- DIY: Shift Boot Replacement
- DIY: Sidemarkers from MB SLK Compressor
- DIY: Shutting off A/C during defrost mode
- DIY: Short Throw Shift Adaptor Install
- DIY: Blue Dash Lights
- DIY: Gas Cap Hanger
- DIY: Installing AEM CAI
- DIY: Change Your Dashlight Color
- any such thing as a custom supercharger?
- Whats the LX mid-pipe diameter?
- Need help on Interior trim piece removal..
- ATTN : jaje, Question on your MB SLK side markers
- Is It Worth It???
- Removing side rear panels
- remove the power window controls on the driver and passenger arm???
- WOULD THIS WORK
- Electrical Help With An Underbody Kit
- Any good body shop guys out there?
- Self INstall or Pay to install (AEM CAI)
- DIY Trim piece, the lil panel where the window buttons are.
- 10,000===>maint' light...
- Anyone know how to do this???
- Size of windshield wipers....????
- Air coming from the vent?
- Temperature Rating of Plastic Engine Parts
- ceramic header life expectancy?
- Need help with 01+ Coilover w/pillow upper ball mount
- How much should I drop my car?
- what fuse to put for the LED windshield washers?
- *Another* desperate clearing corners question...
- Want some info on CAI vs SRI?
- New exhaust and MPG1
- removing headlights
- clear headlights....can people on the sides of you see you're turning signal?
- needle question
- turn aem cai into sri?
- How to remove speedometer guages?
- AEM POWER PULLEY INSTRUCTIONS FOR ALL HONDAS/ACURAS
- NOS INSTALL QUESTION HELP!!!!!
- i dont know bout this quest.
- My Interior Lights.......
- V-SPEC COIL OVERS?
- Coilover problems
- HX catalytic converter...same position as EX?
- IDLE TOO HIGH???
- anyone know how to reset the "maintenance required" light?
- HOW do I relocate mY spare tire to under my trunk
- clutch line?
- NEON RELAY PROBLEM LOOK
- Parking Through Drive Piece Taking Apart
- LED GAUGES HOW? Slickwillie HOW?
- Another Intake Question, but not which one is better!
- Another Steering Wheel Question
- My needles stick
- DIY: Apex'i V-AFC Install Instructions
- Red Brake Calipers...
- Tips for removing oil filter please
- coilovers dangerous?
- Questions about the 935draggers Civics, about the wheels
- DIY: Blue Dashlight DIY
- VAFC installation question
- !!!!!!!!!<Installing Springs>!!!!!!!!!!
- My Headights (realign)
- Burning Plastic Smell
- Detailed insructions on Painting plug cover...
- ground control replacement parts
- Air Bag Sticker Sticky Stuff Removal
- Bad Shaking!!!
- Some lessons on VAFC Setting Screen!!!
- Push-Button Engine Starter Help!
- How to remove rear stock speakers
- Need help with LED washers
- Relocating spare tire - only on the Coupes
- Engine Codes what are they
- DIY: Oil Change
- air/fuel ratio gauge
- Grills I got
- Problem with clearing headlights??? HELP.
- Help with clearing................
- VTEC INDICATOR LIGHT???
- Installing Indiglo dash.
- Question for Header Gurus
- Extention
- Bec Tech coilover system in the works
- 17x8 wheels?
- 93-2000 civic Spoilers
- Over Heating Bulbs??
- 215/45/17 and a 1" drop- question?
- complete coilovers vs. spring/shock combos
- Headers for the LX
- Door handles
- Do you Want Blue Guage Faces ??
- What are fogs for ? ...
- Seat swap question.
- Torque for wheels
- cleaning intake filter
- Tightening trunk latch?
- LED hoodlight hookup?
- stock wheels
- Shaving of the Emblems...
- Security breach? If grille removed?
- Forum's DIY upper grille OOC.
- Ignition System
- Rods/Pistons For 2001 Civic?
- Fog Light switch wiring...
- PLEASE HELP!!!!!!!!!!!
- Maint req'd light???
- Will 18's fit
- OEM fog lights and grill
- quick question about sunroof
- defrost activation wire?
- 2k1 civic ex 15"s to 99 civic lx <possible>
- h and a oil filter
- DIY: No More Trunk Rattle!
- INJEN CAI diameter????
- DIY: Magnaflow exhaust install
- 180km/hr???
- Valve Cover
- Help with trunk lock
- AEM Ram Air and K&N
- silicone...
