- couple questions from a nub.
- Other k-series mounts besides the hasport ones!!
- turbo kit for a your d17.
- How to calibrate emanage for vtec settings?
- Is this for real?
- New and Need Advice!
- need help...
- K20a3 or d17 turbo
- Nitrous Track Car
- upgrade cams?
- a question for the swap guys
- question about sf downpipe for an lx
- A NEW breed of D17 emerging.......
- DIY: How to Rebuild a D17 with New Internals
- some motivation for the SOHC Crew.
- TSI turbo kits...it
- Engine Swap Help????
- RSX Motor, any good?
- Back again!
- lets get some sounds clips of some turboed 7thgens of their BOV
- K20 oil pan?
- Hasport Axles? Should They Look Like This?
- d17 turbo kits
- Tranny Dead!!! One Question!
- 03+ s2000 or 03 civic turbo?
- Bigger T25 wastegate ??
- Turbo on stock ECU
- Do I really need aftermarket sleeves to make 350 whp?
- What else am I missing
- Tranny or Turbo Swap? Help
- What did you guys use for lines??
- Tuning today!!!
- Look 4 A Turbo Kit...
- Rsx
- T3 360 Degree TurbineOil Seal
- Back from tune...funny numbers..
- HAHA, I Love DIY swaps **PICS ADDED**
- Fuel Leak WHERE???
- SC 7th Gen?
- Couple of problems I need to sort out
- Dyno Results in for Abmerop18's boosted D17 @ 11 psi
- stock clutch....
- K20a3 Swap Total Price
- im back...... haha
- K20a swap, mandatory ac/ps removal?
- Fuel System
- auto to manual tranny help!!!!!!!
- Emanage's Anti Engine Stall Feature?
- 200 whp
- I need help with K20z swap!!
- The shape of things to come.....
- Dual CAm
- A3 Swappers step in
- Manual Trans Swap....
- new turbo
- turbo oil pressure help
- problem holding boost
- best oil for boost?
- looking for gauges for my turbo set up.. wats accurate?
- A wee bit of love for the internally gated folks....
- Water to Air Intercoolers???
- Bov Help
- Autometer Boost Gauge
- Dezod V3 Kit in my hands!!!!
- BIG RSX Injector problem...
- NEW! Dezod D17 Bar & Plate Intercooler
- More Intimate pics of the new V3 charge pipes
- Questions about K20a2 swap
- RBC mani on swapped EM/ES
- $200 Turbo...
- You Have Got To See This
- intercooler
- Jet Hot 2K Blue D17 Manifold.....
- D17A1 block
- Advice for turbo guys here....
- K20a2 swap times on 1/4 mile
- Passed the roadtrip test...
- turbo kit for k24 accord
- Emanage Problems thread DO not delete
- Injectors
- thinking bout supercharging ???
- Update on V3 kit install more pic update on full install! pg4
- I'm looking for some dyno numbers?
- More V3 GOOD news....
- Homemade turbo
- dyno'd today... bad day, need some help/suggestions
- IK20's
- Im backkkk, and have questions about nitrous 1/4 mile times.
- Have anyone tried this manifold?
- TSI Turbo Kit For $1,800 Yes Or No?
- Is there a specific Nitrous kit for a 03 civic 1.7L that i can get?
- KPRO question
- K20/k24 automatic?
- Smoke Over Exhaust Mani
- Is $7000.00 (canadian) a good price for Turbo installed
- Lost my actuator rod from SFs kit...
- Help wid homemade turbo!!
- Dezod's Downpipe and Mani
- cel?
- Would this be worthwhile??
- Engine Swap
- Dezod Turbo Kits in stock!!
- S-afc
- blown away
- Calling Out TransformedBG
- turbo piping
- K24 swap Q's
- A real FAQ on How to building D17 engine internals
- Dezod does it again....(V3 results are in w/ DYNO)
- I want a turbo, but is my tranny okay?...
- Power steering cuts out...
- D17 Into a 98 EK
- direct bolt on???
- Engine Swap question
- Almost Done
- DSM 450s
- K24A2! not K20.. swap help?
- Turbo
- Need 5/8 Brass Check Valve But Cant Find. Need Help Asap!!!!!!!!!!!!!!!!!!!
