- 2 Blown headgaskets in 1 month
- Oil Feed fitting from where?
- auto tranny mod
- Which fuel pump
- obx turbo mani
- 7th Gen Available Turbo Kits Writeup-UPDATE 4-22-07
- Dezod Motorsports D17 Equal Length Manifold *SHIPPING!!!*
- TSI and stock exaust
- Reinstall or sell?
- swapping!!!=D =D
- Got my TSI today!
- plugs?
- new part came in for my turbo kit
- Golden Eagle sucks (sleeving the D17)
- so yesterday i had some data logging done
- Questions!
- delivery =T
- My car is finally tuned!
- wastegate question
- Emanage Ignition wiring; Coil Vs. Channel
- Evo 8 FMIC, will it fit?
- Tuned?
- sf turbo or dezod ?>>
- straight k20, or k24 block
- good deal?
- Cant take oil pan off!
- stroker kit
- Turbo Pressure on a Stock D17 engine
- oil feed/return questions
- Fuel setup question
- **EDIT** pics added, HELP to ID fuel line, water line & boost vacuum line
- rate your exedy oragnic clutch.
- Stalling issue after turboed
- problem picking wich engine to swap
- What do i do about this?
- Emanage???
- How to hook up a fuel pressure gauge
- Im sure this has been discussed before but...
- Stupid car
- RSX injectors and fuel rail swap?
- Smoke help, need some input.
- "fuel shot through a solenoid?"
- PPl with zex dry kit
- TSI KIT for my 02 civic EX
- E-Manage w/ the Dezod D17 Kit is NOW PLUG & PLAY...S-AFC2 & V-AFC2 available as well
- who runs 75
- Any last minute tips?
- K20 swap diy
- EDIT : Buying a K20a3 w/ PIC
- How retarded are you??
- Legit???
- Steel braided oil lines
- where can i get n20 jets by this weekend
- headers w/ oem exhaust....
- Nitrous Install pics
- Need for an intercooler with low boost?
- Question
- Get the Pressure sensor!
- K20 w/ Supercharger
- How much HP from a bored out TB?
- 700 whp street car
- Nitrous
- Nitrous Dynos
- tsi kit is gay to install..
- Mex's e-manage install / tuning problems continue...
- Emanage Help?
- just curious...
- Why is k20 more popular than k24 swap?
- E-Manage Ultimate...
- good head gasket
- Hesitation
- Tsi turbo question
- Cast manifold w/external w/gate
- Ruined D17 what should I do?
- Nitrous parts
- Bit curious???
- KMS Intake Manifold...
- act clutch..
- new radiator
- Custom Boost
- Tsi Turbo Kit and Cel light on
- Check valve & MAP
- Fuel system enhanced (back to fabricating)
- Engine Build Up
- Blown/Broken Engines
- Nitrious Question
- Vacuum hoses?
- how much will the ecu try to adjust the fuel while in closed loop
- Turbo idle fix
- FYI: Those Looking for awesome prices...
- Help with BOV connect...
- k20 swap help
- turbo anyone
- bottle warmer Q
- plugs
- TSI problems (newbie)
- Some more parts laying in my garage
- MAP plug location
- Dezod Motorsports Stage 1.5 Turbo Kit??
- where did you get the studs for the rsx injectors?
- SRT-4 Injectors?
- My motor is finished!!!
- about missing link..
- RC 550cc injectors in the 7thgen. Pics and installed
- Affordable wideband???
- turbo in the winter
- stock clutch and turbo
- Axles
- need torque specs asap
- B-series in a 7th gen..hotness(hope not a repost)
- Cleanest k20 Intsall ive seen
- EP3 Fuel Rail + 310CC injectors
- JUNKYARD WARS! turbo questions inside. help if u can.
- people with tsi kit....
- Fuel System related question for Turbo Application
- intercooler piping
- Dyno tune done
- 3 inch piping...
- E-manage maps GT28R Auto trans!
- engine cut out at high rpms
- K20's in everything...
- boost gauge problems..
- stroked= ? hp
- K20a2 Longblock
- Manual Swap from Auto
- So coolant does NOT expand?
- No more NA for me
- Installing my turbo kit again
- Opinions?