- rear light bulb problems
- Acura (Honda) Engine Specs
- Suspension Techs
- DIY: Front and Rear Camber Kit Install
- more lowering help....
- stobe brake lights (new question added)
- Interior Strobe Positions ?
- i live in queens, ny.. does anyone wanna clear my lights for money?
- tech: tie bar stresses?
- Camber KIT
- anyone know how to do the diy hiper blinker
- rear tie bar install
- springs?
- Straight cat/ ehaust
- Replacing Emblems...
- NEED HELP ASAP!!!!!!!!
- Fender well
- How do you install front emblems?
- A few points of interest
- Coil-over: How do you lower it?
- ELECTRICAL PROBLM!!! PLZ HELPPPP
- Question on DIY clearing headlights...
- custom cat back?
- Dynamat or other sound dampening material
- HELP QUICK!!!!!!!!
- if i change my cai to a sri .........
- help and opinion please
- Torque spec for rear hub/drum nut?
- Dash Lights
- got PIAA 1700X for xmas..
- Thermal Cat-Back Pics ?
- brake upgrades?????
- NOS Guru's PLEASE HELP!!
- Check Engine!! light on after installing SRI..help!!!
- Fog lights & lower grille???
- RETARD TIMING????
- searched... couldnt find... clearing headlights.
- Throttle cable affects MPG ??
- Q? w/ 11.5:1
- Need Template to cut Bumper for Fog Light ? Help
- Lug Nuts and Focal R3's
- slight drift...
- Air to Fuel Ratio.
- 114x4
- Will a shift knob off of an earlier year Civic fit our cars?
- book on 2k1 civic..?
- DIY Shaving
- Adding Vetec ???????
- can i get my cam gears ajusted, to add more HPs
- porting the intake
- Wanna shave the rear "H", but are there holes under it?
- AT door lock Remotes
- Lowering affect intake??
- Exhaust Resonator??
- stock spark plug model
- How do you get at your gauges?
- grill
- Injen Race division cold air install?
- AEM CAI and gas mileage
- Neuspeed Upper strut tie bar
- 2002 center trim
- Removing coil springs for coilover install
- VAFC WILL NOT WORK ON CIVIC EX 2K1!!!!!
- ??Rear Discs??
- How To Adjust A Camber Kit Installation?
- Exhaust Header Help!!!
- CAN YOU PUT ON A DOHC HEAT AND REPLACE SOHC?
- Different Sized tires/Speed O
- Re: New Pistons and rods...
- Removing Stock exhaust???
- Integra Type-r wing (need answers?¿?)
- HELP - need info on matrix coilovers QUICK!!
- Found this article explaining exhaust, backpressure, and shockwave tuning
- Altezza/Tpye R grill installed!!!
- INJEN CAI to INJEN SRI....
- ? about torque converter
- reverse lights
- ? on headlights
- Swapping Engines in 2k1 Civic EX
- Change remote all unlock to SINGLE press
- Best way to shift?
- Computer Chip?
- I Need Your opinion on Coil over
- Nitrous Q.(allready searched)
- will a grill scratch my paint?
- Making body kit more secure?
- AHHHHH I need help =) hehe
- Turbo suggestions from the wrong person
- Turbo question: enligten me
- Automatic gears?
- NOS INSTALL
- DIY Heaven
- Help me fast...
- DIY Clear HEADLIGHTS PROBLEM!?!?!
- DIY: Alarm and remote start
- Oil filter cooler.
- a q about my grill
- Diameter of Stock Throttle body ?
- Advice needed on cleaning inside windows.
- exhaust ideas.....
- Spoiler->Wing
- Altezza's
- DIY: HOOD struts & Aluminum Spark Plug Cover
- when installing injen sri....
- Oil Change
- AEM Pully installation
- Difference in Coupe Vs. Sedan Headlights
- Oil Change Q...
- Springs after body kit?
- NEON LIGHTS DONT FIT......
- Help with gauges
- Another Question about turbo's with stock exhaust
- Missing AEM CAI DIY!
- Bad news on removing speed limiter
- Nokya Xenon Plasma lights
- Weird tire wear?
- ??on installing Liteglow Proseries underbody neons
- Help me out...taking out the interior door handles...
- honda parts for 2002
- accord wheels??
- DIY BACK DASH?
- RSX Front End Swap
- newbie to suspension mods
- Q on DIY Led washers
- some info on rear disc swaps
- red bulb legal for rear turn signal
- DIY: Clear needles for gauges
- do i need camber kit?
- tires?
