Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Help! IAC valve & P0505 driving me crazy!!!
Old 06-13-2010
biederboat's Avatar
biederboat is an unknown quantity at this point
Somehow I knew this would happen. Daughter's 98 EX 5-spd CEL went on a while back, P0505 (IAC fault). I researched, cleaned out the valve (a few times), no help. The car came with a cold air intake, I installed a factory air cleaner assy. As she just got back from college, I finally installed a new IAC valve. CEL back on!
Aside from the CEL being on, the other symptoms are: When decelerating, engine will idle down, bounce up a bit, then settle to 1K on the tach. It will occasionally "buck" when accelerating. When I've cleaned/changed the valve, there has always been coolant at the valve. Also, when I disconnect the air intake hose as the throttle body and put my finger over the intake to the IAC, it idles down nicely (did this with original and new valve). Bottom line, repalcing the valve doesn't seem to have helped a darn thing.
Any final things to try before I give up and go to a shop?
Thanks,
Biederboat
biederboat is offline
Old 06-13-2010
Re: Help! IAC valve & P0505 driving me crazy!!!
sounds more like a bad tps sensor. i would look for a whole used throttle body to swap in. usually $50 on ebay. and be sure to get a 5-speed version. if rpms bounce around or go up on their own, its a tps issue. iac issue only causes idle drop and stalling. usually iac sensors do not go bad, they only get clogged.its much more likely for tps to go out.
Old 06-13-2010
biederboat's Avatar
Well, I just looked online, TPS's look to be around $40, is there any reason why I shouldn't just do that as opposed to the used throttle body? Does the sensor actually move the butterfly or something else that would cause the amount of air flow (or something else) to change? When I heard "sensor", I think of something that just measure, doesn't actually move anything.
Thanks,
Biederboat
Old 06-14-2010
Remebers the old days
CrewChief's Avatar
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
The TPS regulates the injector signalalong with the MAP sensor. If its faulty it could be adding or pulling fuel at the wrong times. Its an easy change.
CrewChief is offline
Old 06-15-2010
tps is easy to change, but hard to calibrate the voltage. swapping in a whole piece is much easier and faster. it tells the ecu how far open the butterfly valve is. on an auto trans it can cripple the car if not working properly.
Xuhme
21
08-07-2023 03:40 PM
Misfit2613
Brakes
26
09-01-2018 05:02 PM
Supramk3
05-11-2015 07:55 PM
mievil
04-28-2015 11:02 PM
smmahan
04-15-2015 08:17 PM
Quick Reply: Help! IAC valve & P0505 driving me crazy!!!
