Trunk Release Handle Stuck In Locked Position
Old 04-01-2009
jhk1976's Avatar
jhk1976 is an unknown quantity at this point
Unhappy Trunk Release Handle Stuck In Locked Position
Help!
I have a 2005 Honda Civic LX Special Edition. My trunk release handle has a lock on it, so you can use the master key to lock the trunk release handle, preventing the trunk from being opened from inside the car. Last week I locked the trunk handle, but have been unable to unlock it. I insert the master key and turn it from the locked to the unlocked position, but the handle is still locked somehow. When I turn the key, I don't seem to feel any resistance from inside the locking mechanism, so I have a feeling something's come undone in there.
I'd like to fix this myself if it's something simple. Anybody know how I can go about opening the sucker up to see what's going on and/or how to fix it?
Old 04-01-2009
badhabits's Avatar
badhabits is an unknown quantity at this point
Re: Trunk Release Handle Stuck In Locked Position
ignore everything i say.
you could probably just pry the plastic cover off, and move the lock manually :P
but then if u crack it (and u will) ud have to buy a new cover, but i doubt they could be too expensive :P
Old 04-01-2009
that lock is a joke lol. yeah just try to pry out the top plastic piece and play with it. spray some lube in the hole too maybe its jammed. i dont even use it cause if you forget its locked and yank the handle, it will prolly snap off.
Old 04-02-2009
CraigW's Avatar
I have a bulletin for something similar to this on my home pc. I will try to locate and post it.
Old 04-02-2009
CraigW's Avatar
Cant find the TSB... Forgot I lost some stuff a while back.
I attached the page from the manual.
File Type: pdf
Old 03-08-2010
spawnaside's Avatar
spawnaside is an unknown quantity at this point
I also have the same problem! Did anyone find a solution?
Trunk release will not work. The key will turn the lock but the handle never becomes operational...
Are there any good sites for the TSB?
Old 03-09-2010
CraigW's Avatar
I had the same thing recently, I used a multi-folded sheet of paper wedged between the lock cylinder and the metal bracket on the rear side. It moved the bottom of the cylinder forward and allowed the 2 mechanism to start meshing again and it has worked fine since.
Once the covers are removed the lock cylinder can be pryed straight up for removal.
DerbyDad03
Exterior
05-16-2021 10:07 AM
Adam925
11-19-2019 10:56 AM
numbersguy
Electrical DIY
09-15-2018 11:24 PM
carhag2000
04-25-2015 01:33 PM
Quick Reply: Trunk Release Handle Stuck In Locked Position
