DIY: replacing power window motor assembly on my civic coupe
Old 03-07-2009
wallydude03's Avatar
My power window motor assembly broke so i replaced it today. I hope that these pictures will help anybody in the same situation as is was.
Start by removing the handle:
unclip the handle wire and power lock button if you have it:
remove this screw by the power window control panel:
disconnect the cable:
remove the 2 screws holding the door panel:
pop off this plastic piece by the mirror:
Now grip the panel from the bottem by the speaker, start popping off the panel:
rip off that white plastic on the door if you want:
Connect the window control panel back up and move the window up until you see the 2 bolts through the two holes on the door:
remove the window motor connector and unclip it from the door:
remove the window:
Remove the 4 bolts that hold the window slider:
Its out!
I hope this helps anybody who has a similar problem
Old 03-30-2009
ph0ng's Avatar
ph0ng is an unknown quantity at this point
Re: DIY: replacing power window motor assembly on my civic coupe
Good post.
I just got finished fixing my passenger side window. The process was exactly as you described, minus one part... My window was stuck in the down position! So removing the mounting bolts for the glass was a pain in the ***.
Once I took the motor unit out, found out everything was working perfectly. Unit ended up getting jammed. Put everything back in and now it actually works better.
Once you have everything out, its a good time to grease the track for a smoother ride.
Old 03-30-2009
lordhelmet's Avatar
DAMN! That's a great write-up! I don't know how I missed this post a couple of weeks ago. Have some rep.
Old 05-27-2009
lapchern's Avatar
lapchern is an unknown quantity at this point
how did you remove the window exactly? my window is currently stuck in the down position. thanks.
Old 05-27-2009
^I would try directly applying power to the power window motor connector and see if the window can roll up. The easiest way to remove the window is to lift it up so that you can see the 2 bolts throught the 2 holes in the door
Old 09-08-2009
Atromos's Avatar
Atromos is an unknown quantity at this point
Pretty easy, you just unscrew it from the slider. If you were looking at it, you'd know what to do I'm pretty sure. Getting the door's plastic bits and whatnot off is probably the biggest chore... all I can say is be careful with the metal tools, they kill plastic like a mo.
Old 09-15-2009
civic_goober's Avatar
civic_goober is an unknown quantity at this point
This was a great post. My driver side window pwr regulator assy cable snapped and this post saved me big bucks by showing me how to do it myself on my 2001 Civic LX
I saw on other postings where I could get the power window regulator assembly online. I saw places like MajesticHonda.com it's $179.00. Their site has some errors. They had 3 parts listed.
Power window regulator assy 59.00
Power window regulator assy 179.00
Power window regulator 59.00
I called to find out which one was the right part for my car. They told me the obvious...the 179.00 part.
I also checked some other sites that sell "Direct OE Fit" parts. I IM'd the technical support and they told me that it's an aftermarket part from Dorman that will work - price 77.00. Some other aftermarket parts sites sell others like Dorman for as low as 52.00.
I was visiting the Hamilton, NJ area and I called the local Honda dealer. Hamilton Honda. price...$80.07 + tax.
for the whole assembly. So check locally and compare prices.
Out of curiosity, I also called the Lakeshore Honda Dealer in Toronto, ON, Canada. And surprise the part costs $225.00 CAD. What exchange rate are they using?
It's not hard. Except for pulling out those white **** things that hold the door trim in place. If you have one of those forked flat head screw driver tools that removes this trim holder grommet. It's super easy.
Old 10-22-2009
jwai's Avatar
jwai is an unknown quantity at this point
Hello i have an 05 civic sedan es .. an Australian model. Here we drive on the right hand side. Therefore i am wondering if a US regulator for the FRONT left would fit MY AU model for front left. Here is what i'm thinking of buying :
http://cgi.ebay.com/ebaymotors/01-02...Q5fAccessories
I called up my local honda spare parts: they are selling them for 600AU.. jesus christ
Old 10-27-2009
silviacivic's Avatar
silviacivic is an unknown quantity at this point
hey i'm kinda new to the whole forum thing and i didnt know how to search or any thing so i'm just replyin to this and askin for directions on replacing a 6th gen coupe window someone broke into my car and now i'm out a driver side window some ppl say its hard others say i can do it myself but i'm not sure...help?
Old 10-27-2009
Old 11-17-2009
Gumdrop's Avatar
Gumdrop is an unknown quantity at this point
for this DIY, do you have to roll the window down while removing the door panel? or should you keep it rolled up?
Old 03-26-2010
mkabatek's Avatar
mkabatek is an unknown quantity at this point
Smile Re: DIY: replacing power window motor assembly on my civic coupe
Thanks. The part cost 50$ w/ shipping off ebay, and it took me about 1 hour to do! Easy. Thanks again.
Old 07-31-2010
jimmyjames1387's Avatar
jimmyjames1387 is an unknown quantity at this point
I agree with the other posts. This was extremely helpful, it would have taken me MUCH longer to figure this out on my own. The only problem I ran into was in reinstalling the window. The motor is moving the window really well, but after it gets past about halfway down it binds up a little and won't go all the way down. Any tips on how to properly reinstall the window?
Old 07-31-2010
CraigW's Avatar
^^^ Make sure your upper and lower tracks/channels are clean and also make sure the rubber inserts are not deformed or out of place.
Old 07-23-2011
mbryanr's Avatar
mbryanr is an unknown quantity at this point
Another great photo tutorial for 2006-2011 Civics...made my job so much easier!
http://www.paulstravelpictures.com/H...ide/index.html
Old 04-12-2012
tongsmith's Avatar
tongsmith is an unknown quantity at this point
hay what do i do if my window is stuck all the way up thanks for your time ppl <3 Honda4life
Old 05-02-2012
kuke554's Avatar
kuke554 is an unknown quantity at this point
I also would like to know if there are any other changes that would need to be made if the window is stuck in the up position?
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
miatabro
07-17-2015 12:12 PM
Pr0n1s
04-30-2015 03:08 PM
15EXCoupe
04-19-2015 09:26 PM
Killagi
04-12-2015 10:42 AM
Quick Reply: DIY: replacing power window motor assembly on my civic coupe
