View Full Version : Honda Civic DIYs and Civic Tech Chat
  1. Installed intake and Check Engine light appears
  2. spoiler = installed
  3. Custom Question????????
  4. Mississippi and surrounding states
  5. Going to Buy Springs soon...NEED HELP.
  6. CAI and California Emissions
  7. lead substitute
  8. Spring Installation DIY Needed
  9. panic button reprogramming
  10. grill mesh install???????????
  11. Brakes!! Need advice
  12. hood holder bar thingy
  13. AEM Bypass valve diagram question
  14. any one have tips for installing a liteglow neon kit? or DIY?
  15. No amp with bazooka 6 1/2's???
  16. Flow of stock exhaust vs. aftermarket?
  17. Will this wheel size fit??
  18. Gotta have 17s
  19. Replacing black door handles and side mirrors with silver ones
  20. Need help removing rear quarter panel
  21. Top Of Coilover Bottoming out on strut housing
  22. Need DIY short shift adaptor install
  23. rear bumper
  24. Rims question?!?!?!?!?!?
  25. matrix 4-2-1 chrome header?
  26. throttle body spacer
  27. Which Strut Bar is it?
  28. cheap cold air intake
  29. Does anyone know the value of R1 the resistor you play with on the DIY hyperblinker>?
  30. What Alarm Sys...........?
  31. Strut Bar taht fits a car with Intake
  32. blinkers?
  33. Throttle Cable Probs. . .
  34. Premium vs. Regular
  35. K2 HID Conversion help!
  36. Aftermarket Springs/Coilovers...Do I need Camber Kit?
  37. Injen Intake
  38. Shift boot Replacement
  39. removed resonator.. could bad things happen?
  40. pedal sizes
  41. map lights
  42. map lights
  43. AFTERMARKET STEERING WHEEL HELP!!!!
  44. painting rear drums
  45. 17" Wheels + 2" Drop + Body Kit = Scrapeage???
  46. What is the difference? 215/45/17 or 205/40/17
  47. How to relay projector lights?
  48. Projector question
  49. Help on Tachs...
  50. messed up DIY's
  51. HELP!!2nd gear pops itself out and grinds.
  52. Air/Fuel Meter..which wire off O2 sensor???
  53. Anybody upgraded their ignition?
  54. 300 HP 2k1 Civic?
  55. Help!!! xenon body kit install...
  56. AWWW... noise maker!
  57. The dealer words
  58. Non-Civic Help Please....
  59. DIY Blue Interior Lights
  60. Will new tachs on a DX reset the total milage.
  61. idea approval?
  62. Hard-Wire ??? From Mega DIY
  63. Installed My Projectors
  64. Adjusting throttle cable feedbacks
  65. xenon front bumper...
  66. Popping noise after spring instalation???
  67. Tail Lamps for 2k2 Civic Si
  68. Racing with 5 speed???
  69. Help with Ground-Controls!
  70. Blinker idea & need help
  71. ROTATE TIME
  72. HP Racing Header w/ Hi-Flow Cat
  73. prokit = camber kit??
  74. Brake pads
  75. ecu wiring
  76. Wiring lights
  77. Looking for a certain alarm, any peps knowing about aftermarket alarms look
  78. Taking out THE TAXOMETERS!
  79. POWER WINDOWS ON A DX
  80. Air Conditioner Removal
  81. Question to IamLoki
  82. Someone throw me a fricken bone here ...... someone with electrical experiance
  83. OEM rims?
  84. melting or cutting plastic?
  85. Speaker Mounting Depth?
  86. DIY CLEARING HEADLIGHTS??????
  87. installing apexi rev speed meter
  88. Springs to eliminate wheel fender gap?
  89. swappable parts
  90. Hood Rod
  91. Adjust Throttle Cable??
  92. 15w50 motor oil
  93. DC Sports TCS catback install ?s
  94. Maintenance TIME!!!!
  95. Installing a spoiler??? Anyone done it before.....
  96. DIY Govenor Removal Needed.
  97. Good drop look
  98. The myth of the 80 shot N2O, feasible?
  99. anyone know how Scissor doors are done on civics??
  100. Installing New Trunk Springs - need help
  101. DIY on headlamp black housings
  102. need help on LED washers
  103. Sedan DIY hyperblinkers
  104. I have a HUMONGOUS problem!!!!please help
  105. new clutch
  106. what this noise
  107. ATTN: Those that installed their KONIs...???
  108. koni/ground control graumet
  109. new idea for DIY...
  110. DIY trim finally done...
  111. Anyone done this to their Auto?
  112. Frankenstien Swap???
  113. INSTALLING PROJECTORS? HOW? NO INSTRUCTIONS!!
  114. Grill Repainting
  115. Help people with the upper grill
  116. NX kit question on if somthing dosnt work, like one of the solenoids??
  117. Ignore last post and answer this one
  118. Tires/rims QUESTION 215/45/17 on a lowered 2k1 ???
  119. I searched.. i can't find.. HELP on rpms
  120. how to install the bodykit without shake and stay firm?>?
