Error Code: P0497 (EVAP System Low Purge Flow)
Old 12-04-2008
Celsian's Avatar
Celsian is an unknown quantity at this point
I'm no expert when it comes to car problems. Luckily I have a smart dad who is. Unfortunately P0497 which is a Low Purge Flow in the Evaporation System has stumped us. I have an '04 LX and everything is stock.
Has anyone had this problem before? Where's the best place to start? Any suggestions are greatly appreciated.
Old 12-04-2008
TRIZ's Avatar
Re: Error Code: P0497 (EVAP System Low Purge Flow)
From what I find, it has something to do with ecm calibrations aka your fuel mixture. If you take it to the dealer, they should be able to adjust the mixture so your not throwing that code.
EDIT: You cant do this yourself because its on the PROM, programable read only memory.
Old 12-04-2008
Celsian's Avatar
Thank you for the speedy response. Before I go into the dealership and spend the $99 to have the ecm calibrated, it was suggested by one of Honda's Mechanics that I clean the Vapor Canister Purge Valve. He seemed to think that it may only be opening part way which would be causing the low purge flow. Unfortunately I didn't ask how to clean it. It's in the closed position right now so I am unable to blow through it or anything like that. Should I just shoot some WD40 in it?
In case you're unsure what the purge valve looks like, here's a shot of it. (Sorry about the quality, blasted cell phones.)
Old 12-04-2008
TRIZ's Avatar
I dont wanna steer you in the wrong direction- I dunno how you go about cleaning it- I'm not sure WD40 is the answer, it could hurt it. Call your guy back at honda and let me know what he says.
Old 12-13-2008
jackscivic's Avatar
jackscivic will become famous soon enough
You would be wise to just replace the purge valve. cleaning it is not the answer. And by the way, on a stock PCM you cant calibrate the A/F mixture. There might be a Update, but its not going to correct a bad valve. Purge valves do go bad ya kno.
Old 10-18-2011
brewcrewearl's Avatar
brewcrewearl is an unknown quantity at this point
Squirting WD40 into this valve would be a horrible idea, its an air valve and spraying somethign like that into it could very well gunk it up. If you do want to clean it I would use alcohol and shake it around inside the valve, then allow it to air dry, it won't leave any unwanted residue. I checked mine using some batteries and blowing throw it(in the direction of the arrow). It opens and closes when you energize it just like any other solenoid valve. Mine seemed to be working fine, I ended up changing it anyway but it didnt fix my problem, I had and still have the same code as you.
Old 11-30-2011
kamran123's Avatar
kamran123 is an unknown quantity at this point
Sir i have a 2006 Honda civic, im trying to figure out where does the purge valve locates at, i cant find it, can u please help me out?
Cajunkev1
04-03-2017 04:32 PM
lilrob1213
37
06-29-2015 06:45 PM
Reverb2005
06-26-2015 06:22 PM
davidpaustin
04-30-2015 11:20 PM
Quick Reply: Error Code: P0497 (EVAP System Low Purge Flow)
