Can i change oil filter without changing oil
Rep Power: 0 Can i change oil filter without changing oil
Hey whats up guys . Alright last night i changed my oil but i had the wrong filter so i had to leave the filter i had on . Now that i have the right filter , can i change the filter without changing the oil ? Cause i dont know that if i take the filter out with the oil still inside the engine , if the oil is just gonna come out the oil filter hole or not . thanks for all the help.
Rep Power: 290 When you left the old filter in there, it had maybe half a quart in it of dirty oil. As soon as you cranked the car, it circulated that dirty oil with the new oil. But there's not that much oil in the filter. They're really small.
Check the oil with the dipstick before swapping the filter and changing it all over again. If you think it's really dirty, change it and the filter. I doubt the little bit in the filter would justify changing 4 quarts again.
Regardless, if you put a new filter on there, you'll need to add some oil to replace what was in the old filter.
Cracka
Rep Power: 0 Originally posted by Unleaded
if it were me, i'd change the oil again even if it was 1 day old. new oil + dirty filter = dirty oil.
same here, look at the color of your oil after a day, or a few hr's of drivin, i bet its dirty looking still
id change it all again
Rep Power: 287 Man Honda made those filters a PITA to get off! I remember the first time I changed mine I had to puncture it with a screwdriver just to get leverage - the chain wrench I had kept slipping off......bastards!
Rep Power: 0 Am i the only one who thinks this is kinda pointless? If you put in a new filter, it will FILTER out the dirt and contaminants in the oil. The reason why you change the oil, is to put fresh oil in with all of the addatives that come with it. You can just chage your oil filter, without chaging the oil, the filter will get all that crap out of there. Plus, it wasn't very much oil to begin with. Modern Oils are much better then the oils of old... The 3k change limit and such aren't really necessary, if you look in the civic manual is says to change every 10K miles, BUT this is only if your car burns a quart every 3000 miles. (so basicaly you're replaceing your oil at least once before you change it)
I would just like to say once again, it's addatives, that are so important. If the addatives didn't burn off, then you'd basically never have to change your oil.
-Mark
-Mark
Rep Power: 583 I paid too much money for my civ to not take care of it, some of u may flame me for this, but i change my oil every 2,000 miles. Yes, it may be pointless, but for as cheap as an oil change is, i will continue to change it every 2K. As for taking off the filter, yes, it is a PITA. I used a big pair of channelocks to get it off and tightened it by hand when i put it back on. Gotta love engerneering !!!
Rep Power: 290 I man-handled my filter off. Fear the bellz death grip!!
Anyway, the fram that I got to replace it with has a non slip edge to it that makes it easier to tighten and easier to break loose. It's #PH7317 if anyone wants to try it.
Rep Power: 0 I think the factory torques the filters on and because of the extended drain intervals now, the gasket really sticks to the block. I sprayed some WD-40 around the gasket, let it sit for 10 minutes and then the factory filter finally came off.
Rep Power: 0 you guys know your supposed to put new oil on the rubber seat part of the filter, right. when i change my oil, about every 2500k i pour one quart through the engine to "Wash" out and metal shavings or dirt. i can always get the filter off with my bare hands, i think you guys are doing something wrong if its that hard to get off.
Rep Power: 583 Yeah, i always take my finger and rub new oil around the seal to lubricate it. I never did try "flushing" it with new oil though. I don't know if that would do anything or not, maybe it is just personal comfort knowing that u did that.
Rep Power: 0 well, me and my older brother have the same car (01 ex manual) his is red mine is black. my dad buys oil by the case and we always have one left over so i just got in the habit of doing it. but usually you can see it start out dark and get lighter as you pour it through. so it might do something. you just never know.
RIPSAW
11-06-2015 04:36 AM
Unleaded
06-26-2007 09:25 PM