  121. Neons inside the middle air vent
  122. Spring break in period.
  123. ARGH! Water in my altezzas!
  124. clutch pedal travel distance too long
  125. horsepower = 1/4 mile time
  126. Cleared Headlights w/pics. Looks good.
  127. rs kit w/mudflaps??
  128. Just traded my 2002 LX Coupe for a 2002 EX Coupe
  129. whos got a helms and a scanner and wants to be nice?
  130. WHat are these for?
  131. New Exhaust / Reset ECU?
  132. getting behind a pillar to knock out a dent?
  133. OBD III?
  134. can a ex aem cai fit on a dx
  135. Auto LX Intrument Cluster in 5spd. DX? Yes.
  136. K&N Fuel Injection Kit?
  137. Please help! Changing dash lights???
  138. HKS Turbo Kit
  139. Springs for sale
  140. How do i reset the radio code
  141. apc front strut bar which intake
  142. DIY is kinda slow lately.....
  143. GC/Koni prob!!!!
  144. Civic EX, Civic Si (Si-R), RSX suspension
  145. help please.. i hate muffler guys
  146. Coilovers
  147. help about the side pinstripes
  148. tail light covers? pics
  149. DIY: Dash Lights Part I
  150. DIY: Dash Lights Part II
  151. ECU Wiring Harness Layout Question
  152. painted headlights...
  153. DRL off?
  154. Cleaning the INJEN FILTER
  155. serious concerns...
  156. Air Intake Question
  157. Alarm Install Help
  158. Need advice for mods to leased Civ.
  159. WTF: Coilovers
  160. how hard to install a header? it looks very easy to me
  161. DIY black housings
  162. installing intake what do i do
  163. Best 95 bucks I have spent in a long time!
  164. Help on Cat back systems...
  165. replacement oem filter?
  166. removing the dash...
  167. interchangeable exhaust??? possible???
  168. springs to eliminate wheel fender gap?
  169. What is the best psi?
  170. Engine swaps??????
  171. questions?????
  172. So, EM or EX?
  173. Button or No Button
  174. DC SPORTS HEADER INSTALLATION
  175. HID convertion for Civic H3 Projectors...need help
  176. Reprogramming your chip, for intake and exhaust. Necessary?
  177. Ground-Controls are pissing me off!
  178. Crazy but true...
  179. Philips SilverVision
  180. Home Made CAI , has someone done it?
  181. How do you remove these pillars?
  182. I got SCARED!
  183. I must be lucky..........
  184. What ya think bout this idea? (arospeed front mount intake)
  185. How do i get muffler off??
  186. Steering Problems
  187. Greddy Evo ?????? Help???
  188. How do you take off the little flap underneath the stock CD player???
  189. HOW PUT THE BODY KIT BACK ON THE CAR , IT FELL OFF
  190. Any Ideas on how to do this?
  191. ATTN: ALL DX AND LX COUPES W/EXHAUST! NEED HELP
  192. How side molding is attached???
  193. Wheel Specs?
  194. wiring a led
  195. stainless vs. ceramic
  196. tire size????
  197. vibrant strut bar how to install??
  198. PICS HIPER H4 Bulbs and Green Underbody Neons at Night
  199. strut bar need help
  200. PICS of my painted rear drums
  201. britney spears pics(nude)
  202. What is this called..
  203. 4door with no side moldings?
  204. Cutting struts for dopped cars?
  205. rear drum brake
  206. does anybody know how to put in a hand clutch?
  207. HELP - ground control install
  208. Need a little clarification on a header
  209. efficiency algorithm (tire size/mileage/odometer) help!!!
  210. im lazy tell me how to paint the Honda Vtec on the cover
  211. Engine bay in LX sedan vs Coupe
  212. idea on dc header
  213. DIY: Custom grill insert?
  214. lowering cars
  215. what kind of Tires?
  216. PLEASE HELP EXHAUSTE SYSTEM TOO LOAUD!
  217. i blew up my clutch !!
  218. removed muffler
  219. has any1 installed aem big rotor kit?
  220. tires on backwards?
  221. magnaflow exhaust leak (magnaflow owners)
  222. What will Honda Allow?
  223. custom cat back system-remove resonator?
  224. alignment specs
  225. Custom Rear Console
  226. Help please
  227. Question about alignment after lowering
  228. Wiper Arms.
  229. Don't be a jerk and just help please
  230. foglights turn off when you go to Highbeam
  231. Using d2 on an auto to stop roll back safe to use?
  232. 5W30 Synthetic in Winter?
  233. Idea... Wireless Sidemarkers
  234. Help on Lowering w/ ground control???
  235. Installing body kit i have a Q
  236. hp racing new for 2002
  237. newbie to 2k1's needs help fast
  238. question for members with REAL HID *edited w/pics*
  239. alignment
  240. KICKING A$$ TILL I HIT 3rd GEAR
  241. how much to ported and polished head and intake manifold, three angle valve job, camshaft, and porte
  242. Idea on Painting Rear Drums
  243. Should I or should I not?
  244. rear upper strut bar
  245. weight of 15" steel rims?
  246. Should Oil Drain Bolt Be Hard to Loosen?
  247. Compustar Alarms question
  248. instructions on how to install black lights in your car
  249. Quick question about tapping fogs into headlights
  250. questions on parts
