~~~DIY Front Door Speaker Install Coupe and Sedan~~~
Old 01-31-2007
electric130's Avatar
I know this has been DIY'ed several times, but even the sticky didn't cover everything I encountered, so I thought I'd write up what I did. Also, I'm making the pictures as attachments so they won't get lost and turn into little red x's in a year or so like most of the DIY's on here that have pics hosted on another site.
My installation was performed on a 2002 LX Sedan with power windows and door locks. If you have another model, it may be similar, but I can't promise that.
EDIT: Thanks to EggRollBandit05 for providing steps and pics for the COUPE owners out there
Speakers
Infinity Reference 6012i
Tools Needed
Standard flathead screwdriver
#2 Philips screwdriver
Long skinny flathead screwdriver
Drill (preferably cordless)
3/16" drill bit
3/8" drill bit
8-32 Tap and matching #29 drill bit (can usually be bought as a set for a couple $$$)
Wire strippers
Terminal crimpers
Jigsaw
Parts Needed
(8) - 8-32 x 1.25" Machine Screws
(8) - #8 Lock Washers
1ft Speaker wire 16 or 18 ga
(4) - Male spade connectors
(2) - Small female spade connectors
(2) - Medium female spade connectors
Here's the tap, drill bit, screws and washers you can pick up at Lowe's.
As you can see here, you've only got about 1.75" of clearance between the top of the door panel and the window. also, the width of the opening is ~4.125" so keep that in mind when picking out speakers. especially if you want components. they tend to have very large magnets.
If your speakers are less than that, then you're good. Go head and mount them. My speakers were right at 2", so I needed a spacer.
A 0.5" spacer would have done the trick, but I had some .75" MDF laying around so I used that for mine. You can use whatever you want to make your spacer. Start by tracing the adapter ring (or the speaker if you don't have one) as a template.
Drill a 3/8" hole in the middle ring so you can get the jigsaw blade in there.
Cut out the spacer and repeat for a second one.
Test fit the spacer on the speaker and ensure it fits. Mark the locations of the 4 mounting holes of the speaker.
Drill the mount holes with a 3/16" drill. This hole is big enough to let the 8-32 screws pass through freely, which is what we want. Again, repeat for the other spacer.
My speakers came with foam, so I installed it on the back of the speakers. I doubt it will help at all, but I put it on anyway.
Insert screwdriver as shown and pop off cover.
Remove 2 philips screws here.
Pull out assembly as shown and remove electrical connector.
In order to remove the assembly, you'll have to remove the door opener rod. Rotate the plastic connector 90 degrees and lift the rod straight up. Compare the pics to see the connector.
Locked
Unlocked
Remove Sail Panel.
Insert screwdriver as shown and gently pry off the cover for the door handle.
Remove screw from door handle here
and here
Remove power window connector if applicable
EDIT:Heres a continuation of the panel removal process for the COUPES
The steps are the same up to the removal of the sail panel.
pry up the screw cover inside the handle.
remove the phillips screw.
start from the front and pry up the door handle cover until you can slip a finger inside to pull off the panel.
Disconnect the power window connector and set the cover aside
Now remove the two phillips screws:
front...
back...
Then stick your hand inside the door handle opening and pull towards you to pop out one of the clips.
The rest of the instructions are the same as the sedan (pry up around the edge of the door panel to pop off the white clips)
Thanks EggRollBandit05
Insert screwdriver as shown here or anywhere around the door panel edge and pry up just enough to get your fingers behind the panel. There should be around 5-6 fasteners that will pop off. The panel the slides straight up out of the window channel.
To remove the stock speakers without damaging them, insert the long skinny screwdriver into the top and press down to release the clip.
Wiggle the speaker back and forth while pulling up to release the bottom clips. then admire your massive paper driver! Remove the factory connector
So I didn't have to cut off the factory connector and could reinstall the OEM speakers later if desired, I opted to make my own adapter harness. I only had the larger spade connectors on hand, so I cut them to make them fit. See pic for comparison. If you can get the medium size male's, then you'll be good.
Here's all the connectors you'll need.
Cut the 1ft wire in half, strip the ends and crimp the terminals on to make the 2 harnesses.
Position the speaker and spacer on the door. Ensure that the speaker terminals will not touch the metal of the door panel. Mark the location of one hole. Drill with the #29 bit and tap it to make threads.
