What kind of engine oil would you recommend for a 1999 honda civic
Old 08-05-2010
rocky12345's Avatar
rocky12345 is an unknown quantity at this point
Hello Guys,
What kind of engine oil would you recommend for a 1999 honda civic with a 1340 cc engine.
I just bought it and the previous owner was using a 40 grade oil. My mechanic is recommending that I upgrade to a 20w 50 oil.
What would be the advantage of doing that and what type of oil would you recommend.
Old 08-05-2010
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Re: What kind of engine oil would you recommend for a 1999 honda civic
Civics are meant to run with 5w30 for economy, changed every 3750 miles. You can run 10w30 in the summer time, but it's not necessary. I've never heard of anyone running that thick of oil.
I run castrol or valvoline regular, but I find the whole oil debate a bit theoretical.
Old 08-05-2010
no text
Old 08-05-2010
5w30 will be just fine
Old 08-05-2010
Honda recommends 5w20, most of us prefer 5w30. Also, i put 20w50 in my F750, putting that in your civic would probably result in you giving your mechanic more business than you'd like.
Old 08-06-2010
Low and slow!
02civicsi02's Avatar
Ya honda recommends 5w-20 but 5w-30 turns out to be alot better especially during hot weather. So use some 5w-30 and I either use castrol or mobil1.
Old 08-06-2010
Trance Addict
MelJ's Avatar
My vote is also for 5w-30.
Old 08-06-2010
I'm scratching my head at how the original poster came to the conclusion that he should run that thick of oil.
Also, for you transmission, get the honda stuff for either auto or manual because you save in the long run.
Old 08-06-2010
the 5w20 recommendation is only for 01+ civics and only because they wanted to get slightly higher mpg numbers. has zero relevance to the engine specs or operation. many other car companies have done this too, in some cases using the exact same engine as a previous model year. older civics pre 2001 are all recommended 5w30.
Old 08-06-2010
Nosepicker's Avatar
Nosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the rough
5w-30 Mobil 1 Full Syn!
Old 08-11-2010
rocky12345's Avatar
Thanks Guys. Appreciate the help.
Old 09-21-2010
ottotheclown's Avatar
ottotheclown is an unknown quantity at this point
Do you know Motorcraft 5-20 works very well. It is made by Conoco Phillips who will be suppling oil now at the dealer level rather than Mobil who did just that for years, At Wally you can find it $14 5qts. Good bang for the oil buck.
Old 09-21-2010
i thought honda was switching from mobil to kendall?
LionSpratt
01-29-2017 11:07 PM
Rinzlor
04-24-2015 10:33 AM
aultman1990
04-19-2015 07:14 AM
Quick Reply: What kind of engine oil would you recommend for a 1999 honda civic
