- fixing camber
- How hard is it to adjust the height on coilovers?
- What is the gude package
- Turning signal bulb...???
- Clicking Sound Coming from Front Right Wheel Well
- OBX Type H (HKS) Catback Exaust??
- I just want to make sure....
- cat-back help!
- WTF my keys are stuck in the ignition!And my metre is fvcked up(HELP ME)
- Front Lip Rear Valence Side Skirt Installlation
- wiring neons to window lock switch?
- Sedan Grill to Coupe Grill Conversion...Completed w/ Pics!!!
- bolt patterns?..our wheels-
- Philips Silver Vision Question
- how much for custom piping
- Altezzas not flush on car (Anyone have that prob)
- I Scratched My Car, HELP!
- Question for Grey
- INSTALING CD RADIO HEAD UNIT OUT OF 2K2 EX IN MY 2K1 LX
- Torque Values for DC Sports Tower Brace
- DIY: Painting Washer Nozzles
- modding trunk springs
- DIY: amp on stock deck
- neon lights switch wiring diagram
- Injen CAI vibration?
- magnaflow hitting sway bar??help
- aem cai ?
- WARRANTY?
- front emblem vs rear emblem
- best engine for 2001 civic LX
- oh man, DIY painting trim problem some 1 please
- Louc click and popping sound
- Clearing Sedan lights?
- Rear Sway Bar Rattle
- Vinyling the Dash
- What's redline all about???
- Intake Question:
- changing the colo of your interior?
- wiring washer lights
- Miles per tank?
- Some tech ?'s
- Cleared Heads But Forgot To Change Bulbs
- ENGINE WARRANTY??
- How to tell if an engine is lugging!
- Any 1 with Tsunami Front, under headlights question..
- port and polish done
- interior DIY
- Koni Installation in ohio, michigan, indiana where at?
- NMB Paint For Body Kit?
- Weapon-R Dragon Filter cleaning
- what to do with third gear??
- DIY FOR MY STRUT BAR
- coloring the honda cover inside hood
- glass from a blue bulb, in my front light
- power window wiring on DX/HX?
- dealer tech/mods
- shift points other than redline?
- Anyone know how much an RSX swap ........
- herlp me please..my spring is making knocking sounds
- question about neon wiring
- Switching Air conditioner
- This is a WEIRD problem.....
- Customizing Altezza Grill
- Dual Exhaust on a 2001 Civic EX?
- Projector Headlight Alignment
- Nitrous???
- installing altezzas
- Clicking Noise coming from front...
- Disobedient shift boot
- car set on fire
- PAINT CAME OFF?!!!!!!!!!!111
- HEADERS!!!!! DO OLDER CIVIC HEADERS FIT THE NEW 7TH GEN CIVIC???
- Ride Quality...HELP
- AEM CAI HELP....
- 2 quick questions for sedan owners or whoever
- need help with map lights
- Rough Idle Problem
- How can i improve antennae reception?
- DIY Washer Lights
- turn signal color
- DIY: 7thgencivic.com Sticker
- Stock OEM foglights....
- DIY Wire Cover
- Massachusetts and exhaust? Please Help
- PLEASE HELP! DAMAGED!
- penzoil is bad?
- Any1 with a konig intake? or i guess any for that matter..
- GReddy cat back
- Final Verdict on Exhaust pipe
- I wanted a Repair Manual but couldn't find.....untill...
- What type of fuel does our cars use?
- Chang moonroof to sunroof on a 2k1!!!!!!!!!!!!!!
- Removing air vents
- Cutting the shifter
- anybody with a tsunami FB !!
- what kinda plugs
- Help rough idle
- cat back or custom exhaust
- i got a turbo on my car
- Hey, where'd the Mega DIY go?
- Another exhaust question
- did Some1 mentioned door tweeter mounts??
- Hey guys
- DIY for HID?? Please Help!
- Break in period for new engine?
- wondering if someone could post some pics...
- Torque Values for wheels
- Automatic to manual
- 92-95 5Th Gen Civic EX Wireing Diagram *NEEDED BAD*
- ANOTHER BREAKING IN THE CAR QUESTION?
- BAD LINK ON DASHLIGHT DIY
- Laptop installation!
- Problems! Please Read!!
- HP loss with dual exhaust
- hyperblinker.....need help
- REMOVING BUMPER QUESTIONS
- Condensation in Cleared Headlights
- Will the turbo fan timer work on the civic?
- gauge cluster swap????????????????
- lower tie bar installation?
- Wet Kit vs Dry Kit
- 01 Head Light Problem
- Any recalls on civic ex 2002?