Mount the speaker with one screw and tighten down. Mark the location of the other 3 mount holes. I inserted the 3/16 drill bit into the spacers holes to mark the metal. I made a mark on the spacer so I knew where the speaker terminals were. This made it easier when I was reinstalling because unless you drill everything perfectly spaced, the spacer will only really fit one way when you put it back together.
Drill and tap the remaining 3 mount holes. Install the wire harness you made.
Put a lock washer on each of the 4 mount screws. Insert and mount the speaker with 4 screws and 4 lockwashers.
At this point, I turned my car on to make sure that the speaker was working. Once you're satisfied, reinstall the door panel the opposite of how you removed it. The passenger side is essentiall the same with one exception. Removing the electrical connector for the power window has to be done from the back of the panel. Insert the skinny screwdriver as shown to release the locking clip.
Other than that, the install is the same as the driver's side. Enjoy your new speakers.
TIP:When installing the door panels, it's easier to do it if the windows are rolled down. Obvisously, the window control switch needs to be connected for this to happen, so i rolled my windows down before I started. Also, if you're using a different spacer, with the window already rolled down, you'll know right away if the speaker is going to hit the window or not.
ID:	69469   Click image for larger version
ID:	69470   Click image for larger version
ID:	69471   Click image for larger version
ID:	69472   Click image for larger version
ID:	69474   Click image for larger version
ID:	69475   Click image for larger version
ID:	69476   Click image for larger version
ID:	69477   Click image for larger version
ID:	69479   Click image for larger version
ID:	69480   Click image for larger version
ID:	69481   Click image for larger version
ID:	69482   Click image for larger version
ID:	69484   Click image for larger version
ID:	69485   Click image for larger version
ID:	69486   Click image for larger version
ID:	69487   Click image for larger version
ID:	69490   Click image for larger version
ID:	69491   Click image for larger version
ID:	69492   Click image for larger version
ID:	69493   Click image for larger version
ID:	69495   Click image for larger version
ID:	69496   Click image for larger version
ID:	69497   Click image for larger version
ID:	69498   Click image for larger version
Last edited by electric130; 04-22-2007 at 07:46 PM. Reason: 1-Tip added. 2-dimensions added. 3-coupe steps added.
CivicHybrid03 (06-28-2020)
Old 02-03-2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Metra 72-7800??
Old 02-03-2007
TRIZ's Avatar
the door panel removal process is different for the coupe, otherwise pretty much the same. Nice DIY, great step by step pics!
Old 02-03-2007
speedfoos's Avatar
Color me impressed. Nice DIY. Word on the coupe process.
Old 02-03-2007
ian01ex's Avatar
ian01ex is an unknown quantity at this point
Very detailed. Thanks for the new diy cuz most of the old ones pics dont work anymore and all that fun stuff.
Old 02-03-2007
Originally Posted by christmaspie
yeah, that would work, but mine was free vs. the $7 from there plus $5 minimum for shipping and both will perform equally. good find though if someone either doesn't feel comfortable with my way or doesn't feel like spending the time to make them.
Old 03-05-2007
Europort's Avatar
Europort will become famous soon enough
Nice post electric, glad to see somone else besides myself trying to make life easier for 7th gen'ers as far as door panel removal goes :P
Old 03-05-2007
I wil fix vBPlaza today
LT2004ever's Avatar
great DIY, i could follow it very easily! if i had a sedan i'd so be out there right now. BTW is there a DIY for the coupes on the site?
Old 03-16-2007
mikenam's Avatar
mikenam is an unknown quantity at this point
^^^^coupe is the same.
great diy.
Old 03-18-2007
TRIZ's Avatar
^ have you done this?
agian, coupe isnt the same with the door panel removal process.
BTW electric, get at me on AIM, we gotta talk about a new audio setup for me =)
Old 03-18-2007
i don't do AIM. i refuse to install any garbage that AOL put out! if you've got gmail we can chat there. send me a PM.
Old 03-20-2007
mikenam's Avatar
Re: ~~~DIY 02 LX Front Door Speaker Install~~~
yes ive installed comps in my coupe.
Old 03-21-2007
yingjai's Avatar
yingjai is an unknown quantity at this point
OMG. I can't believe I didn't find this earlier. The audio shop told me I had to cut my wires and that's everyone does it. He said nobody makes these connectors. So much for believing them.
Old 03-21-2007
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
Great job!!!
