- AEM FIC vs GReddy E-Manage
- P1106 & Misfires revisted
- D17 yet again at the shop
- crower rods issues please help asap!!!
- Hondata for d17a2 manual
- The results from our turbo kits (quantified)
- Blown Turbo!
- whats the best route to take?
- VTEC engagment and limp? - The VERDICT
- Turbo Guide
- vafc2 ?
- d17 at 250 whp
- coolent line to turbo
- I still haven't fixed anything...
- BOV Sound
- turbo for 02 ex
- Deatsch 525cc injectors
- Help!!!!!!!!!!
- Frankstien hybrid pistons in a non-frank k24???
- downpipe for t3 t4 turbo
- Question about K20Z1 into EM2
- eh....almost there(special K)
- RBC intake mani fitment???
- Hondata ECU Hybrid Racing Wiring
- |Dezod Motorsports| The end all of D17 turbo posts...
- HELP! Can i mini-me a D17A2 head into D17A1 engine?
- Question about BDL 70MM Throttle Body on K20Z1
- srt4 injectors
- Ex Engine Swap Need Ecu Help!!
- Oil feed tube length
- Sometimes you just get lucky...
- Ex 02 Sensor Wiring Harness
- dash harness
- finished tranny swap, quick questions
- Quaife LSD Update
- loook at my new turbo goodie!!!!!!!!!!!
- unknown boost problem
- For those on K-Pro
- Missing Link
- KPro and o2 sensors? WTF? Learn how it all works...
- T28 turbo kit on ebay...
- D series supercharger.
- tapping noise..HELP
- Manifold
- I finally took it to the track...
- K20a3 Throttle Body Clearance, Help!!
- side mount IC good for 250+whp?
- MY block, IM, and ecu.
- vitara pistons and d16 eagle rods into d17?
- Look at what happened to my manifold!!!!!!
- B18 swap possible?
- I need help!!
- K20a3 AC Compressor Wire up
- need turbo oil help
- Powersteering Cooler
- F/IC Tuning !
- Mechanical Oil Pressure gauge install?!?!
- brand new pictures of my turbo just completed
- K-ECU wire up. Need Help!! (images)
- Which Header and Downpipe to use for a K20A3 swap?
- 10 months in the making ***teaser vid****
- Vacuum question
- Ecu problems. PLEASE help
- How much psi can the auto tranny take?
- ok its official!
- Intake Question ...
- fuel return line help!!!!??? asap
- k20 question
- Less boost than usual + exhaust louder = relation?
- If you did a k20 swap and wana run a/c but have problems with a 3 wire.. read here
- Fuel Injectors
- Headgasket gone.... AGAIN
- Subframe Help
- turbo rebuild problem civic 1.4 turbo
- |Dezod Motorsports| New, more cost effective connecting rods!
- questions for the turbo gurus
- 16.0 @ 87mph, wtf is that...??
- New turbo install has begun
- K20A into EM2
- And So It Begins
- B18C ITR or B16B CTR
- Throttle Body swap.
- help: replacing head gasket
- K Swap Axle Question
- What happen
- MagnaFLow Cat back hangs too low?
- Turbo Question
- ARP headstuds torque
- K23 Swap
- random problem leads to more random boost problems
- New part....
- clutch and boost
- Stock ecu gone bad!!!
- K20A3 Swap w/AC and Power Steering
- My motor build.
- DC5 Intermediate shaft?
- rsx injectors
- mini me head swap + fic turbo wiring help
- boosting auto civic
- KPRO Boost Control & Lean protect
- where the hell did my exhaust thread go?
- DX/LX to EX head swap
- ARP torque
- K1 Technologies rods that DEZOD sells
- Technical Boosting Questions
- d16y8 mani swap asap helpp
- Removing K-series tranny
- E-Manage Subinjectors
- boost questions
- D17 Turbo Feed Line Size
- emjay's Dezod D17 kit in action
- turbo a a/t civic
- Anyone Know?
- Quick K20 Questions ALMOST DONE!
- if neone can give me any knowledge on good kits for a 1999 gsr engine into my 2002dx
- Swap or build and boost?
- k24/20 finally done
- is this turbo usefol for my d17?
- Continued...
- VW TDI swap
- My Motor Build.
- Where Does The Battery Go????
- standalone ems
- breaking up while driving
- K20 Type R Internals
- Hondata k-pro
- Where can i get a top mount mani for a d17?
- Where do I find...
- Dezod Turbo kit...
- ? Maximum Horsepower ?
- 100+ shot
- what is the best motor to swap with for a 97 civic ex
- Sac raceway 4th of july NEW set up RUN!!!
- vtec head question
- best piggy back ems
- vtec swap o2 sensor codes HELP!!!
- Automatic To 5 Speed Conversion
- which head sud i put on a k20z1 block ?
- Have K20a3 swap wanna go JDM K20a
- em2 k20 swap subframe help
- B-20 swap
- type-s brakes and motor in 01 civic
- 99 motor swap into a 94
- Y8 mani ON the D17
- How to install autometer boost gauge???
- swap questions
- Misfire
- Misfire
- Secondary o2 Sensor Wiring on DX/LX K-Swap
- K20a2 Engine + K20z1 Tranny into an EM2?
- 50 shot dry= stock injector duty cycle?
- FS: K20A3 O2 Sensor $75+
- D17a2 Zet Kit Help
- need help!! y7-y8 swap
- K20 Swap Serpentine Belt Change
- parameter setting for emanage ultimate
- Toasted cylinder 1 plug w/ 50 shot!
- D17a2 Dyno results
- is it possible to change a 01 civic front end with new headlights, bumper, and grille
- 7th gen jdm
- Possible B Series swap??
- Upgrade to E-Manage Ultimate
- Tuning Shops
- HELP Plz
- Emanage vs Kpro
- my d17a2 built wit turbo project still under construction
- k20 swap help!!!!!
- D17 turbo parts HELP!!!
- Good Turbo?
- Not a covered swap question
- J's or Ingalls torque dampner
- Turbo Help
- Questions from a newbie
- P0134
- 04 Civic turbo exhaust downpipe routing
- K-Pro Help
- Building a Homemade Turbo
- Turbo help?
- Crower turbo cams Question!! and d16y8 Intake manifold Question!!
- Swap or not
- Nitrous build, new to forum.
- K20 swap buisness / company in Ontario Canada?
- CAI and remove CAT - How much horse power?
- need specific info on k-series vs. b-series
- need info on a tranny swap
- wanting to swap motors
- auto to manual help?
