- Dynoed the monster
- Overheating
- rods in k's
- D17 - B18C-5 Swap
- Preparation for going turbo
- Is this just me?
- E85 Fuel
- will a 14b turbo fit a t25 manifold?
- PEDALS: auto to manual
- Not getting any power after boosting
- K20a2 with a greddy kit?
- D17 Engine blocks?
- Any Turb Kit That Doesn't Remove Cat?
- cast turbo manifold
- Intercooler pipping size???
- Sad day for me :(
- k20 swap malfunction
- k20
- 200whp
- s2000 motor, dirty cheap
- a1 to a2 head swap reliability...
- Custom equal lenght mani update NEW PICS PG 5
- nitrous users, fuel question
- new and need turbo help want the truth
- noob'ed out with crower cams
- wideband o2. CHEAP! too good to be true?
- Subframe???
- Turns but wont start!
- 200 horsepower
- Found a DIY for the d16y8 Intake Manifold swap
- 2003 Civic Ex VTEC
- walbro 255 fuel pump
- ES1 DC5R Brake swap
- D17 block guard
- Even more boost!
- D17 valvetrain
- How big of a turbo is everyone running?
- Just bought a civic
- Head is finished
- A quick note about aftermarket fpr's
- This is turbo related.....
- K20 Swap FMIC piping question
- Harness vs Headswap question
- K24 head swap
- Tuned Emanage Map For All
- turbo question
- Dumbest thing ever
- do i need greddy pressure sensor w/ emanage ?
- UK k20 throttle bodies
- dc5 typer axles
- Tranny sucks doo doo
- Inexpensive. And what about that warranty?
- Has anyone ever used a butt dyno?
- 350 whp k20a2 N/A
- turbo question
- Fmu ?
- ECU swap idea
- will a d17 turbo fit a k20 ?
- Question about turbo kits
- Hks Turbo
- Y8 Intake manifold Q, for those who done it!
- K24 Frank begins.
- FS: 06 type-s subframe
- To open or not to open? That tiz the question!!!
- RSX Injector Fitment Question
- Issues with K20s
- Max HP from N/a D17?
- Modded RSX-S injectors for more flow
- Reliability with k20a2
- before tuning
- Emanage/ Support Tool Problem
- head swap
- help on k20
- video 18 psi - thought i would be nice and share
- 550whp FTW!!!
- Good ebay kit?
- is this a good price
- Tuning day! Done
- Obd1 D17!
- World's Most Powerful d17-Check it out
- Speedo Shot 10-80ish mph, Dezod Kit 8 psi
- wanting to turbo a d17???
- Coolest K20A SC'ed EVER! :)
- Tsi Kit
- K20A Question
- do i need these swap parts
- header question
- Turbo for d17a1 vs d17a2
- Custom TD04 turbo project
- EBAY Turbo kits
- Well, the poll is in! 350+whp inside
- this was posted on my site
- Tci Shift Kit And Boost Question
- Anyone have K20x + Full Race Turbo Kit?
- about the K20 swaps
- FYI: Engine Management Calibrations (D17 & K20/K24)
- Turbo installed.... now it won't even crank.
- Dezod. Over priced?
- K20 42psi I think you know what happens
- rsx type s stock injecotr max psi??
- Dezod turbo systems
- e-manage
- LSD for d17 realized
- hks bov??
- not you everyday swap
- dezod plug n play harness???
- PCS-xfc
- look what they are using
- E-Manage memory question.
- New Parts!!!! YES Also Help from N/A Guys Upddate Pg 6 12/25/06
- Design your own ELM with 3D model then build it your self
- To sleeve or not to sleeve
- K24block/K20head or a K20A2
- Effective boost/launch control
- NeuSpeed Strut Brace+K20 Swap Fit?
- Is this setup cool
- can somebody help me out with a fuel regulator
- New turbo kit for 01-05 Civic with D17A's
- how many OG members still here and boostin etc?
- going turbo...need help though
- emanage wiring diagrams n fixes for ex
- k20 turbo setup
- CRV engine in a 7th gen?
- My next move should be.....
- injectors
- check this out!
- cool turbo kit!
- Need to disable something in e-manage
- Need help on what to use to tune...
- I got a turbo!:)
- A Cpl 7th gen turbo videos.
- boosted k20a2 hondata question
- slicks?
