SOHC versus DOHC? Advantage Disadvantage?
Old 12-28-2004
ravolutionazx's Avatar
ravolutionazx has a little shameless behaviour in the past
I'm new to this forum thing but this has been bothering me for quite some time now.. as we all know (for those of you who actually take time to look under your hood) we 7th gen's have SOHC D17A motors.
Single OverHead Cams.
Now as opposed to hearing about many DOHCs around there...can anyone say B series..
what is the difference between SOHC and DOHC.. disadvantages? advantages? i need help.. thanks
Old 12-28-2004
loser x)
Old 12-28-2004
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
Wtf?
Old 12-29-2004
devilvtec's Avatar
devilvtec is an unknown quantity at this point
well, just to warn you, you sort of came off as having an attitude, which is prob gonna get you some undesired responses. I cant help you out too much except to send you to www.howstuffworks.com and read about the engines and dual cams and single cams, that may help you more than anything else
Old 12-29-2004
O RLY
S2000man01's Avatar
dohc's in the long run will be able to rev higher due to the fact that their rocker arms, and valve train have shorter parts. in a dohc setup, generally one cam is for the intake side, and the other for the exhaust side. (meaning the intake valves and exhaust valves)
so obviously in the case of two is better than one, dohc and sohc are no exception.
there's a ****-ton more detail you can go into on it, but howstuffworks.com will give you a good rundown as well.
Old 12-29-2004
nor cal 7thgens
allmotor's Avatar
basically to put in short terms what s2000 man said....dohc
Old 12-29-2004
MrDibbs19's Avatar
MrDibbs19 is an unknown quantity at this point
^^ yea what he said
Old 12-29-2004
Got Boost???'s Avatar
in addition to what S2000man said...
When it comes to tuning you can advance/retard each cam individually with a DOHC setup.
The spark plug can also be dead smack in the center of the combustion chamber with a DOHC setup.
Old 12-29-2004
nickm748's Avatar
What all of them said^^^
Old 12-29-2004
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
hahahhahahahahahahhhhahahahaaahahahahahaha
Old 12-29-2004
texasric3r's Avatar
texasric3r is an unknown quantity at this point
Not only that, but when you come in with an attitude, you should at least get all of your facts straight. "Single OverHead Cams" -> WTF?? Single indicates ONE overhead CAM.
Old 12-29-2004
thats why its called SOHC. and i wasnt copping an attitude.. sorry if thats how you received it but thats not how i meant it to be.. anyways thanks.. ill check the site
Old 12-29-2004
bgoetz's Avatar
bgoetz is an unknown quantity at this point
yep + in the case of cars with VTEC both the intake and the exhaust valve performance in maximized with the DOHC. Were with the SOHC only the intake valve performance is maximized. This creates a VTEC that is a hell of alot more noticeable.
Old 12-29-2004
mexinaction's Avatar
Bwahahahahahahahahaaa
Old 12-29-2004
CivicsRdBest's Avatar
The only advantage that I know of on a SOHC engine over a DOHC one is less moving parts.
Old 12-29-2004
SIinthesky's Avatar
SIinthesky will become famous soon enoughSIinthesky will become famous soon enough
DOHC is much better from a tuning standpoint when you're running cams and cam gears.
Old 12-29-2004
Arith's Avatar
Arith has a little shameless behaviour in the past
Exclamation
what a loser...
Old 12-29-2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Sohc - Economy
Dohc - Vrooom! :d
Old 12-29-2004
Drakkar's Avatar
Drakkar is an unknown quantity at this point
well let's see
sohc- is less rotationing mass, which means your would be able to make it so that this engine design to be able to make very high rpm's with the right amount of tuning. single cam engines have been some of the most powerful its just takes money.
dohc- has more potential to make power there for its most likely the better choice. the problem with dohc designs is that there is more rotating mass involved so it takes more power to make those parts move, also there is double the chance that something may break because there is 2 of them instead of one. but overall this is the better choice because of honda's setup with their dohc designs you are able to change the the advance/ retardation of the cams as stated earlier.
hoped this helped
Old 01-02-2005
thanks.. i still wish i had a K20 though
Old 01-02-2005
Old 01-02-2005
Drakkar's Avatar
we all wish we had a k20a2
Old 01-02-2005
RESIDENT ROTOR HEAD
nookiemonster's Avatar
nookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of light
^^^ Not me!! Hehe I'll keep that D17 for a long time methinks.
Old 01-02-2005
zachgeyer's Avatar
in hotter cars
Old 01-02-2005
nor cal 7thgens
allmotor's Avatar
u can still make a sohc fast.... look at bisi's old track car hittin 10s
Old 01-02-2005
civic01vtec's Avatar
Old 01-02-2005
Wolfgang5884's Avatar
Wow, people are lazy.......LOOK AROUND THE NET!!!
Old 01-02-2005
O RLY
S2000man01's Avatar
Originally Posted by Drakkar
well let's see
just to point out.
yes less rotating mass, since there is only one cam, rather than two.
however, they are NOT as good for high rpms as a dohc.
due to the fact that the cam rocker arms, etc, must do BOTH intake and exhaust valves, they are longer and do not do well at higher rpm.
Old 01-02-2005
The Beer-man
Metallica454's Avatar
Metallica454 is an unknown quantity at this point
To hell with all SOHC, DOHC, pushrods, rocker arms, lifters......Rotary is infinitely more effecient and simple. If my memory serves me correctly, I belive a standard wankel rotary only has some 3-4 moving parts where a standard V6 has around 200. It's too bad though most companies don't think outside the box and can realize the benifits of such an engine.
Old 01-03-2005
RESIDENT ROTOR HEAD
Let me clarify.
1.0-1.3L rotaries have 3 moving parts. Two rotors and an eccentric shaft (similar to a crankshaft.) The 20B (2.0 L) has 4. Three rotors and the eccentric shaft.
The main reason why other companies don't use them is because in the beginning, they gave up early. In the late 60's Chevy experimented with the idea of a rotary Corvette, but ditched the idea. They couldn't make it work. The engineer at Mazda (sorry I really don't know his name) who still designs rotaries today, was under the direct tutelage of Dr. Felix Wankel...the Father and inventor of rotaries, a German engineer.
The reason why the other companies don't use them now, is because Mazda has copyrighted much of the progress they've made in rotary development. Plus the fact that Mazda has established a niche with a rotary market, and it would be very hard to compete.
Quick Reply: SOHC versus DOHC? Advantage Disadvantage?
