View Full Version : Forced Induction and Swaps
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. guages for nitrous questions...
  2. guages for nitrous questions...
  3. boost controller
  4. explain fuel return system difference and our fuel system
  5. Dual exhaust good for boost?
  6. Highest PSI Attained To Date
  7. what dumb A$$
  8. what exhaust do you have in your Turbo'd civic?
  9. Fuel injector question
  10. Turbo
  11. Internals
  12. What is the best turbo kit?
  13. FYI::HKS New Manifold Cheap$$
  14. need a quick explanation
  15. broke loose!
  16. SF turbo kit question......
  17. to run 10psi daily on a AT...
  18. another SF Turbo kit group buy? Anyone interested?
  19. 15 pounds of boost
  20. Acceleration
  21. Best swaps
  22. turbo k20 civic
  23. 2K1 Civic makes 332.1 HP UPDATE***
  24. Liquid intercooling system
  25. Nitrous Recipe
  26. Blocks the same on the LX and EX?
  27. Turbocharger FAQ
  28. k20a swap and emissions
  29. Nitrous Equipped Civic
  30. K20A3 Swap
  31. Turbo RSX types makes 15'sec
  32. Buying Sf Kit!!!
  33. nitrous
  34. Post your turbo set up here
  35. catalytic converter ?
  36. LS swap in my 95 dx hatch
  37. Alcohol Inj Recall!!!!
  38. First turbo'd 7th gen hx
  39. golden eagle vaccum line router
  40. Will the SF turbo kit fit a 2k1 civic ex auto?
  41. Retard your ignition timing with this!
  42. turbo for sale?
  43. E-Ram Electric supercharger
  44. cryO2
  45. Porting out the throttle body?
  46. Who has larger injectors?
  47. what would be the best engine to put ina hondda civic
  48. Turbo Kit w/Intercooler
  49. D17 internals.......
  50. Catalyst...
  51. motor mounts???????
  52. forced induction
  53. retard timing
  54. prep for nitrous?
  55. Headwork
  56. I need phone number for sf!
  57. Negative Effects
  58. More Internal Info!
  59. Looks like a Turbo Discounters turbo on ebay
  60. My SF Turboed Civic Passed Emissions
  61. BMW swap?
  62. vtec engagement and turbo
  63. Boost spikes and BOV's
  64. sf turbo question
  65. I told you it was big!
  66. Help on my turbo setup
  67. Turbo Discounters Injector Interface
  68. Pictures of my kit! Finally...
  69. 400 shot on a 350z?? video inside...
  70. K20A swap or turbo
  71. Small Shot
  72. Small Shot
  73. K20 A/T Swap?
  74. fuel system settings
  75. K20 or SI motor and tranny swap referalls?
  76. Fuel Pump Booster?
  77. Dyno Sheet @ 11 PSI
  78. ball bearing turbo good?
  79. JE Piston Specs for Turbo Applications
  80. redlinin'
  81. Turbo or build motor?
  82. Edelbrock Wet Kit!
  83. Greddy Profec B Turbo Boost Controller
  84. Turbo Questions
  85. turbo please
  86. My path has been chosen...
  87. HKS Turbo Manifold D17
  88. tranny swap
  89. How long should engine swap take?
  90. futureRSX... wtf...
  91. VAFC/SAFC for adding fuel with turbo
  92. help me choose..
  93. More info on the Aeromotive digital FMU!
  94. Making turbo 2k1s safe
  95. Boost in neutral???
  96. 8 psi delsol
  97. you have turbo? help me..
  98. K20a2 Swap!!!!
  99. K20 K24
  100. Anyone running with a wideband O2 sensor?
  101. amount of oil..
  102. Turbo and Intakes
  103. help to buy k20a engine japanese only
  104. SF turbo kit installed
  105. Spraying to cut lag?
  106. RSX type-s and type-r
  107. Let's talk about BOV's...
  108. turbo timer help
  109. super afc II
  110. NXand ZEX Remote Bottle Opener?
  111. anymore turbo'd civics in VA?
  112. what do u think about this?
  113. turbo timer question
  114. For those how have the TD kit
  115. when my turbo spool i hear weird noise help
  116. NOS Jet Size?
  117. K24 and D17 Valve sizes?
  118. For those with Alcy injection...UPDATED WITH LINK
  119. K20a2 Swap Parts List Needed
  120. Best trim (LX, EX) to do swap with?
  121. i need help ASAP!
  122. Purge Action
  123. Results of a K24 with some bolt-ons.
  124. Making custom boost gauge, need MAP sensor information
  125. Returnless Fuel System Digital FMU
  126. DH Racings Turbo Kit?
  127. Emanage question.
  128. has anyone tried a 100 shot on the stock d17?