- Emanage help
- k20 power steering
- K20A engine harnass help
- K20Z1 Swap has anyone did it in 2001 civic ex?
- Question about turbo PSI
- boosting untuned?...
- Stage 2, n/a, VAFC2 or emanage?
- ECU reflash proplems
- HELP ME!!....engine management!!
- My Turbo Kit for My (D17A1)!!
- which option to take tuning my d17
- intake ?
- p/s resevior question
- where can i get??????
- SF fuel
- B-series into 7th gen civic.
- clutch master cylinder
- My First Run W/my Turbo Set Up
- My 1st start-up with turbo...
- Which fitting for fuel return line
- Just Recieved Ny Tsi Turbo Have Q:
- clutch lines from master to slave cylinder
- light weight flywheel worth it on turbo set up?
- ECU Reflash
- question about turbo kits
- searching for a intake manifold 50 civic ex
- emanage for 04 ex coupe settings!!help!!!!
- Boosted K20a Swap plans!!
- Aem Or E-management For Turbo Set Up
- Will it fit???
- K20Z1 Swap into a 2002 Civic Sedan.. Starting Soon
- D17 manifold MANIA!!!!
- rsx-type s injectors
- D16z Arp Head Studs Work For The D17a2?
- Ring & Pinion Swap - EX to HX.
- RSX Half shaft
- K20Z1 swap need help with radiator????
- Turbo Install Questions
- What injector to use???
- Ck out the new turbo and mods/ DYNO NUMBERS ARE IN.LAST PAGE.
- hood clearance problems
- A little backdoor action.....
- what psi or hp will the plastic intake handle?
- internals???
- - Can I Use?.........
- New To F/I = Questions.....
- Turbo & Parts Suggestions?
- wire harness in engine bay
- Whats the part number for the walbro 255 that "fits"?
- k pro trouble
- best swap for my em2
- need help auto to manual conversion i have 1 question
- since my last post was closed...
- trying to find a k20a2
- 2007 RDX High Flow Injectors for your Boosted D17?
- the car wont start
- k20A3 forced induction
- Code P0507 On Turbo 05 Civic
- What companies make a good turbo kit for a 03 em2?
- Help with RSX k20a3
- Would Like To Get Feedback On Others Who Installed The Tsi T25bb Extreme Kit
- Looking To Tape Into The Brake Booster For Boost Gauge
- a bit of a complex question about a swap... which one? look inside
- Oil Return Fitting
- What turbo, Piping and incooler to go with? D17 Guys HELP
- my first CEL - Doh!!!
- alot of vibration
- Wiring Harness problem need help fast
- Having A Problem W/the Pressure Pipe Befor The Blow Off Valve Popping Off.
- Looking For Ideas For Fuel Upgrades .
- help!!....the turbo is hitting in ther clutch oil line!!
- FI Injector Question
- misfire problem with my turbo
- my swap
- Stock K24 on 7th gen LX, worth it?
- The Next Turbo problem
- what is the best AFR to have when boosting full throttle?
- Stock injectors question
- Oil Temp Weld In Fitting
- intake
- nitrous question...
- K-Pro for D17!!!!
- TSI Extreme Kit...few questions
- It begins...
- k pro for d17 is here!!!!!!!!
- Yea it was inevitable...
- Gettin' the hang of this...
- Head swap?
- Modded AEM V2 SRI to CAI for K20 swap
- to all u K20 gangstas
- The end all Intake Manifold...Installed page 4
- Turbo Set-up. Is this all i need to get started?
- k20 for1k???
- F20B DOHC Swap??
- Turbo not going into boost! Help!
- emanage tune
- All my DIY links are fixed
- JR S/C on a 7thgen
- K20 NA Swap, with Turbo Lag?
- Finally Started My Project
- D17A1 supercharged
- thought i share
- K20A or K20 A2 or K20 A3
- Double Checking my Turbo Set Up...
- For those with EX Head Crower Stage 2
- engine doesn't pass above 4000 rpm
- Regarding D17 Turbo Set-ups
- Turbo Exhaust Manifolds
- turbo kit
- MANIFOLDS HKS or DEZOD Best way to go??
- some possible experiments
- Regarding 38mm Wastegates Tial or Turbosmart with the dezod manifold
- Fuel Pressure Setting On A Turbo Set Up?
- TURBO: T3 or T3/T4 Hybrid What's best???
- K Pro D17 turbo test car
- Questions before buying..