- no cat...
- Honda Bulletine on Reverse Shift Fork
- Is it difficult to change the break pads?
- how much should i lower my ride
- alternative fuel in civic?
- motor oil
- Putting Herculiner in trunk, Good idea?
- air ride...air bags...wut ever u wanna call them...
- cluster swap????
- K20A2 engine swap on a 2001 civic coupe (ex)
- My combination of intake/exhaust.. give me opinions
- my friend broke a light bulb!!
- Awesome Shift Boot!
- installing MSD window switch
- 7440 and 7443 bulbs.
- help!!!!!!
- front map lights....they're 194/168??!!
- HYPER BLINKERSSSSS
- rear lower tie bar?
- Door Panals???
- hey CUE2k1
- LIGHTBULB AFTER CLEARING HEADLIGHTS
- need to remove something
- Changing oil and converting to Synthetic. Anything special need to be done?
- great...my dome light doesnt work when the door opens....
- went today to the track and !!!!!!!!
- help with an intake on a 96 accord v6
- Side MArkers.......
- Intake decision, whats good??
- headlight question??
- dying synthetic leather
- 19mm sway bar on a 2k1 dx lx DONE
- Projector headlamps
- what bulbs needed
- Help with shift knob??
- Rev Limiter...
- fogged headlight help!!!!!
- break in period question
- problem with clear headlights.
- Need HELP removing gas pedal asap!!
- why would spraying more then once in a period matter?
- BORE OUT THROTTLE BODY?
- has anyone done the DIY BLUE DASH LIGHTS?
- CAI
- Stiffer suspension for 2002?
- need help with Headlight ? peoples....
- Apexi V-AFC install help!!!
- NEED HELP !!!!!!!!!!!!!!!!!!!!!!
- Fuel cutoff=bad news
- Some one please Help !!!!!!!!!
- What Gas Should I use in My Civic?
- two install questions
- DIY Relocating spare tire under the car (no pics)
- Returnless system...........
- Another fuel question
- Help with Upper Grill Install
- Painting Altezzas...
- A ?, for those with nitorous.
- Window Tint Question....
- Location of engine bolt for coolant flush???
- What Does CAI Exactly Do?
- Increase in Red Line
- B series engine swap??
- 2 Throttle Cables
- DIY: 2001 DX LX sway bar
- Tint ?????
- Tapping wires?
- Headers Question...
- Light up light switch. need help.
- projection headlamps
- alignment after a accident
- need a lil help please
- CUT FRONT STRUTS????
- questions on painting
- Do I need to clear coat touch-up paint?
- What to do?????????????
- Installing A Body Kit Correctly
- Had my car for 1 year do i need a tune up or sumthing?!
- racing seat brackets
- lets talk cost...
- how can i keep my floor mats in place...
- HELP!! how do you take the runner assembly off of the seats??
- Horsepower gain?
- Painting RS sticker for Grill?
- HELP ME!! SNAPPED STRUT TOWER BOLT
- Can any one make a D I Y for moving your tire under your car??
- how do i install an m3 powered mirror with led?
- custom strut bars?
- Pullies?
- Tranny swap and head swap (as seen in Products and Parts)
- Anyone know how to fix a SCRATCHED WINDSHIELD
- seat install...
- Catalyc Converter
- non-noob altezza question
- cat-back question.....
- Procedure for shaving door handles?
- remote start in 5-speed
- A different type of cleared lights....
- ps2 question
- just bought 3157's but dont fit
- Ok so maybe all these intakes,headers,cat-backs don't give us much but what about!?!?
- just installed HU, now having electrical problems!
- I Hate My Cleared + Black Headlamps
- engine swap
- Grinding Noise...when i accelerate..FIXED!!!!!!!
- HELP! Installing Revo SS when POP!....
- CPU chip worries
- S-AFC??
- NEED HELP!
- SQUEEKY SPRINGS? (kind of)
- Do our Civics come slightly tinted from the factory?
- HELP ON a/c and blinker
- Aftermarket Fog/Driving Light Install Question
- Piping
- AEM Cold Air installation
- Free Air Subs?
- Turboed Matrix info that may help with 7G Civics
- Updated: DIY Relocating spare tire under the car (with pics)
- cai or short ram ??
- auto meter air/fuel gauge install???
- Valve Cover Painting... with DupliColor Mirage System
- HELP@@
- Intake Cleaning Question
- HOW TO CLEAN AEM SRI INTAKE FILTER
- injen cai
- Where to drill a hole in the firewall
- parking lights
