DIY: Changing Spark Plugs w/pics (noob version)
Old 07-28-2007
I wil fix vBPlaza today
LT2004ever's Avatar
Post DIY: Changing Spark Plugs w/pics (noob version)
Ok, yea its simple, but hey alot of people want pictures instead of just an explanation. So here we go for all the noobs, so i will not use a bunch of confusing terms. This was done on a 01 civic Ex
All parts used
screwdriver
socket wrench
torque wrench
extender
3/8 spark plug lug
spark plug gapper (not shown)
note: Let your car sit, and your engine cool before starting this
First remove your little wire cover on top that sez Honda or Honda vtec
now take off the little caps right here
then you will have to disconnect the harness on top.. Should look like this
Now pull that sucker out! should look like this (i had to usee the screw driver for one of mine cause it was on there pretty good)
now attach the extension on ur wrench, and put on the spark plug lug and stick it on down there
rotate counter clockwise till it comes out, heres what mine looked like and they have never been replaced i believe. unless the first owner replaced them
now the new ones
comparison
Check out this link http://www.ngksparkplugs.com/tech_su...qs/faqread.asp
If you have iridium plugs generally The DENSO Iridium Power plug comes pre-set with a protective sleeve over the firing end, to protect the gap from accidental alteration.
As for other plugs at this time go ahead and check the box to see if they are pre gapped, if not gap the new plugs with your gapper tool... should be .044
No pic
heres all of them once i removed them.
Now guys if u are gonna take pics like me cover up the holes so that nothing falls in there. Just a precaution, i put the tubes back on in all the holes while i took pics
now when puttin the new ones in go ahead and attach the plug to the end and slide it on down there, and being to screw it in with your hand using the extension, untill its gets snug. do it for all of them, and with the torque wrench torque them to 13ft/lbs
once u are done putting everything back on, u are good!
Originally Posted by mdawg
I have the NGK Platinum spark plugs that im going to be changing tomorrow. I was told that they would not have to be gapped, is this true? Also is it a major downfall If I do not have a torque wrench(I know if they are not in enough I will have a rough idle). Thanks for the write up!
truth, you dont have to gap them, but i just checked to be safe, cause u never know. if u dont have a torque wrench, u will still be good, but just be careful with them. Like remember how it felt with another plug. But remember dont torque it waaaaayyyy tooo much ya know. just get them in there snug. Think of it like this, they will heat up, and therefor the metal will expand or what not. Heat makes metal soft and for xxxxxxmiles u drive ur car they will be getting softer and harder depending on the heat. Now if u over torque them in, then i guess there will be a higher chance of them breaking off in there later on when they are replaced again. but yeah, just get them in there snug and u will be good.
Originally Posted by gearbox
iridium is better than platinum, due to the thinner center electrode. platinum really has no benefit other than long life. it is worse conducter than copper so if you want upgrade plugs, dont get platinum. iridium also lasts longer than copper but has an ordinary ground electrode so they do not last as long as platinum . for some cars like the rsx, there is a laser iridium which is a normal iridium plug with a platinum ground electrode, which gives it the benefits of smaller iridium electrode and also longer life of platinum plugs. but they are expensive like whoa.
Old 07-28-2007
slowwhitecivic's Avatar
slowwhitecivic will become famous soon enough
Re: DIY: Changing Spark Plugs w/pics (noob version)
does it feel anythin different? cuz they arent exactly cheap..lol cuz i was gona change them out but not sure if they are worth it.
Old 07-28-2007
This is Myspace
DsevenEm2's Avatar
^^ wondering the same, good write up LT..id give u sum rep but...i have to spread some around apparently.
Old 07-28-2007
You Stay Classy, San Diego
jamis33's Avatar
thanks for that little bit of info. It sure beats paying honda $100 to change the plugs with the same crappy denso plugs. And just incase you guys were wondering. NGK irridium IX plugs do go on sale. At least where I live they had a buy 1 get one 1/2 on all NGK iridium plugs a while back. Next time they have em on sale im gonna get some.
Old 07-28-2007
mdawg's Avatar
mdawg is on a distinguished road
Old 07-28-2007
LT2004ever's Avatar
Lol the rep system again, but you 2 as for different feeling, i dont know yet i havent really gotten down on it yet, i was just taking it soft for a little while, but i will keep everyone updated. imma put a review in the parts review thread after tonight and driving, then i will update my double your gas mileage thread
truth, yuo dont have to gap them, but i just checked to be safe, cause u never know. if u dont have a torque wrench, u will still be good, but just be careful with them. Like remember how it felt with another plug. But remember dont torque it waaaaayyyy tooo much ya know. just get them in there snug. Think of it like this, they will heat up, and therefor the metal will expand or what not. Heat makes metal soft and for xxxxxxmiles u drive ur car they will be getting softer and harder depending on the heat. Now if u over torque them in, then i guess there will be a higher chance of them breaking off in there later on when they are replaced again. but yeah, just get them in there snug and u will be good.
