View Full Version : Forced Induction and Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22
  1. Installing E-manage Ultimate. HELP !!!
  2. Anyone have a base map for 01-05 lx?
  3. emanage? help?
  4. AEM EMS on D17
  5. Emanage Tune? Which is easier?
  6. Closed Loop Matter?
  7. Ordering AEM EMS 30-1030U
  8. D17 evolution occuring....witness it 1st hand!
  9. Searching For A Fuel & Ignition Managment.
  10. FUEL RAIL,which one to modify
  11. Biggest Turbo to fit on Dezod Mani w/o fitment issues
  12. Ck Out My Civic Turbo Video// DYNO RESULTS ,LAST PAGE.
  13. Driving with wastegate open, is it that bad?
  14. best k20 k24 pair
  15. Having A Problem W/misfire Over 5500 Rpms.
  16. turbo specialties or dezod
  17. Who Offers Great Prices On Garrett Turbos
  18. Swap Qustion
  19. clutch problem
  20. Tunning the car this weekend (that didnt happen)
  21. SixSigmaRacing Header for the RSX/DC5
  22. Thermostat Question With Or Without.
  23. New dyno inside
  24. Question about N02!
  25. E-Manage keeps crashing??!
  26. Speedfoos' Turbo shopping list and Tips thread (August 2008 update)
  27. HELP - OBD2 OBDII ECU Connection Emissions??
  28. Turbo Setup For The Philippines (PICS)
  29. My New Turbo Set-Up Thread
  30. 5 Speed swap help!!
  31. Most of my kit is here :D Picz :D:D
  32. TSI Base Map
  33. Turbo Specialties kit
  34. ITB's?
  35. Base map for Sf kit
  36. EL mani comin back? MAYBE so...
  37. Thinking about a swap...
  38. 2ndary O2 sensor help!!
  39. DIY: D16Y8 Manifold on D17 + fuel pump upgrade and return fuel line
  40. intake manifold choice for turbo setup
  41. So my turbo just got installed...but how to make car run normal
  42. Having A Problem With Boost Pressure.
  43. K20A swap
  44. Acura RDX swap
  45. Some cool tuning and exhaust related results
  46. Turbo set help please
  47. Anybody with a TSI kit please read
  48. Where would oil leak from?
  49. 750+whp RSX
  50. I'm still alive. *UPDATE*
  51. The need for more power!
  52. D16 or B18B rods in D17?
  53. DC5 Radiator on EM2 Kswap
  54. Custom Intake Manifold For Civic 01-05 D17
  55. rdx injectors d17a2
  56. Commence Motorbuild... DYNO GRAPH (PAGE 12)
  57. I Need New Injectors!!!
  58. k24/k20 transmission questions
  59. JRSC Dyno Inside - A3
  60. k20 type R swap in 01 civic ex
  61. k20 swap 1/4 times
  62. K24 swap question
  63. D17 Injector options
  64. Cheaper Denso Irridium IK20 alternative?
  65. Burning oil bad
  66. i want a k20
  67. clucth stages
  68. Turbo or Swap..Which is better for canyons?
  69. Where to buy the SF wastegate?
  70. rsx-s injector set-up problem? please help!
  71. Confused as Helll!!!!!
  72. dezod kit wut else needed?
  73. New dyno numbers SHOCKING! NEW VIDEO AND PICS on pg 7
  74. Ummm....did i blow my turbo?
  75. D17 Turbo manifold options @ Dezod
  76. EM2 redynoed!!!!!!!!!
  77. older d16 head into a d17 block ?
  78. what wastegate do i need?
  79. Turbo Question
  80. I got a problem with turbo
  81. Hondata & Wideband Conversion
  82. Ebay T3/T4 turbo
  83. k-swappers w/a/c....
  84. Wtf?
  85. OBD2 emissions with a k-swap???
  86. Subframe Question... Additional parts required?
  87. New AEM Piggyback (Seems VERY promising)
  88. XFC on N/A EM2
  89. Triiiiiiick new BOV. No welding required, no flanges either
  90. Exedy Pressure plate with OEM clutch disk?
  91. the whole heating up at a stop thing.. **UPDATE 7/14/07 post 22**
  92. What is this?
  93. Turbo Setup
  94. Other D-series parts
  95. Opinions on my Goals - 03' EX
  96. Good Thread to state your opinions!
  97. Walbro 255lph Fuel pump w/ Install Kit
  98. Boomslang Plug-n-Play
  99. H22A redhead in a 05 civic???
  100. Pop Goes The Headgasket.
  101. FORCED INDUCTION or N/A....why?
  102. intercooler piping ?
  103. buy hole or assembel??
  104. Catch Can Setup
  105. map sensor questions!
  106. Vacuum Manifold
  107. Intercooler
  108. Finally got dynoed! *Graph Posted*
  109. My New Slug
  110. LX to EX head swap with Acura EL head?
  111. Oil Feed Problem
  112. timing on head swap?
  113. Engine dies when full throttle to redline (kpro) (Update September 9-07)
  114. Well, this sums up my weekend pretty well...
  115. ex head swap problem
  116. Is this turbo kit any good?
  117. is this safe...
  118. installing A/C on k-swapped 7th gen
  119. fuel questions!
