8th Gen 2006 - 2011.
Cold Air vs. Short Ram Intake
Old 10-22-2012
shaank18's Avatar
shaank18 is an unknown quantity at this point
I got a 2007 Honda Civic Lx Coupe Manual Transmission. I want a to add a new intake system. I want a cold air but it rains a lot over here. What do you guys think I should do.
Last edited by sdaidoji; 11-16-2013 at 05:06 PM. Reason: moved from DIY, it's a question, not a DIY
shaank18 is offline
Old 10-22-2012
qqert's Avatar
qqert is an unknown quantity at this point
Re: Cold Air vs. Short Ram Intake
move somewhere sunny.
qqert is offline
Old 10-23-2012
short ram, you wont notice the difference.
Old 10-23-2012
shaank18's Avatar
What do you think would be nice short ram. I was thinking the k&n typhoon short ram?
shaank18 is offline
Old 10-23-2012
yeah that is a good one for sure.
Old 10-23-2012
shaank18's Avatar
What do you think about weapon-r short rams?
shaank18 is offline
Old 10-23-2012
i have had mine for a very long time and love it. i did eventually trade the foam filter for an AEM dryflow paper filter and had to make some custom bracket for the intake and also extend the temp sensor wires, but its worth it. very simple and effective intake, easy to clean the filter, nice sound and gains, and filter gets outside air directly thru the upper mesh grill. so technically its like a cold air with the car moving. i have tried aem and K&N intakes and like the WR best. Ive had it for about 7 yrs.
Old 10-23-2012
shaank18's Avatar
Thanks! that helps a lot! What do you think about the Volant Cold Air Intake with RAM air scoop? Do you think itll be good in rainy weather?
shaank18 is offline
Old 10-23-2012
oops i forgot its for an 06+ civic engine. i think your best bet will be K&N typhoon with aem dry filter on it. the volant is okay, but heatshield around the filter will only trap more heat. the design looks too pieced together. the K&N even has a small heatshield on the bottom.
Old 10-24-2012
Sherlock's Avatar
Sherlock is an unknown quantity at this point
Wink Re: Cold Air vs. Short Ram Intake
this is the myth being busted for cold air and ram air intakes
They literalloy say that it gives maybe a 1%increase in power so dont waste your money get a header and exhaust and a turbo
Sherlock is offline
Old 10-24-2012
unless your car does not have an upper grill, any short ram will work like a cold air with the car moving. the engine bay has to be sealed off from outside air to actually have a warm air intake.
Old 10-24-2012
shaank18's Avatar
Would it be good to buy a breather filter?
shaank18 is offline
Old 10-24-2012
definately not! the PCV system needs vacuum from the intake to work properly.
Old 10-25-2012
shaank18's Avatar
Can Anyone tell me if this
Typhoon
Its the 69 Series K&N Typhoon Intake System for my 2007 Honda Civic
can be switched from Short Ram to Cold Air?
shaank18 is offline
Old 10-25-2012
oh, god, have been so long since we have had npot another one of the "which intake? which give the most powa?!?" threads... thought we banned them for being so frequent... bummer.
sdaidoji is offline
Old 10-26-2012
shaank18's Avatar
Dont worry its my last question about it...
shaank18 is offline
Old 10-27-2012
i would look up the model number on K&Ns website to be sure
Old 10-27-2012
shaank18's Avatar
Its 69-1013TS
Ive been looking at this on a whole bunch of websites. Its just says air intake system. if search for K&n short ram, all that comes up is the same product and product number. If i search for a K&n cold air intake, same thing comes up.
shaank18 is offline
Old 10-27-2012
yup that is the correct part for the non-si civic.
Old 10-27-2012
shaank18's Avatar
So is it both a short ram and cold air intake?
shaank18 is offline
Old 10-28-2012
well no, its a short ram like in the pic. they dont make cold air for that intake and car model.
Old 12-09-2012
Jdantonio's Avatar
Jdantonio is an unknown quantity at this point
IMO cold air is better, sucking air from in front of the wheel well. Side note you will have to avoid standing water while driving.
Jdantonio is offline
Old 12-09-2012
Jdantonio's Avatar
If your mechanically inclined you can make your own for cheap.
Old 12-10-2012
HondaLuv3r4Life's Avatar
HondaLuv3r4Life is an unknown quantity at this point
Question Re: Cold Air vs. Short Ram Intake
Is the short ram intake hard to install on a 06 ex non si sedan? looks like some kind of sensor has to mount to the tubing? Also wanted to see if anyone in here knows if i can use a short ram intake system from a 95 integra ls would fit my civic?
HondaLuv3r4Life is offline
Old 06-07-2013
monstergear127's Avatar
monstergear127 is an unknown quantity at this point
if youre going to ask how hard it is to install a air intake system then you should probably just not do it.. to really get a hp increase a cold air/short ram isn't going to do much, you also need to put on a header along with a complete exhaust system so with all that added up youll be spending around 800 to 1000 bucks
monstergear127 is offline
Old 02-09-2014
"Honda - tried, true & tested...!"
brags's Avatar
brags is an unknown quantity at this point
that's right the name (cold air intake is not really a cold air intake at all)
when its under the hood of a hot engine in a hot climate outside when its
80-90 degrees ferenheit b.s. even with the car moving your still getting warm air at best in the summer time.
brags is offline
Old 03-02-2014
pulsereaction's Avatar
pulsereaction is an unknown quantity at this point
I have the 2007 Coupe and I preferred the Weapon-R intake. It's a short intake with the cold air hook if you decide to relocate the battery, otherwise you only have room for the intake with this design. I live in Washington state where condensation is regular so a cold air or ram would not benefit ME, I also agree with the comment about HP. My intake may give me 10HP on a cold day but to maximize your horse power without spending too much you must go with headers and a cat back system to see at least 275 HP. Stock 170-175 +intake 10+headers 50+ cat back 50-70=285-300 with the right combo and brand.
pulsereaction is offline
Old 03-25-2014
shrapnel771's Avatar
shrapnel771 is an unknown quantity at this point
I put a K & N on my 95 civic and it had a more aggressive sound, but I never noticed any appreciable gain in HP regardless of weather conditions. Why not just get a regular K & N on a stock system? It would save you money in the long run. I was wondering if there was a way to put that 95 system filter in my 2013 Civic? I still own the intake system.
shrapnel771 is offline
Old 10-06-2014
4dirtbike4
4dirtbike4's Avatar
4dirtbike4 is an unknown quantity at this point
Just got an all stock civic 03 lx coupe and im looking to start modifying it. Wanted to start with a cold air intake and new exhaust, Anyone have any advice on which one or any other beginning mods i could start looking into?
4dirtbike4 is offline
Old 02-08-2015
gothman667's Avatar
gothman667 is an unknown quantity at this point
I'm just curious about something. Which brand of intake is better? Are they all the same in terms of gains? Or do they differ slightly?
Because I'm still on the fence about whether or not I want to boost my '08 Civic EX, I was planning on putting a cold-air intake system on my car for the time being, or until I decide on what I'm going to do.
Do you guys have a preferred brand that is your go-to for these situations? Something that you know will give you some gains?
gothman667 is offline
Quick Reply: Cold Air vs. Short Ram Intake