- e-Manage Ultimate
- Dezod, Intake manifold?
- E-manage and nitrous ...
- Help me with my loose nuts...PLEASE!!!
- Shaft PLay
- Oil feed
- radiator fan
- Right NGK plug?
- K-swap with AC.
- K20 Swapers i got a question.
- Over 200whp and stock axles
- K20 swap faq?
- new Clutch!!
- *Official* Turbo whp listing
- How many acutally installed Turbo on autox!!
- afcII + cam gear for tuning?
- Question about Pistons?
- Pistons and rods...
- well i f'ed up something already...
- how do u shift with Turbo
- head gasket
- What to do before puting turbo?
- k20a3 --> k20a2?
- Oil feed and return line
- hmm will it work...?
- Nitrous+tune?
- Turbo installed, but doesn't seem like much more power?
- 1996 Civic Si
- Best Swap?
- To all those boosted-?
- k20a3 swap....
- E-manage voltage clamp?
- New Toy, Emanage & Custom Harness (more pics added)
- Supercharged d17... Something to think about...
- rsx-s injectors
- RC550 Injectors
- K20 Swap -- Done ** More Pix on Page 3 **
- Knock sensor and Emanage
- in the process of turbo
- another timing option for ya
- NEW! Dezod Turbo Assembly. Great for custom
- New! More affordable & large injector options
- 2003 LX 1.7 Liter Turbo HELP
- walbro 255lph fuel pump install
- e-manage settings
- new website
- Which K swap is easiest??
- WOT switch for spray
- Official Release:Dezod Motorsports D17 Stage 1.5 Turbo System
- K20 swap problems..
- water and oiil fed turbo
- K24 Engine w/ K20a3 Tranny
- whats the most easy swap for our cars?...
- 1/2 Radiator for 7thgen
- Need Help ASAP! Emanage fried somthing??
- MSD digital rpm window switch problem
- oil feed line
- Running a CAI on a swap?
- Finially got the new dyno up
- Wanna see how fast our civics go? (Video)
- Turbo install gone bad need help
- Nitrous for AT people
- 04 Honda Civic ex Engine swap
- New turbo problem please help again
- turbo exhaust
- Will K Motor go down in price?
- Question about swaps
- Turbo = Loosing Fog lights?
- K20 Swap Subframe questions...
- Turbo guys please call out your DINO'S
- K20 Swap Dyno Numbers **Updated** Dyno Sheet Up
- What About the H22!??
- obx manifold and t3super 60
- dry -> wet
- VAFC 2 tuning help
- Questions about a Turbo before I buy one.
- FYI: Dezod D17 Stage I turbo kits are on the shelf
- K20A3 questions
- engine build question
- Pistons, rods, sleeving?
- external wastegate mani, with internal wastegate?
- Would you be scared in buying...
- Turbo problem. Help needed!
- 05 vp Nitrous Kit?
- Finally...KMS Intake Manifold + Boost = ?
- Hasport MM vibrations
- turbo civic 0-60
- (NEW STUFF LAST PAGE it worth it) what do you think, check it out and help a member!
- timing retard
- Well i can honestly say....
- Need help w/code plz
- Using Air Filters Question
- TCI Auto *personal review*
- swap
- Ideal Turbo for a D17a1?
- b16a swap
- Spray on an auto
- Settings for Nitrous RPM Window switch
- Who know's the answer
- k24a2 swap vs k20a2
- KMS Intake Manifold + Boost Review!
- Who says leaf blowers don't work?! *Bonus* - NAWZZZ TOO!
- to all those boosted, with or without internals.
- People that are K20 Swapped
- Hasport PRess Release K24 Mounts for 2001+ Civics
- DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
- 440's with emanage-issues
- L@@K at this turbo manifold
- me and spdrcrchk wanna know????
- uhm... what is this thing?
- Update on AEM EMS
- cel light with turbo kit
- k20 rad fan wiring help
- Autometer Boost Gauge Question
- question on fuel management
- INjector Correction on E-Manage?
- EGT Reading?
- For those that have/have used y8 intake manifold
- please help me with my downpipe
- Turbo Help ASAP 1997 Honda civic ex
- I need some useful, intelligent, and serious input if possible....