  120. k24 swap with a/c
  121. Looks good to me...
  122. Up And Running Again.ck It Out!!
  123. Help with AEM F/IC fuel/ignition maps (updated)
  124. stock injector wiring question
  125. ATTENTION kpro d17s
  126. k20 em2 exhaust fitment
  127. swap options...
  128. Dezod v3 kit + kpro = 185.5 HP Updated w/ dyno sheet
  129. E-mannage
  130. EMS vs Piggyback (update, post #11)
  131. Engine swap + turbo
  132. swap question
  133. reverse lights
  134. fuel return help!quick
  135. Quick question about UEGO
  136. Golden Eagle Vacuum Manifold *Problem Fixed*
  137. Wideband Sensors Explained
  138. Sick of High Impedence Injector options?
  139. New wideband option from PLX
  140. RS*R ExMag & Turbo
  141. Turbo causing A/C to not work
  142. FAQ; D17 engine internals for turbo (up dated july 07)
  143. New product: Dezod Race manifold
  144. Need a straight answer!!!
  145. D15/D16 Manifold
  146. Replacing TSI system with AEM
  147. My motor at chris shop.Update page 5,6. dezod pnp head.
  148. as i reserch more i get more questions
  149. official Vehicle weight of an Kswap EM2 EX
  150. K20z1 swap into Em2 Please help?????
  151. Attack of the CEL *UPDATE page 5*
  152. Tuning Help & Dyno Results
  153. Pictures Of K20z1 Complete In Engine Bay!!!!!!!
  154. EPS problem...help
  155. TPR Customer Turbo D17a Build
  156. am i just lucky....
  157. Check engine light help
  158. K24a
  159. Front Bumper Fitment
  160. Good news coming for engine building D17 owners
  161. Help! Which ECU do I need?
  162. 04 LX with EX ecu --vtec solenoid error
  163. Engine Building... Looking back from 5000 miles
  164. turbo
  165. Hey turbo cats!! I need help!! 3 easy questions!!
  166. need help with A/c on swapped civic.
  167. Turbo EM2 Help
  168. Vacuum line and Oil Catch Can Diagrams
  169. Quick turbo question
  170. Turbo Spool
  171. K24 Swap Question...
  172. LSD through Quaife is here!!!!!!!!
  173. Intake cam gear isn't adjusting right?
  174. Pics of my Turbo Installation
  175. My valve cover.
  176. My valve cover.
  177. this clutch for the dezod kit
  178. AEM EMS and A/C
  179. SS vacume Lines BnT Performance
  180. car acting up
  181. turbo
  182. A REALLY stupid question
  183. Blown Head Gasket???
  184. aem cam gear
  185. fuel pressure regultor
  186. Turbo timer help!?
  187. Emanage Memory
  188. Results are in on page 10 @ 17 PSI now with vid!
  189. Spark plug non fowlers
  190. D-Series Supercharger
  191. Anyone know how long....
  192. can this be done?
  193. This ought to free up some horsepower....
  194. few questions about externally wastegated vac plumbing
  195. T.E.A.R.S. - Turbocharged Engines Anonymous Relief and Support Thread
  196. turbo specialties forgedpistons???
  197. New to boost. Plan, Comments/Questions?
  198. Cool DSM engine building video
  199. trouble with turbo help
  200. turbo vacum lines
  201. Dezod or TSI?
  202. D17A2 Turbo Vs. N/A
  203. Turbo encounters
  204. 2004 Honda civic Swap
  205. Y8 mani or custom
  206. type-s inner+b-series outter axles for k20/k20 swpas in em2???
  207. Anyone with a K swap I need a small part from the D
  208. Need your help... TURBO gone wrong
  209. Internal of the transmission
  210. Emanage blue software
  211. Help with engine management
  212. emanage blue 5-6 psi base map needed
  213. Drew's Car at BnT Performance
  214. Internal parts from GX Model
  215. hooking up greddy presure harness and sensor?
  216. Dezods kit on EBAY Is this a good bargain ?
  217. buying a car with a blown motor?
  218. Will this fit on my t3 super60?? need answer asap
  219. Tuning and AFR question
  220. Changing FD
  221. Dezod Turbo System owners chime in!
  222. Type S motor
  223. Dezod Motorsports Tech Post: Boost Pressure (excellent read)
  224. Rebuilding engine help.
  225. What to do...?
  226. plug from compresser '02 civic k20a2?
  227. emanage blue communication issues
  228. Found this nifty little thing...
  229. Dezod Downpipe Issues
  230. Supercharger for 1.7 2003 DX
  231. JDM Base K20?
  232. Popcorn
  233. Dezod turbo oil lines
  234. Which engine is best
  235. Emanage Blue Need some help
  236. d17a2 turbo??
  237. RSX injectors with NA D14A1?
  238. Headgasket Options
  239. AC Compatible manifold?
  240. Disco Potato Questions and Long Block
  241. Turbo question!
  242. New Fuel injector option for boosted D17s
  243. Emanage update problem
  244. Radiator fans
  245. What do you think?
  246. K20 swap turbo kits?
  247. EM2 K20a3 Hybrid Racing Wiring??
  248. Need help!
  249. lx header o2 defouler or 02 simulator
  250. K24 Build Numbers
