when it's turned on?
Old 11-28-2010
escomonose's Avatar
I replaced the engine coolant tempature sensor and the radiator fan switch. At first the fan was not working when it was supposed to. I know that usually when the thermastat is bad the heater will cool down the engine that is why i did not start with that. The car will cool off as fast as it heats up.
Old 11-28-2010
escomonose's Avatar
sometimes the air is hot sometimes cold
Old 11-28-2010
escomonose's Avatar
Sorry about the delay in response
Old 11-28-2010
I'd start with replacing the radiator cap and bleeding the coolant system. There might be air in there causing it to overheat. Are you sure you installed the sensor right? Does the fan work now?
Old 11-28-2010
yep, I agree with Tom (tbohar).
I'd probably go as far as covering all bases while you're messing with the coolant system. Replace the radiator cap, flush the system, replace the thermostat, then fill/thoroughly bleed the coolant system. All those things are minimal costs, and, depending on how much you spend on the radiator cap, should run you less than $50 total.
Old 11-28-2010
escomonose's Avatar
Thanks for your help. i will try these suggestions.
Old 11-28-2010
escomonose's Avatar
LionSpratt
01-29-2017 11:07 PM
CascadiaBlue
04-18-2015 09:13 AM
aZnVoYCe
12-07-2001 12:41 AM
aZnVoYCe
Bolt-on Engine Performance
11-04-2001 10:18 AM
Quick Reply: 2001 honda civic overheating when turn on heater any help would be appreciated
