Sponsored by:
Sponsored by: DashLynx
Wheel Bearing DIY? 2002 EX
Old 01-03-2011
raj
raj's Avatar
raj is an unknown quantity at this point
Can anyone point me to a front wheel bearing DIY (with pics)? I did a search and found a couple different threads but not too clear however.
Can I get a new hub with bearings pressed in already? Guess that would be easier.
raj is offline
Old 01-04-2011
04goat
04goat's Avatar
04goat is an unknown quantity at this point
Re: Wheel Bearing DIY? 2002 EX
or buy a new bearing and have it pressed in. that is what we do at our shop...
04goat is offline
Old 01-04-2011
Prodresurgence's Avatar
Prodresurgence will become famous soon enough
Buy the entire hub and press that into the knuckle. Eric the car guy has a great DIY video on this. http://www.ericthecarguy.com/videos/?tubepress_page=4
The video is called "replacing an accord wheel bearing" you can find it on youtube too.
GL
Prodresurgence is offline
Old 01-04-2011
raj
raj's Avatar
GL
Thanks. I seen one of his other videos but didnt check to see if he did wheel bearings.
Im guessing Accord R&R is the same as Civic R&R.
raj is offline
Old 01-05-2011
Pretty much, it will get you through the job. I watched the video before I did one of my wheel bearings (01 ex) and it was almost an identical job. You will need a press or access to one to get that hub out. Or you can try to smack it out with something like Eric uses but I have a press so... Good luck!
Old 03-18-2011
raj
raj's Avatar
Let me just revive this thread and just share my experience with wheel bearing. Several DIY's I found indicated using OEM Honda wheel bearing. Of course I decided to cheap out on it and bought a $46 bearing from Pepboys. Its making noise on slight turns now after about a month. Right now I might just look for a used knuckle to put in.
raj is offline
Old 05-08-2011
bigheadmark's Avatar
bigheadmark is an unknown quantity at this point
i wasted time and $ by mistakenly buying a hub online..i thought that the bearing was already pressed into the hub from the factory..it was not....the FRONT wheel bearing is sols separately from the hub (at least on a 2001 LX)
bigheadmark is offline
Old 05-08-2011
If you don't have a press just remove the knuckle and take it to a shop, simple.
MindBomber is offline
Old 05-08-2011
^ A smart man there... In case you wanted to know how to remove the knuckle... :
https://www.civicforums.com/forums/1...necessary.html
BlueEM2 is offline
Old 05-09-2011
Since this came up, this one will fit well in here:
sdaidoji is offline
Old 05-09-2011
those rotors are sweet! what kind are they?
Old 05-09-2011
They are called "ATE" sold by Canadian Tire obviously in Canada... They work awesome.. grip much better than OEM. I'm just kinda trying them out because I got a great price on them:
http://www.canadiantire.ca/AST/brows...46_ViewDetails
BlueEM2 is offline
GolNat
Suspension DIY
05-12-2022 06:49 AM
CarStuff
12-06-2020 12:52 PM
Civic2002lx
10-07-2015 09:17 AM
izdman
05-19-2015 03:43 PM
bsmiley
04-27-2015 01:27 PM
Quick Reply: Wheel Bearing DIY? 2002 EX