  129. tranny swap?
  130. Question about installing new piping from Headers to Exhaust
  131. turbo!
  132. SF auto turbo to manual
  133. FS: '02 Si motor/tranny (K20A3) w/ EXTRAS.....
  134. What happens when you use hydrogen or helium gas in ur engine
  135. launching a boosted civic
  136. dh-racing turbo!
  137. rsx-s need help with build up
  138. Im about to drop another G on my turbo setup
  139. Doing a K20A Type-R swap
  140. Turbo setup (pictures! 56k death)
  141. Anyone using a HKS AIC or Haltech F5?
  142. Who has the fastest 7th gen?
  143. Need to upgrade clutch w/ a turbo kit?
  144. Catalyst's Next Project.....
  145. SF Turbo or K20A2 sawp: That is the question!
  146. Installed SF Kit, to adjust boost...?
  147. Anyone have ideas of new types of Forced Induction
  148. Garrett Turbo and SF Manifold
  149. Jdm Integra Type R Dc5 Rsx K20a
  150. Compensating for altitude
  151. rsx engine!
  152. k20a3, k24
  153. Turbo install is done!!! SF RULEZ!
  154. I Have Created It!
  155. My EG Project
  156. anyone dynoed?
  157. Excess blow by from breather
  158. turbo kits
  159. please help me 03 ex turbo kit
  160. swap help
  161. Boost controller
  162. something you k20 boys should jump on
  163. Swapage
  164. SWappage
  165. Someone hit delete.
  166. Turbo Compression
  167. VIDEO of me at 4.5psi, 1st through 5th
  168. Supercharger for 01 - up civic... on the way
  169. Bought a spearco intercooler today.
  170. Check out this swap !!!!
  171. Water injection
  172. SF turbo or K24 with k20 head??
  173. 91 octane for turbo??
  174. what is the nx kit # please!!
  175. alcohol injection?
  176. SF turbo GB now available
  177. SF Turbo kit safe?
  178. More FI - Turbo Performance PC?
  179. Anyone happen to get the E-Manage ignition harness working yet?
  180. Trubo tuning issues...need some help
  181. so close, yet so far away
  182. Which BOV is better ?
  183. Engine swap....not very necessary
  184. dynos
  185. Turbo AND Nitrous
  186. Bout how much does a turbo system weigh
  187. vortech fmu
  188. supercharger or turbo??
  189. valve timing
  190. D17 or K20 Port Work Anyone?
  191. OMG a TURBO KIT I NEVER SEEN
  192. Sleeved block alternative. Block posting?
  193. look at this manifold
  194. The electric supercharger from hell!
  195. Avc-r
  196. K20 swap into an EG
  197. Frankenstein vs. TSX
  198. turbo!
  199. rode in a boosted 7th gen for the 1st time
  200. SF turbo questions?
  201. Finished my tranny swap
  202. 99 Ex w/ turbo......
  203. fuel for turbo ?
  204. Lx to Ex ?
  205. Boosting D17....waste of time ?
  206. turbonetics deltagate
  207. Anyone feel like taking a dump?
  208. Wow.
  209. automatic LX turbo
  210. k20 help
  211. the h&d turbo
  212. Anti-75shot???
  213. For SF turbo owners
  214. Turbo Sizes?
  215. ebay: MISSING LINK TURBO MAP FIX 01-04 CIVIC & RSX
  216. Hks Turbo
  217. Poll: K20 or turbo
  218. Intercooler Piping
  219. $$$d17$$$
  220. quick question
  221. blowing up engine
  222. turbo tuning
  223. building motor
  224. another boost question
  225. emanage parts needed>?
  226. Swap?
  227. Auto Trans..turbo Civic Owners Talk To Me...
  228. ANYONE with an AUTOMATIC and NITROUS
  229. bov q
  230. anybody know of a manifold i can use with a greddy t3 turbo
  231. HKS down pipe
  232. Need Help for Turbo Decision
  233. Greddy e-manage
  234. Quick question, need help!!!
  235. question about turbo...
  236. K Series: CTR vs. RSX-R
  237. sick of being slow
  238. clutch question to those with speed
  239. Post Pics
  240. Tuning?
  241. lowering the compression=lose power?
  242. Body style: Civic or RSX?
  243. gotswap? 11's here I come
  244. V-afc II
  245. What gauges would be most usefull???
  246. what swap
  247. Swap Guys!?!?!?
  248. catalytic converter ?
  249. RSX interior swap
  250. Mild steel turbo manifold
