View Full Version : Forced Induction and Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22
  1. auto n spray
  2. wondering how to get more fuel with a FMU
  3. Emanage Ultimate Wiring?
  4. 96 dx head swap?
  5. For those who dont know what sleeves are.....
  6. Anybody wanna start a "Tuning 101" Thread...
  7. should i use e-manage or vafc2 on my setup? TURB SWAP QUESTION
  8. How to choose the proper size injectors
  9. Manual Transmission
  10. K20 swap or turbo? ~Help in Rochester NY!~
  11. supercharger and nitrous
  12. intercooler fitting
  13. what spark pluggs (what heat/spark) should i use with turbo
  14. K20 w/ turbo
  15. K20 wiring harness...?
  16. Turbo filter
  17. WTF - electric supercharger
  18. Turbo Rebuild!!!???
  19. Im sure yallve heard this one before.. but
  20. GSR axles work with K20 swap !!!!!
  21. Honda r18 pic!
  22. Check K20a3 for sale... i wish i could buy it
  23. Injectors
  24. Help With Pump Used For Water Cooled Turbo Setup..
  25. Engine Swap Question
  26. DO you suggest this exhaust dump powered by a turbo? look
  27. RAZ cams add 30hp untuned !!!!
  28. Who wants to be the first with a custom D17 Quaife LSD?
  29. Newb w/some turbo questions
  30. FYI: GReddy E-Manage Packages are now available
  31. Turbo on a budget...
  32. Locating an engine
  33. Question for those of you that have swapped..
  34. Help me complete the equation..
  35. looking for a d17 non-vtec turbo manifod
  36. Checking interest: E-manage Ultimate PnP & some other goodies
  37. Where to install a BOV ? pic
  38. RE-Dyno'ed my K20A *updated 11/28, graph on post 112
  39. k20 into a '99 Civic H/B?
  40. have anyone use a HF turbo manifold on there civic 01-04
  41. FYI: Dezod Turbo Kit For Sale
  42. ??? about manifold flange
  43. need to get everyones opinion on my exhaust setup.
  44. Nitrous Spark Plugs?
  45. Whats more accurate?
  46. bhelp blacking out tailights
  47. is there any good advice?
  48. K20A swap acceleration vid!
  49. NEED Turbo Expert
  50. 91 crx swapping 94 LS motor!! HELP!!
  51. The 7thGen: Should I Swap or Turbo?? FAQ
  52. Stock D17 Turbo
  53. need info
  54. Will a 2006 civic motor fit in our cars?
  55. 2001-03 ECU Pinouts
  56. AEM stand alone
  57. Dezod Catless Mid-pipe (replaces cat-ed EX pipe on our turbo system)
  58. Timing nitrous
  59. The missing LINK.......
  60. Can't Get Oil To Turbo....HELP!!!!!!!!
  61. n20 = retarded?
  62. For those ppl with emanage......
  63. Cant ever get the same answer...
  64. Boost controller problems
  65. tuboing new engine
  66. k20a vs k20a2
  67. Turbo Timer with immobilizer
  68. Car insurance increase after swap?
  69. 1030/1030-U now available
  70. What Fuel enrichment system to use...
  71. Vid of my k24
  72. I think I'm running lean
  73. Dezod turbo kit
  74. stock injectors please help
  75. catch can
  76. 2001 civic turbo Civic dyno video. 56k go away =)
  77. Dezod expanding it's horizons
  78. Swap Question
  79. engine swap
  80. clearing up the 8THgen FI question.......
  81. How much can our clutches hold
  82. My new FMIC
  83. Question about Wastegates
  84. turbo oil feed and return fittings? where to buy?
  85. more boost
  86. Sway bar + Swap
  87. Intake off turbo
  88. ATTENTION to all turbo know it allers, especailly those with tsi kit or a t25.
  89. SF manifold to OBX manifold?
  90. 7th gen Supercharger Part II
  91. My Dyno Results at 5.5 psi
  92. is there really a website?
  93. AEM PnP EMS for the D17 have arrived!!!
  94. ITB's {dun dun dunnnnn)
  95. Some help with choosing and piecing together for turbo
  96. turning the intake on a garrett t3???
  97. what are you turbo people doing for the winter?
  98. How to? Pressure sensor
  99. nitrous engine setup question
  100. Need opinion on 5spd convtn/k20a3/ or turbo
  101. retarding timing in a 7th gen
  102. will an AN8 size hose fit on the oil return neck of my t25 from tsi???? ASAP HELP
  103. Dyno Results
  104. Apexi turbo timer off ebay
  105. Exhaust question
  106. For those who had shop install K20....
  107. sneak peak of my new setup.....
  108. Nitrous dyno numbers?
  109. turbo:cheaper 2 buy sepearte? or kit?
  110. what parts will i need to make GReddy e-01 or profec b work?
  111. 911 help!! (nitrous parts)
  112. correct jets for 75shot nitrous
  113. install help ---> SF kit in 04
  114. Emanage users
  115. question about Exhuast
  116. [swap]need to know wuh parts....
