Transmission dipstick
Old 11-22-2005
millerwl71's Avatar
millerwl71 is an unknown quantity at this point
I went to check my transmission fluid and when I went to pull out the dipstick it kinda felt like it was just laying on top of the hole. It was really lose like it wasin't grabbing. I'm suprised it dosen't fall out when I'm driving. Well, the question is, is that normal to be be that lose or should there be some sort of grab when I pull on it? Thanks.
Old 11-22-2005
Crayons taste like purple...
shroomster's Avatar
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
it relies on a minute amount of suction from the lip of the hole...best solution is to try and find some tape that is heat resistant that can add some security to your peace of mind....dunno why Honda skimped on putting a dipstick tube on this gen of civics...
Old 11-22-2005
Boobies are the mans tinkertoys
dp_yz713's Avatar
dp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to behold
My dad is a mechanic and he said it is fine. It wont fall out. It would have to raise up almost a foot high to fall out.
Old 11-22-2005
shroomster's Avatar
now here is the thing...it doesn't have to fall out for it to leak fluid, which is what mine did...the damn thing has to be seated 100% correctly for it to suction right and not leak
Old 11-22-2005
dp_yz713's Avatar
true, but if it still in there, and leaks then you should see the oil on the ground. idk. i just asked him and he said as long as you push it down it will be fine. did it affect your trans any? or did you catch it early enough
Old 11-22-2005
shroomster's Avatar
have you ever started your car without the oil cap on?
it spritzes like a fountain sort of * <<<like that asterik but only tiny drops...
the tranny just kinda seeps out when it gets hot enough...it wasn't a case of it dripping cuz it isn't a heavy steady thing, as the tranny isn't full to the brim giving enough reason for it to leak, it was more of a seepage onto the hot tranny that dried it nearly immedately and left that residue look on the back of the tranny and on some of the wiring around it...
Old 11-22-2005
dp_yz713's Avatar
yah i hear ya.....no smell of it burning, cause it smells like crap when its new, jw
Old 11-10-2011
gotbyu's Avatar
gotbyu is an unknown quantity at this point
Re: Transmission dipstick
I came across this tread because I also too noticed that on my 2003 civic the transmission dipstick was very loose. Anyways, I did find a solution and apparently honda has a newer trans. dipstick and I was able to find it at hondapartsnow(dot)com They had it for like $8 and the part # is 25610-PLX-003
It goes in nice and snug and is no longer loose. I hope this helps anyone else that comes across this. Now I don't have to worry about this falling out or having debris fall in the transmission.
Old 11-10-2011
lowlife9's Avatar
i believe gearbox said he purchased the new style dipstisck awhile back and after time it also became loose like the original one.
Old 11-10-2011
i dont think it would get that loose like the original unless you leave it in there for years. the key is to wipe around the hole with a shop towel before installing the stick. trans fluid is what shrinks the rubber. just like it does to the seals in the trans lol.
Old 12-15-2012
botakcivic's Avatar
botakcivic is an unknown quantity at this point
Old 12-16-2012
Dr Krieger of Modification
mac25's Avatar
i've always thought about the chance of getting dirty rain water in there when you hit a pot hole full of water.
Old 12-16-2012
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
All I can say is that my dipstick was left loose and it jammed into the tranny bending the dipstick and shaving off some metal.
I would make sure it fits well and is always pushed in tightly.
Old 03-11-2017
Robert Mason's Avatar
Robert Mason is an unknown quantity at this point
Thank u so much my friend u r a life saver!!!
nola000
Engine start problems
63
02-17-2023 09:18 PM
Whitexj
09-30-2015 02:04 AM
blizza
09-22-2015 03:48 AM
jerry38
09-20-2015 08:38 AM
Christian123456
09-09-2015 05:26 PM
Quick Reply: Transmission dipstick