- Dezod V3 and PCS perfect match with engine bay pic
- FYIs on passing emissions with boost....
- Night Clips of My D17a2 Turbo
- TURBO HELP. lag/boost controller any pointers?
- turbocharging
- Swap Questions
- Turbo Systems
- how well does the aem ems work with k20's?
- 5 Speed Turbo and Nitrous Owners, Listen up!
- d17 cam gear question
- new forged 8.5:1 pistons
- Kpro tune
- auto to manual swap ( k20a2 )
- Port and Polishing my Head?
- K20a3 turbo or k20a2 swap
- quick lx to ex head swap question
- K swap shifter cables
- Tuning?
- Head swap
- k24a1/k20 eg vs 330whp Evo
- Fuel rail conversion?
- Interest in a Dezod Turbo Kit GB?
- who will be the first k23Turbo
- E-manage boost clamp/cut problem DEZOD THE MASTA!
- k20 bored at 89 mm Darton sleeves
- Intercooler Size?
- Srt injectors+14.7psi
- exhuast question
- Need an ATL D17!
- Cheap Namebrand turbo?
- weird problem with turbo manifold
- Dump Tube for V3 kit is done(now with 3 pics)
- From Russia with love ho-ho
- Rattling issues for k swapped civics
- any alternative to missing link check valve??
- Good read: Acura K23A1 Turbo
- is this possible
- someqns
- who makes the most reliable turbo system?
- Fuel Management? turbo? fuel system?
- Ex engine swap help. Please help
- engine problem
- it is possible(k20a)
- map sensor problems
- true or false n2o question
- RSX-S shifter issues
- Swaping D16y8 into 7th gen?
- My Turbo Process Thread; ep3 A3
- low compression by adding head gasket...
- Kpro Calibrations
- new dyno
- Tsi Injector Box ????
- k20 automatic?
- converting auto to manual
- Auto to Manual
- head swap
- Inlet filter for V3 kit solved
- Turbo question
- Noob questions, yes I searched!
- How many of you guys here have swap K20
- k20 swap question really quick
- k20
- Injector Plug Harness
- RSX cluth pedal assembly
- Affordable Turbo Kit?????
- wide range of qns...
- Just got my car dyno'd..
- Just Got A Dry Shot.. Help Plzz
- Help With Power On My Noz
- ATTN: AEM EMS users, please read!
- Pcs-xfc
- Flow bench testing the head
- what to do next
- Vaccum line
- 13.7 run video kswaap boost
- Reliable?
- ECU/key mobilizer problem on a vtec swap from a lx to an ex!
- vtec or non-vtec for boost? turbo gurus come in!
- inlet filter
- Plz Help With Nos & The Jets
- Cam installed dyno #'s posted
- boost controller question
- Im so excited about this!
- Everybody run!!! I have a plan...
- just wondering if anyone knows
- i need to know
- D16 turbo on my D17
- can some give me a rough estimate?
- Should I Buy The Used TSI Kit?
- dezod logo IC
- from auto d17 to manual k20
- Ported Head
- Crower Stage 2 turbo camshaft
- Building K20
- Cant decide???????
- Anyone?
- Pretty lame video clip of my car!!!
- swap question
- Insane built, boosted D16
- swap question
- nitrous express article
- D17 Rocker Arms
- To Need or Not to Need!
- Next production run.....
- Project D17 Boost finally underway lol
- turbo kit
- nitrous on an auto tranny???
- Any One Ever Use Dynamic Autosports?
- video: my turbo run
- warranty with nitrous
- Plastic Intake Manifold Gasket
- k20 swap
- mustang throttle body on civic?
- brk7e doesnt work
- 5psi?
- Need tech info? Dezod's got it!
- PCS-XFC base map
- New Turbo-Game Over
- Emanage clarification
- I'm really scared.
- Pros/Cons of having lightweight flywheel with boost?
- Crower Valve Springs/Ti-retainers installed*PICS*
- emanage base maps
- thinking about turbo, need help though
- d17 shifter cables for k20
- Kswap crashes?
- Turbo
- Jw
- New clutches are here, slammin prices for forced induction D17s!
- k20...
- 16psi of boost civic (what about traction) please advise