  117. F20c
  118. difference between k20a2 vs k20a3
  119. Does the Kms valvetrain package work with a crower stage 2 turbo cam?
  120. Need help! weird boost cut problem...
  121. k20a3 vs. d17 weight
  122. AT --> MT swap
  123. D17 subframe auto / manual
  124. joined the n2o club.
  125. help with cam gear tuning...
  126. BOV, wastegate and boost guage
  127. Update...
  128. Sf t3 flange with t3/t4
  129. dry nitrous
  130. Buyin a turbo kit
  131. Please Help! Turbo!
  132. I'm very confused!! PLEASE advise!
  133. engine shutting off, please help
  134. spring psi on SF kit?
  135. mechanical drawing for a garrett t3 turbo
  136. Not to much to choose from for the 05-04 Vic..
  137. Sneak a pick of the new set up
  138. emanage unit update probs!?
  139. tranny
  140. Wat else do i need ?
  141. TO Dezod, how close is the stage 2 package to completion
  142. Alcohol injection
  143. so apparently rsx-s tranny bolts up to f20...
  144. d16 intake manifold and injector question
  145. d16 and d17
  146. FYI: D17 Core Kit Limited Time Pricing
  147. exhaust mani/turbo smoking
  148. Downpipe flange
  149. Project Beta Help!!!!!!!
  150. any one with the d17a turbo out there?
  151. Where to put nozzle at???
  152. Poll: D17 Stuff **future boosters, please enter**
  153. Need to know what you guys think (Guys with K20 chime in)
  154. ITBs with k20 swap
  155. just general idea of turbo kits plus installation
  156. sf NEW fmu install
  157. Ls/Vtec in a 2001 Civic
  158. Need help from turbo people
  159. turbo 01' ex questions!
  160. K20A swap JDM Type R
  161. new guy
  162. Turbo guys.... quick question about FMS???
  163. oil leak from turbo/exhaust
  164. new and need advice
  165. different turbo
  166. Looking for a boost controller?
  167. Dyno Chart at 6 psi
  168. lx power
  169. where is the ex head swap!?!?!?!
  170. my dyno at 8 psi (pic)
  171. Air fuel ratio question
  172. Help Anyone If You Can ?
  173. questions about cams
  174. Multiple K20 Questions!! please help!
  175. K20 Swap Problem.
  176. What size spring
  177. In-tank fuel pump (main post updated!)
  178. K20a swap gas mileage?
  179. fuel in and fuel out on fmu
  180. Gt30R or t3 super 60
  181. What else do i need
  182. carbon fiber..?
  183. sry for the n00b question but.
  184. please help i did search but i just need
  185. 450cc injectors
  186. Help E-Manage Install Problem
  187. turbo for 01 EX civic
  188. E-manage settings
  189. Turbo Guys Help Me!!!!!!!!
  190. generic boost question
  191. RSX Injectors + EM
  192. Who's got a turbo that has to pass emissions?
  193. Compression Ratio
  194. K20 + turbo
  195. FYI: Aem Ems 30-1030
  196. Emanage misfiring problem
  197. best turbo for auto?
  198. T3 5 bolt gasket
  199. Dezod Holiday Raffle!!
  200. Car 80% done peek a boo
  201. fpr
  202. NEED advice and opinions on this auction ASAP plz
  203. turbo timer problem
  204. Turbo project detail engine pics 44k
  205. radiator problem ??
  206. downpipe sizes
  207. New motor!
  208. Return Fuel Line System
  209. t3 dx/lx downpipe
  210. has anyone swapped an 05/06 k20z engine yet?
  211. Nitrous Purge Help
  212. Rsx type s swap
  213. TSI fuel system
  214. Emanage Misfiring
  215. New Dyno @ 13 psi
  216. Platinums for nitrous?
  217. Wideband O2 Sensor Sale!!!
  218. Ok Ok, read this now or I will hurt you
  219. what cams are good for turbo for our cars?
  220. D17 swap w/ vtec head
  221. boost gauge install help
  222. tapping into fuel line for nitrous
  223. TurboXS Dual Stage Boost Control?
  224. Stupid CARB!!!
  225. Looking for detailed instructions on swapping type s head on k24
  226. Nervous about e-manage
  227. greddy profec bspec II problem
  228. D16 turbo manifold on D17
  229. if u didnt know
  230. cheap and easy vtech controller :) A hack of sorts
  231. WHat intake to use with a K20A2 swap?
  232. new project that just started.....now new FAT hole in wallet!
  233. blue/white smoke
  234. Looking for a fitting... don't know where to look
  235. Why hasn't this been done yet?
  236. Ok, cat's out of the bag.... Surprise #3
  237. Is there a K20 Automatic available?
  238. how fast is the em2 k20a3 swap??
  239. Places that do custom intercoolers?
  240. About my TQ curve
  241. K Series Transmission With EM2
  242. k20a2 dc5
  243. who has a k swap in the vic
  244. Custom Bar & Plate Intercoolers will be available....
  245. Max boost put on a d17?
  246. Tranny Swap Questions
  247. TSI owners... quick question
  248. How long to hold a 50 shot?
  249. CEL came on after a 50 shot spray
  250. Downpipe?
