M3 Mirrors with LEDs Install.
Old 02-22-2005
i love my morreale
eddiechaps's Avatar
M3 Mirror w/ LED Wiring instructions:
I chose to go with alternate signal wiring. This means that when parking lights are on, the mirror signal will also be constantly on. When signal is used, the mirror will flash alternately with front signal.
Now first you will need:
18 Gauge Wire
Electrical tape
10mm socket.
0.8mm socket.(5/16”)
Phillips head screwdriver
M3 Mirrors
How I did this:
Since I have projectors, this may be a little too enxtensive for you. But I found it easier to access my wires this way.
1. Put the window down. Pull the piece on the inside around where the mirror is up as hard as you can it should pop off.
2. Using the 0.8mm socket remove the nuts around the mirror.
3. Then , pull off the rubber piece on the miror. Get some wd-40 and a vise grip. Spray the wd-40 all over the nuts. Then after a fdew moments grip the nut & start to loosen.
4. Attach the mirror to the car. In mine I only used two out of the three bolts since the other one didn’t fit properly.
5. Remove the front bumper cover. Here’s how you do that: http://www.7thgencivic.com/forums/sh...d.php?t=155290
6. Follow the DIY to remove your headlights.
7. Unplug the bulbs from the electrical connectors. Cut the wrap around the turns signal bulb’s wires. (That’s the bulb marked 7443.)
8. Locate the red and green wires & strip/cut them.
9. Put the white wire to the green wire if you want the mirrors to light up blue when on with the headlights & to flash blue/amber when you are turning. (only amber will appear when turning without lights on.) Put the blue wire to the red wire. Ground to ground. If need be use some wire to lengthen each.
10. Double check before you put electrical tape around the connections to make sure the right lights light up.
I had a video of the blinking leds but idk where to upload it to so I can use it on here. Hope this helps people in the future. Reply to this post or PM me if you have any questions.
Final Result:
And at night...
Old 02-22-2005
silverem2's Avatar
looks awsome, show us some nighttime pics
Old 02-22-2005
QBoi's Avatar
Wow nice, I was gonna get some, but the car is gone now. How long did it take you?
Old 02-22-2005
i love my morreale
eddiechaps's Avatar
about an hour. the tough part was getting the damn wires fed through the fender to the engine bay.
Old 02-22-2005
QBoi's Avatar
Gotta be longer for us inexperienced fools
Old 02-22-2005
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Is that M3 power mirror or manual?
Good job btw.
Old 02-22-2005
i love my morreale
eddiechaps's Avatar
i never did wiring like that before.
Good job btw.
manual.
Old 02-22-2005
04vic's Avatar
04vic is an unknown quantity at this point
what size wire?
Old 02-22-2005
zachgeyer's Avatar
nice never the less
Old 02-22-2005
zachgeyer's Avatar
ebay?
Old 02-22-2005
i love my morreale
eddiechaps's Avatar
Originally Posted by 04vic
what size wire?
18 gauge
Old 02-22-2005
i love my morreale
eddiechaps's Avatar
Originally Posted by zachgeyer
ebay?
yes inexpensive too.
Old 02-22-2005
silverem2's Avatar
i guess my nighttime pics didnt get a response.lol
Old 02-22-2005
i love my morreale
eddiechaps's Avatar
for ati9700pro
Old 02-22-2005
shmik1's Avatar
didn't I hear someone say m3 mirrors suck and u cant see anything? u should take some daytime pics from the outside (like a normal pic of the whole car) do they flow well with the car?
Old 02-22-2005
i love my morreale
eddiechaps's Avatar
the passengerside mirror does. but the driverside you have to kind of move forwad jsut a bit to see the angle you should see. i never use the side mirrors for their purposes anyway i just look over my shoulder. but yes there is a slight discrepency on the driverside mirror only.
Old 02-23-2005
Black03civic's Avatar
eddie, nice diy man, i am truly impressed. Where these on durring the meet? cus i dont remember you showing them to me.
Old 02-23-2005
i love my morreale
eddiechaps's Avatar
n man. they arrived at my house as i was leaving to go to occ for the meet.
Old 03-22-2005
fuzionms's Avatar
fuzionms is an unknown quantity at this point
anybody have a wiring diagram to wire up the Power m3 mirrors???
Old 03-22-2005
i love my morreale
eddiechaps's Avatar
Search.
Old 03-22-2005
wow nice pics. So it also flashes amber too?
Old 03-22-2005
i love my morreale
eddiechaps's Avatar
Yeah, when the lights are on they flash blue to amber alternatively. & without the lights on they flash plain amber. Although I have the blue wires disconnected so they don't light up. Therefore, I can pass NJ inspection.
Old 03-22-2005
New Mod on the Block
Rennen's Avatar
really nice. good DIY
Old 03-24-2005
i love my morreale
eddiechaps's Avatar
UPDATE: If you want blue to blink instead put the blue wire to the green wire.
Old 03-24-2005
MojoMyCivic's Avatar
MojoMyCivic has a little shameless behaviour in the past
Does anyone know the connection for the powered mirrors? I bought those same lights with white and blue blinkers, but I don't know how to set up so that they'll be powered. It only comes with three wires for the power, but when I opened up the OEM ones, there's a plug. Any help will be appreciated!
Old 09-04-2005
diskreet's Avatar
here is a good question... can i hook it up to be on all the time, like a running light. and then blink with the turn signal. this would work when i have my lights on if i tap the 1 wire for the 7443 bulb but when the lights are off then it wont light up at all. that would suck. any ideas? other than a relay on each side for each mirror?
Old 09-04-2005
there are two wires coming from the mirror led, power and ground. Hook one up to parking light power, and the other to signal power. One will act as a false ground. So what you get is always on with parking lights, only flashing when signal is on, or alternate flashing when signal is used AND parking lights are on.
Old 09-04-2005
i love my morreale
eddiechaps's Avatar
the way i did it showes you how to exactly do that.
Old 09-07-2005
Rep daVinci's Avatar
Rep daVinci will become famous soon enoughRep daVinci will become famous soon enough
do you have to have power mirrors in order to install these b/c I was thinking of getting them don't have PM.
Old 09-07-2005
<---- I am really this short in person!
fullgrown's Avatar
fullgrown is an unknown quantity at this point
isn't it illegal to have blue lights?
Quick Reply: M3 Mirrors with LEDs Install.
