malfunction indicator light
Rep Power: 0 malfunction indicator light
Alright guys on my way to work this morning and my car was feeling funny like it was missing almost, it was kind of jumping a little bit not too much though. So I look down a little later and my malfunction indicator light is on the yellow one right above the temp gauge that looks like an engine. What do you guys think it is I know its not the gas cap I havent got gas in like 5 days. I do have a high flow cat but i've had it for like a year now and the light has never came on before. What do you guys suggest I do to fix it?
Rep Power: 0 So if i unplug the negative cable and reset the ecu. If it stays off im good right but if it comes back on check the o2 sensor. Also I have an mil eliminator on the second sensor. Next question is that hurting my engine?
7thgen Power Maker
Rep Power: 0 Alright guys I got it checked the guy said that the code was saying high voltage to the o2 sensor after that cat. So I bought one and installed it, like a day later the light came back on. What do you guys think it could be? Could it be the mil eliminator or anything else? Please help me!
Rep Power: 0 Well the only two options is the gas cap and the emissions right! So I know its not the gas cap and I dont want to put that back on, I like the extra hp I have from it.
Can anyone answer my other questions?
Rep Power: 283 If your 2nd O2 sensor is getting High Voltage, it may actually be your MIL.
Did you install the MIL when you installed your high flow Cat?? I would think that just reseting the ECU would be enough to prevent the Malfunction Light from coming on. You will definatly Need a MIL if you Bored out the Cat, or straight piped it. But I don't know, has anyone one here done a High Flow with No MIL ???
My thought would be that the problem is either the MIL, the Sensor, or the wiring, I'm thinking an Aftermarket CAT can not increase the Voltage, and Becuase it's the Voltage it is somewhere in the connection between the Source, the Sensor and the ECU. So check you wiring, your Sensor and your MIL. If it is not one of those then you got me baffled.
Did you get the correct MIL, I don't think they are universal, I'm pretty sure you need one designed for our cars.
Good luck
Good luck
jimmyfloyd
05-20-2015 07:06 PM
werdnahall
05-17-2015 11:37 AM
tylerginevan
04-27-2015 12:29 PM
Civicchicky87
Idle Issues
04-22-2015 07:16 PM
