Resetting Check engine light?
Old 05-04-2009
notmycivic><'s Avatar
notmycivic>< is an unknown quantity at this point
So I hit 160km h in a 1999 civic si, which governed out the car and a check engine light appeared. As my name says, it's not my civic so how would i go about removing the light without locking the stereo?
notmycivic>< is offline
Old 05-04-2009
ScottDR's Avatar
ScottDR will become famous soon enough
Re: Resetting Check engine light?
Use an OBDII scan tool to read and erase the code. Otherwise yes, you will need to re-enter the radio code and most likely the radio station presets. Please post back what code it is indicating as I'm most interested. Thank you.
ScottDR is offline
Old 05-04-2009
ScottDR's Avatar
On second thought, only 160KPH???? That's extremely low for a top speed run. Even the US lowest model Civic versions were limited to 193KPH. I'm thinking it stopped you because of another reason, and the ECU is limiting revs in 'limp-home' mode.
ScottDR is offline
Old 05-04-2009
goto any auto store they will read the code and also erase it if you want.
Old 05-06-2009
KcRidin09's Avatar
KcRidin09 is an unknown quantity at this point
Isn't there also a under the hood fuse that you can pull out and just but back in that will reset the check engine light? if so does anyone know which fuse it is?
KcRidin09 is offline
Old 05-06-2009
well yeah but that doesnt solve whatever the problem is. its the FI ECU fuse if you just wanna delete the code, but it will just come back on again until the problem is fixed.
Xuhme
21
08-07-2023 03:40 PM
hernandexz
10-28-2021 10:52 PM
jetcare101
05-08-2015 01:33 PM
bahena08
04-11-2015 05:09 PM
Quick Reply: Resetting Check engine light?