Old 07-28-2007
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
travis, you couldnt get that sway bar on but you can change the **** out of some plugs. mdawg, do not gap platinum plugs. you will bust the hell out of the electrodes. and no you dont need a torque wrench, just dont go ***** out trying to tighten them til they wont turn anymore.
Old 07-29-2007
LT2004ever's Avatar
gotcha, but for coppers, and for iridium, u need to check the gap right?
AND YEA i can change stuff in my engine, but other than that it all is seized and sucks!
Old 07-29-2007
Received 1,146 Likes on 801 Posts
If you don't have a torque wrench, hand tighten the spark plug until you feel contact, then use a ratchet/wrench to take it an additional 1/4-5/8 turn.. That'll give you the approximate torque spec for them.
I forgot where I read that, but that's how I've done it in the past.
Old 07-29-2007
speedfoos's Avatar
Props for the old-school torque wrench Travis! Nice little DIY. Every one of these simple ones helps for folks just getting in to wrenching on their Hondas. Good stuff man. Rep when I'm able to again!
Old 07-29-2007
sl33pyriceboi's Avatar
when ur taking close up pixs, use MACRO...macro is for that specific use...its the pix with the lil flower on it.
Old 07-29-2007
nice writeup. i love how easy they are to change. i recently put in some $50 denso iridiums but didnt feel any difference over the coppers i had before. and if you use iridium, do not gap them or you will break the center electrode off.
Old 07-29-2007
karlozc2003's Avatar
karlozc2003 should not be trusted
which one is better guys platium or irinium?? Im so confused!
Old 07-29-2007
CivicHX01's Avatar
most plugs come pre-gapped... and iridiums can't be gapped anyways... the tip is too small and fragile...
Old 07-29-2007
Old 07-29-2007
LT2004ever's Avatar
lol my camera is old... and i dont have macro, or i woulda used it. lol
Old 07-29-2007
Thanks . Im gonna pick me some NGK's irinium today. Kragen has them for $5.49 each. I called and ask. BTW stock #6441
Old 07-29-2007
lordhelmet's Avatar
Make sure to lube up the boots with some antisieze
Old 07-29-2007
DDragon7's Avatar
Good job on the DIY article. I got my plugs for over a year and I still havent changed them yet.
+1 Rep
Old 08-01-2007
psitsruben's Avatar
psitsruben is an unknown quantity at this point
hey, has anyone heard about those new pulstar pulse plugs? I wanted to know if they really are better if its just a rip off.
Old 08-01-2007
Dticalman81's Avatar
Dticalman81 is an unknown quantity at this point
Great DIY.... now I'll shall change my spark plugs, back to Denso Iridiums.. Good Job LT.!
Old 09-05-2007
Does it have to be exactly at 13ft./lb??!?!?! I dont know if i want to purchase a 'torque' wrench.
Old 09-05-2007
LT2004ever's Avatar
no, all u have to do is get them in there snug... dont torque it like u would your lugs on your tire, but just make sure it feels snug. When u take the first one out u should get a feel of how tight they need to be
Old 09-05-2007
mdawg's Avatar
I changed mine a while back, now my starting problems have got worse. When I hit about half tank was when my engine starts having to crank over multiple times before it seems like fuel gets into the engine. Now its doing it even before half tank, and its an excess of 10 cranks sometimes. I know I had the problem for, but new spark plugs just made it worse, you think they are bad? No idle or driving problems though.
Old 09-05-2007
skoot's Avatar
skoot is an unknown quantity at this point
Sounds like a gap issue with the plugs or one is not tight enough...Also check your battery post and make sure they're not loose
Old 09-05-2007
mikem317's Avatar
mikem317 should not be trusted
BTW, I know it's already been mentioned, but you DO NOT want to gap iridium plugs. I think the electrode on these type plugs is uber sensitive, or something.
I have the same plugs, I love them. I noticed a small increase in fuel efficiency and better throttle response, although marginal.
Old 03-15-2008
dj_cronic_metal's Avatar
dj_cronic_metal will become famous soon enoughdj_cronic_metal will become famous soon enough
changed mine today and used this diy great job
Old 01-10-2009
alejanseren's Avatar
alejanseren is an unknown quantity at this point
thanks for the DIY...followed the steps and avoided paying the dealership $140+. now to figure out how to adjust the valves.
Old 01-10-2009
speedfoos's Avatar
There's a DIY here on the site somewhere. Pretty easy.
Old 01-10-2009
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Omg, you can PAY to have someone put plugs in your car!? I never even conceived of it. And 140 bones! Pinch me.
Quick Reply: DIY: Changing Spark Plugs w/pics (noob version)
