97 oil leak
Old 02-18-2010
MrFortenberry's Avatar
MrFortenberry is an unknown quantity at this point
97 oil leak
I'm thinking rear main seal but the leak is so high up on the engine that I was wondering if maybe it wasn't something else. Also have one around my oil pan?
http://s745.photobucket.com/albums/x...erry/?newest=1
MrFortenberry is offline
Old 02-18-2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Re: 97 oil leak
What year and model is that a dx? Might be the o ring in the distributor. I can not tell from those pics.
civicpapi is offline
Old 02-18-2010
Re: 97 oil leak
there are all sorts of places. rear main seal, the cam and crank seals, oil pump seal, valve cover, oil pan, etc. clean it up and see if you can spot where the oil is coming from.
Old 02-19-2010
civicpapi's Avatar
Re: 97 oil leak
He said top of engine, so that narrows it down, to valve cover, dizzy o ring, I am not sure where the cam and crank seal leaks from.
Old 02-19-2010
04 Honda Civic's Avatar
Re: 97 oil leak
I would imagine its the valve cover gasket, but that should be easy to see..
04 Honda Civic is offline
LionSpratt
01-29-2017 11:07 PM
RIPSAW
11-06-2015 04:36 AM
Kyrian
06-26-2015 11:48 AM
671civicLX
06-13-2015 05:56 PM
davidpaustin
05-20-2015 12:59 PM
Quick Reply: 97 oil leak