Old 04-15-2007
paradoxblue's Avatar
http://www.cardomain.com/item/SCOSAH6
will those fit in my 2004 coupe front doors?
i dont have tools to make my own
Old 04-15-2007
they should as long as they're not bigger than 1". i know 3/4" fits, but i've heard that 1" won't allow the door panel to go on. at any rate, you'll have to drill holes with those, so you'll still need some tools.
Old 04-22-2007
dang i may have to suck it up and pay to have an audio shop install my door speakers.
im in ontario must be lots of places that will do it..
stupid military not letting me have my tools
Old 04-22-2007
You Stay Classy, San Diego
jamis33's Avatar
dude its really not that hard. Im doin mine today. Go to homedepot and get some 1/2" or 3/4" mdf the smallest sheet they have and trace out the circle templates that came with ur speakers. Then screw those into ur doors. and then screw the speakers into the mdf. I know that my local shop sells 1/2" and 3/4" speaker circle things pre cut out from plastic but i think they're around 8.99 each and u can install them urself. it just saves u from cutting. Any good car audio shop should have them. Even a best buy should just ask the install department and they'll sell u the part.
Old 04-22-2007
ok ill do that i guess
i dont even have a drill ill need self taping screws heh..
no tools for me to play with
Old 04-22-2007
no one you know has any tools? you should be able to use self tapping screws, but you're gonna get a workout trying to do it by hand!
Old 04-22-2007
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enoughEggRollBandit05 will become famous soon enough
Hope you dont mind me adding this electric130. You can do whatever you want with it, change wording, move it etc. I tried to follow the same format you used and loaded the pics as attachments.
front...
back...
Name:	Panel removal coupe.JPG
ID:	70627   Click image for larger version
Name:	Panel removal coupe (1).jpg
ID:	70628   Click image for larger version
Name:	Panel removal coupe (2).jpg
ID:	70629   Click image for larger version
Name:	Panel removal coupe (3).jpg
ID:	70630   Click image for larger version
Name:	Panel removal coupe (4).jpg
Name:	Panel removal coupe (5).jpg
ID:	70632   Click image for larger version
Name:	Panel removal coupe (6).jpg
Old 04-22-2007
awesome bro!!!! heck no i don't mind. i'll add it to the first post and change the title.
+1 rep for you!!
Old 04-22-2007
my civic has no boost
hotrodcivic2004's Avatar
Re: ~~~DIY Front Door Speaker Install Coupe and Sedan~~~
just FYI everyone.....instead of doing like the....make shift wiring like he did....you can goto best buy, or circuit city and get a speaker wire harness for our cars.....they come in pairs and fit the same on all 4 speakers. that way everything is gauranteed to work great and fit great.
Old 04-23-2007
this was already covered by christmaspie in the first post after i started the thread:
Old 04-23-2007
word or the Scosche SHHA02B.
Buy one, build one; its all pretty much the same.
Old 01-27-2008
jee88's Avatar
jee88 is an unknown quantity at this point
anyone know how deep of speakers u can put in before the door pan wont fit properply
Old 01-27-2008
it really depends on the speaker. mainly how tall the speaker is from the back of the frame where it would bolt to the door or a spacer and the top of the front. usually, that's the foam around the edge. i've found that most speakers fit on the front side with a 3/4" spacer ring. with a 1" spacer, a lot of people have had to trim the door panels. so there's really no clear answer to this. i gues if someone was willing to drill a big hole in their door panel and take some measurements, we could clear this up, but untill then, we'll have to go on a case by case basis.
Old 01-27-2008
Slowest 7thgen in the GTA
phuviano's Avatar
I have infinity kappa 63.7i in my front doors with 1 inch spacers. The mounting depth of the speaker is 2 3/16. According to Crutchfield, this speaker doesn't fit, but it work for me with a 1 inch spacer.
What speakers are you trying to put in??
Old 01-30-2008
aliefjoker's Avatar
aliefjoker has a spectacular aura aboutaliefjoker has a spectacular aura about
WTF?! On my ex coupe, I had 10mm bolts where theses screws where at. Is that right?
front...
back...
Old 01-30-2008
can't help you on the coupe. that looks completely different than the sedan. shouldn't matter though, screws or bolts. probably not the original parts.
Quick Reply: ~~~DIY Front Door Speaker Install Coupe and Sedan~~~
